how to bleed honda NSR 2003 back brake
leepick
PostPosted: 11:19 - 05 Jul 2011    Post subject: how to bleed honda NSR 2003 back brake Reply with quote
can anybody tell me how to bleed the back brake on a honda nsr please. i no its pretty simple but havent done it before
Aprilia RS125
DrDonnyBrago
PostPosted: 11:37 - 05 Jul 2011    Post subject: Re: how to bleed honda NSR 2003 back brake Reply with quote
Is the system currently empty and you need to refill it from dry or are you just trying to change the fluid?
PostPosted: 11:41 - 05 Jul 2011    Post subject: Reply with quote
The same way as you bleed the front brake? Or any brake for that matter?
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
leepick
PostPosted: 12:01 - 05 Jul 2011    Post subject: Re: how to bleed honda NSR 2003 back brake Reply with quote
its not empty no, needs bleeding and fresh fluid putting in. thanks
Aprilia RS125
leepick
PostPosted: 12:02 - 05 Jul 2011    Post subject: Reply with quote
havent done front or back brake before thats why im asking lol
Aprilia RS125
Livefast123
PostPosted: 12:05 - 05 Jul 2011    Post subject: Reply with quote
If you want to you can buy a bleed kit which will basically stop air being sucked back in via a one way valve but it's not essential.
You'll need 8mm ring spanner (for bleed nipple), brake fluid, syringe, screwdriver for master cylinder top screws and some clear tubing with a bottle at the bottom.
1.Attach ring spanner to bleed nipple nut section then attach pipe to bleed nipple and run to bottle (on the floor) fill bottle with brake fluid to cover bottom of pipe.
2.Fill syringe with new brake fluid and remove master cylinder top and top up the fluid.
3.Using your hand push the brake lever down, when you feel pressure undo the bleed nipple. feel the lever sink and watch the old brake fluid come out. When the lever reaches the bottom of it's travel tighten up the bleed nipple. Repeat until all the dirty fluid and air has come out. Watch the fluid level and DO NOT let the master cylinder run low / out of brake fluid.
4.When you've finished tighten the bleed nipple, replace the master cylinder top and nipple dust seal and jobs a good un.
Remember to TEST the brakes BEFORE you ride on the road!!
Livefast takes no responsibilty for the owners ability to follow this advice safely
Current ride - Yamaha MT-07
leepick
PostPosted: 12:21 - 05 Jul 2011    Post subject: Reply with quote
wow. really appreciate this. massive help thank you
Aprilia RS125
The last post was made 13 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 53.59 Kb
