Halogen spotlight question
dgo1212
PostPosted: 02:20 - 03 Jul 2011    Post subject: Halogen spotlight question Reply with quote
Earlier this year I decided to replace the lights in our lounge and kitchen, as I was re-boarding the knackered ceilings anyway I thought it would be a good idea to fit halogen spotlights as the wiring would be easy to do with the ceilings removed, had ceilings plastered and fitted the new lights and it looked great, however now I've had them a few month they're actually a massive pain in the arse, when they're on they almost blind you if you sit under them ,the bulbs are forever blowing, when they blow they trip the rcd and the amount of light lost from one blown bulb is unbelievable, they're a couple of quid a bulb so can become costly if like me you let them all blow till there's only a couple left, have looked into led bulbs but at £12 a bulb and 18 bulbs in total there's no way I'm going down that road, needless to say they're coming out and I'm going back to normal light fittings and a flourescent tube in kitchen, problem is I'm going to be left with 18 holes, Filling them in is gonna be a pain as it means the ceilings will need painting again, and I really don't feel like doing that sh1t all over again, are there any kind of white plastic caps that I can just push into the holes? Have tried google and ebay and comes up with nothing, karma for anyone who can find something suitable Thumbs Up
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
kestrel
PostPosted: 02:57 - 03 Jul 2011    Post subject: Reply with quote
Personally i'd leave the fittings in the ceiling and bite the bullet and buy LED bulbs. Halogen bulbs are an expensive to run pain in the arse, especially in kitchens and bathrooms and also, due to the heat they generate are a considerable fire risk unless fitted with protective hoods, whereas LED's are cheap to run and produce virtually no heat. I've replaced all of the ceilings upstairs in my house and fitted LED downlighters in every room, including IP65 units in the bathroom, when i fit a new kitchen next year i'll be putting LED's in there too.
The old bathroom ceiling had 6 halogen downlighters using a total of 300w, the 6 LED's that replaced them use a total of 30w, so the saving on energy costs after the initial outlay is massive. Factor in the number of times you have to replace halogens compared to the 10,000 hour life of an LED and after a few years they will pay for themselves.
Isle of Man.........Road Racing Capital Of The World
PostPosted: 08:31 - 03 Jul 2011    Post subject: Reply with quote
What fittings do you have? LED GU10's are under £3 these days.
neil.
LED spots aren't very bright and too directional. You could try compact fluorescents if they are GU10 240v fittings, those are quite good, used them everywhere in our old house which had these fittings all over the place (I hate them personally!) Wink.
https://www.ebay.co.uk/itm/10-GU10-11W-50W-WARM-WHITE-LOW-ENERGY-SAVING-SPOT-BULBS-/170644550488?pt=UK_Light_Bulbs&hash=item27bb353358#ht_500wt_922
The warm white ones are really nice. Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 15:11 - 03 Jul 2011    Post subject: Reply with quote
Cheap LED fittings are a false economy! They are generally rubbish, usually sold by B&Q and give LED lighting a bad name as people buy these cheap rubbish, realise they are shit then go round saying "LED lamps are shit!"
LED lamps with multiple single LED's in them aren't even worth the packaging they are in for starters. You want to be looking for something with a CREE or philips chip in them, but more importantly is how they dissipate the heat. The chip may be rated at 10,000 hours but if they do not have decent heat dissipation they won't last half of that. Look for brands such as Deltech, Decor, Megaman and Phillips.
neil. decent LED lights have a good beam angle now and a quality (expensive) lamp will, just about, compare to a 50W halogen.
Your 18 50W GU10's are burning 900W all the time they are on, changing to 4W Decor LED's at £12.49 each will cost you £224.82 but cut your electric from 900W to 72W in total. Their rated life is 30,000 hours compared to approx 2500 of a halogen (if you're extremely lucky) so whilst you have to spend £225 now you'll save that back relatively quickly.
They have a 36deg beam angle (same as GU10) and are equivalent to 35W, which wil be a benefit if you're saying your 50W's are too bright... only negative is these particular lamps aren't dimmable (you can get dimmable LED's but they're more than twice the price)
p.s I've never seen any type of plug to fill a downlight hole so if you do go down the removing them route it'll be a case of plasterboarding the hole and then skimming over. Anything else will look a bit rubbish!
neil.
PostPosted: 18:12 - 03 Jul 2011    Post subject: Reply with quote
Sorry, I should have mentioned those Luxeon etc. LEDs, they really are good but I haven't got any first hand experience of them in GU10 fittings (got one on a head torch and that looks like the sun is coming out of my forehead!). Are any of these high power LED units dimmer compatible (I do know Megaman do sell dimmer compatible compact florescents)?
Sparks!
Sir Tart-a-lot
PostPosted: 07:22 - 05 Jul 2011    Post subject: Reply with quote
Yeah you can get dimmable but they aren't all that cheap. For retrofit lamps then you cannot beat Philips dimmable lamps, about £35 each though and they are quite large so limits some of the fittings you can install them to. I believe deltech have a dimmable one out now as well as do megaman.
For LED complete fittings then Orlight and Halers offer decent dimmable fittings, I love the Halers personally, really good fittings. As anything though they aren't cheap but pay for themselves relatively quickly.
The last post was made 15 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 60.79 Kb
