| kerr |
 kerr World Chat Champion
 Posted: 23:05 - 30 Jun 2011 Post subject: could this be the cause of my running problems? |
took the bike a run tonight, got about 10 yards from my house and it began to bog down in 2nd gear, dropped to first the revs dropped all the way and died, couldnt get it started again.
getin really hacked off with it now, took the airbox off, and undone the carb to have a look, i noticed the 2t feed was kinked, the black part of the pipe appears to have been stuck on the end of the 2t pipe with insulating tape wtf its too short which has caused it to kink just as it goes into the carb, its hard to see in the pics, couldnt find my camera so apiologies.
also the bit of the carb iv circled red, is that where the fuel filter is?
https://i266.photobucket.com/albums/ii265/BIGKERR/2tkink-1.jpg ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
| MattWadz |
 MattWadz Trackday Trickster
| kerr |
| MattWadz |
| Teflon-Mike |
 Teflon-Mike tl;dr
| kerr |
| MickC |
 MickC Spanner Monkey
 Posted: 10:06 - 01 Jul 2011 Post subject: |
Never had a two stroke meself but i have heard you can un-seize them by pouring some two stroke into the bore (through the plug hole) and working the piston from the crank bolt (under the left hand cover). But you are most likely to have suffered bore damage from the original seizing, but who knows you might be lucky. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:39 - 01 Jul 2011 Post subject: |
| MickC wrote: | Never had a two stroke meself but i have heard you can un-seize them by pouring some two stroke into the bore (through the plug hole) and working the piston from the crank bolt (under the left hand cover). But you are most likely to have suffered bore damage from the original seizing, but who knows you might be lucky. |
EEK!
Yes, thats actually true for most engines, if they have 'nipped up' in the barrel. And two strokes tend to be more prone to that, four strokes much more likely to sieze in a main bearing.
a LITTLE two stroke down the plug hole, then rocking bike back and forth in gear to GENTLY ease it off, can 'do the trick'.... HOWEVER
while may 'work' and engine may run 'OK' on something like a strimmer engine, or air cooled piston port engine, the 'Trouble' is that often, run 'Dry' the piston will 'burr over' around the piston rings, sticking the rings into the grooves, giving low compression, and poor running, and accelerating bore wear... and if nip up caused damage, it wont get any better, and will get a lot worse a lot more quickly.
And this is an AF1, which is a water cooled Hi-Po two stroke; not even sure if it may even be a single ring piston!
They do NOT like running without lube....
and if the ring or rings have scored the bore, and or the rings are burred int the piston, it would be asking for trouble to even try....
running it, and getting secondary damage from a ring snagging in the port or the small end bearing colapsing would be major major hassle.
Keith will be along to tell you prces and suppliers for AF1 'Bits', but worth a head & base gasket to wip the top off and have a look... drain coolant first, and I think its six bolts on them......
If it's not nice when you have the top off, well, THAT is Hi-Po two strokes for you..... and likely not ALL damage was on your part.....
If all's OK, breath heavy sigh of relief.... and mutter all you like at the waste of time, and cost of gaskets..... BUT, better that small hassle that a completely fucked engine! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| MickC |
 Posted: 12:56 - 01 Jul 2011 Post subject: |
He really is an Encyclopedia Biketanica and i happily defer to his opinion and vastly superior knowledge ____________________ XX XXXx
| kerr |
 Posted: 18:37 - 01 Jul 2011 Post subject: |
thanks for advice guys, looks like the sockets will have to come out then, i knew i would have to at some point but iv only done 50 km on the thing
as ever a fountain of knowledge mike  ____________________ aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple |
The last post was made 14 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
