Fork Oil Alternative
LanaTheGreat
PostPosted: 23:58 - 03 Jul 2011    Post subject: Fork Oil Alternative Reply with quote
The wife and me both have Yamaha XT350's. It's been a couple of months since I have noted that my wife's bike forks have been leaking. The leaking has since stopped, I guess there is no more oil to leak out. I obviously have to renew the fork seals.
It seems that fork oil is pretty expensive, and I would like some advice on an alternative cheap oil that can be used instead of the fork oil that the manual specifies. Any ideas?
Born to fish, forced to work
Kazuma SilverFox, Yamaha XT350, Yamaha DT175, Yamaha XT350
PostPosted: 00:01 - 04 Jul 2011    Post subject: Reply with quote
Automatic transmission fluid. Same as 10wt fork oil.
I've also had bikes that used engine oil or a mix of engine oil and ATF.
kestrel
PostPosted: 00:29 - 04 Jul 2011    Post subject: Reply with quote
I used to use Shell Tellus 27 hydraulic oil in my bikes, but have used light engine oil in the past.
Isle of Man.........Road Racing Capital Of The World
PostPosted: 08:30 - 04 Jul 2011    Post subject: Reply with quote
Its not *that* expensive. A litre of Motul 15 weight fork oil is about £6 from Wemoto. a litre per bike should be fine.
Automatic Transmission fluid is probably more expensive...
PostPosted: 08:40 - 04 Jul 2011    Post subject: Reply with quote
ATF lasts longer though.
Raffles
PostPosted: 11:25 - 04 Jul 2011    Post subject: Reply with quote
Is the grade of fork oil critical? I only ask as my three bikes all specify different grades of fork oil. One specifies 5w, one specifies 10w and the other specifies 30w.
LanaTheGreat
PostPosted: 15:01 - 04 Jul 2011    Post subject: Reply with quote
Thanks for the replies. ATF it will be then, since I can get a lot of it for free from work. Mr. Green
Teflon-Mike
tl;dr
PostPosted: 15:15 - 04 Jul 2011    Post subject: Reply with quote
Some bikes actually specify ATF as thier fork oil. Its approx 5wt, possibly a little lighter, and it's a very good general purpose hydraulic fluid, but it doesn't have the seal swellers and other addatives of propper fork oil.
and unless you are buying the stuff in bulk, from an agricultural supplier for the ten gallon tanks of a tractors hydraulic lift system.....
Its rarely any cheaper than either regular gear oil, engine oil or fork oil.
OP.... if you think that 'propper' fork oil is too expensive..... flog your XT's and buy a couple of old piston ported air cooled trail bikes like a Bultaco... becouse fork oil ENT expensive.
My local Motorfactors flogs the stuff for £7 a litre, which is about £2 cheaper than Busters down the road.
It'll only be 'expensive' if you are buying it from the wrong place....
Shop around!
PostPosted: 15:27 - 04 Jul 2011    Post subject: Reply with quote
It is probably something that will cause a noticeable change to the bike, yes. For example if you were to put the correct amount of 30w oil in the bike that specifies 5w the front end would feel too hard and not provide the correct damping, and vice versa.
PostPosted: 17:59 - 22 Jul 2011    Post subject: Reply with quote
Very critical.
Use 30W where 5W is specified and it would probably be like trying to hold onto a pneumatic drill as the forks would probably not absorb any bumps. While using 5W where 30W is specified would probably mean the suspension was barely damped.
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 67.78 Kb
