| Jenks |
 Jenks World Chat Champion
| mr.kris |
 mr.kris Traffic Copper
| MarkJ |
 MarkJ World Chat Champion
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 00:55 - 03 Jul 2011 Post subject: |
play with the pre load,if its too hard then there's little feedback near the 'point of no return' ,just when you need the weight to sink into the shock .Alternatley try riding a tiny bit slower . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 01:08 - 03 Jul 2011 Post subject: |
well the tyre aint looking angry at all on the edges. going by the wear on the treaded grooves your giving it a fair bit of gas when cranked over but not in long or fast corners either that or your tyre is to hard a compound for what your after ...try running a few psi less and see how it feels. it's worth experimenting a few psi either way to get the feel your after. the vfr is going to have soft settings as std and not a lot you can do about it on the damping front and TBH the bikes pre load should on that model ever be to much even though it's good at 2 up with luggage its still not track bike hard!
let me know how you get on  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| weasley |
 weasley World Chat Champion
| Jenks |
| Frost |
 Frost World Chat Champion
| MarJay |
 MarJay But it's British!
 Posted: 09:48 - 03 Jul 2011 Post subject: |
Haha, I love these threads. I love the way that everybody seems to give out conflicting and mostly useless advice.
Jenks, Here are things that you can do to try to improve the situation:
Check the condition of your suspension.
Consider replacing the fork oil with the correct level and type. Examine the rear shock and work out if it might need replacing. It probably doesn't need replacing, but its worth checking. Also examine wheel bearings, suspension bushes and linkages. Make sure there is no play in them. Knackered wheel bearings can cause all sorts of weird issues, as can knackered bushes and lack of fork oil, or old fork oil.
Set up the suspension correctly.
The suspension preload is the most important adjustment on any bike. Have a look at the PDF in the attached zip file. Its the simplest guide I've seen to setting up ones suspension.
Check the tyre pressures
Check that they are spot on to the tyre manufacturers reccomended settings for the bike. If these are unavailable then use the bike manufacturers reccomendation, but remember these are for the OE tyres, and so may not apply to more modern tyres that might have stiffer, or less stiff sidewalls for example. If your tyres are different makes and models front and rear, then this could well be the issue. Mismatched tyres can sometimes cause weird handling issues.
If these things don't help then:
Consider a different make and model of tyre.
I have found that Pirelli Diablos provide a good round profile and never make it feel like you're falling off a cliff. They are a confidence inspiring tyre.
It'll be something simple, but there is no point me trying to guess the exact cause after looking at a couple of photos of your tyres and hearing a very short explanation of the problem. Giving advice like "Its your front preload, mate" Is totally pointless. You need to work out what the problem is because you're the only one with all of the information. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Jenks |
 Posted: 13:48 - 03 Jul 2011 Post subject: |
Cheers marjay
Tyres arnt the problem, they are Pilot powers, not mismatched (Cant do that in germany! ) - and im not allowed to change... i can only have pilot power I or II, or pilot road
having looked at the preload again, inbetween work, it was around 45-65degrees from NONE.
ill see if i can work through the attached file , and try to breathe some life into her.
that or i change bike!
cheers ____________________ 1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi |
| unitynotsocri... |
 Posted: 18:16 - 03 Jul 2011 Post subject: |
as other posters ,but check the swingarm and wheel bearings,that should keep you busy next weekend. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| stinkwheel |
| Jenks |
| Jenks |
The last post was made 14 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
