Sheds
neatbik
PostPosted: 13:10 - 04 Jul 2011    Post subject: Sheds Reply with quote
I need to buy a shed, just for the kids bikes/lawn mower etc etc.
Having never in my life needed to buy one its not really something i have had to ponder before now...
So, i'm after an 8' x 6'. I have found this one -
https://www.gardenbuildingsdirect.co.uk/Wooden-Sheds/BillyOh-Classic-Popular-Rustic-Economy-Overlap-Apex
This seems cheap enough, but is going to last?
What does a chap have to look for when buying a shed?
Cheers,
Nick
Flip
PostPosted: 13:13 - 04 Jul 2011    Post subject: Reply with quote
It won't last forever but a decent quality version will cost twice that. Where ever you put it leave it there. It won't take well to be moved.
Ideally you'd want T&G and solid roof panels and proper floor boards but that's probably OTT for for your needs. Laughing
kerr
PostPosted: 13:36 - 04 Jul 2011    Post subject: Reply with quote
use a decent woodstain, re-coat every couple of years it'l last for many a year
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Flip
PostPosted: 13:49 - 04 Jul 2011    Post subject: Reply with quote
Another thought. With it being overlap don't let any climbing plants get in it or it'll get pulled apart as the plant grows.
duhawkz
PostPosted: 13:52 - 04 Jul 2011    Post subject: Reply with quote
This, Looking at the specs the cladding is only 5mm i personally would wants something at least double that, my new shed was 12mm but as above it was near twice the price of a similar sized shed from the place your looking at.
If you on a budget then it would do but it won't be particularly strong or anything
mogster
PostPosted: 15:25 - 04 Jul 2011    Post subject: Reply with quote
Make sure shed is on a good foundation. Ideally concrete with insulation, but at the very least raised off the ground or it will rot from below.
MOG
The roar of his mighty triumph was heard throughout the land
PostPosted: 16:23 - 04 Jul 2011    Post subject: Reply with quote
Nick.
That shed is crappy. I have one.
Think of it as a slightly rigid bike cover.
Mine's a year old and still looks good, partly because i prepped the wood inside and out before construction.
I reckon it'll last 5-7years, which is pretty good for how cheap it was.
neatbik
PostPosted: 17:04 - 04 Jul 2011    Post subject: Reply with quote
Cheers guys. Thumbs Up
Its only going to be used as storage really, and i only want to spend as much as i have to.
Pat, what stuff did you treat yours with?
Also, i'll probably lay it on paving slabs as i have quite a few kicking around, that ok?
Cheers, Nick Thumbs Up
PostPosted: 17:30 - 04 Jul 2011    Post subject: Reply with quote
For the 1st coat i used that mix it yourself stuff that came with with it. Then got 5ltrs of fence-life.... stuff.
It's pressure treated timber so with me adding the extra few coats....should last a few months longer. Smile
If you do go for the 'el-cheapo'. Expect splits and knot holes.
The roof and floor are fibreboard. I re-enforced mine with a plywood base to take the extra weight.
Predrill..The timber is brittle, because it's thin.
Use sealant where the walls meet the floor.
Yeah, slabs. Set so the water runs where you want it.
Did mine on gravel with bricks at the load points. It's what i had to hand otherwise flags/slabs are better.
Cunnington
PostPosted: 07:51 - 05 Jul 2011    Post subject: Reply with quote
I bought a T&G shed from them for the kid's toys - would recommend them as a supplier - for what it is it is well enough made. It only comes with a light coating of weather protection so I treated it all before I assembled it.
As per the other posts, make sure it is on decent foundations.
For security, you could just about sneeze through the windows, I bedded them in on silcone, which gives them a bit more strength in the wind - if you dont need them, see if you could get one without them.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
neatbik
PostPosted: 19:54 - 05 Jul 2011    Post subject: Reply with quote
Well Mrs Beatnck came home today and told me she had bought one from the local diy store....
Its closing down so she she paid £120 for it.
Looks like i'm spending the next few days learning how to lay a base for it, and then doing some erecting..
The last post was made 15 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 69.18 Kb
