| fecto321 |
 fecto321 Derestricted Danger
| Nexus Icon |
| MickC |
 MickC Spanner Monkey
 Posted: 20:35 - 30 Jun 2011 Post subject: |
Does sound like a fuel problem doesn't it. Like 'Nexus Icon' sugests check the tank breather system. (when you set of its downhill so less work for the engine less fuel used, coming back you need more throttle because of the hill so more fuel burnt) ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
| fecto321 |
| MickC |
 Posted: 20:40 - 30 Jun 2011 Post subject: |
Easiest way is to leave the petrol cap off next time you ride home see if it makes it all the way, if it does you'll need to locate the breather hole and clear it ( on my 900 its in the cap - little hole, get some WD-40 and blast it through it) ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| fecto321 |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| fecto321 |
| MickC |
 Posted: 17:49 - 01 Jul 2011 Post subject: |
To the right of the rusty screw and if you look on the petrol cap theres what looks like a small tube it looks like they will be it. Blast the one in the petrol cap with WD-40, if you spray the one on the tank only use a short blast, you don't want to fuck up your petrol, maybe a ethonol based spray like 'easy start' might be better there. ____________________ XX XXXx
| fecto321 |
| heehaw |
 heehaw Nova Slayer
| fecto321 |
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 04:54 - 02 Jul 2011 Post subject: |
how is the fule filter (if it has one)  ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,, |
| fecto321 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 01:44 - 03 Jul 2011 Post subject: |
Aliens,ionizing radiation,witches?All i could think of is it might be overheating .On the way to work the engine works less and is probably not quite fully hot when you get to work as its only a few miles,on the way home its uphill (and ambient air temperature is higher,assuming your not on the night shift) so it might be seizing.Like when you try to overtake. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| weasley |
 weasley World Chat Champion
| MickC |
 Posted: 09:25 - 03 Jul 2011 Post subject: |
Whats it like on a long run, does it run for say three or four miles, conk out then run for the same distance before dying again. Or does it die after three or four miles then die again a lot sooner, starting to wonder myself now if it isn't an overheating issue (whats the oil level/condition like?) ____________________ XX XXXx
| el_oso |
 el_oso World Chat Champion
| unitynotsocri... |
 Posted: 19:12 - 03 Jul 2011 Post subject: |
witches,followed by overheating,followed by overheating dry joint,or(blocked thermostat,faulty sensor ?) ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| fecto321 |
| MickC |
 Posted: 23:36 - 03 Jul 2011 Post subject: |
You might have to pull your carbs as you say to give them a clean, before you do change or install a new fuel filter and put some cleaner in the tank such as 'Redex' or magic bullet and give it a good run at higher rpm, it could shift any thing causing a blockage and is quicker and cheaper than pulling your carbs. ____________________ XX XXXx
| robocog |
 robocog Traffic Copper
| fecto321 |
| evoboy |
 evoboy World Chat Champion
 Posted: 16:40 - 13 Jul 2011 Post subject: |
Carb icing? In the middle of summer?  ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| fecto321 |
The last post was made 15 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
