Derbi GP1 running issues. Please help!!
russed99
PostPosted: 19:47 - 05 Jul 2011    Post subject: Derbi GP1 running issues. Please help!! Reply with quote
Hi all.
Recently purchased a non running derbi gp1. The previous owner suspected the cdi unit tho i have since changed this to no avail. After some tinkering, new plug etc. It became apparent that we had a spark and the problem seemed to be fuel related. The bike simply turned over but only briefly 'fired' before cutting out.
I have changed the auto choke unit and the vacuum tap this evening and after many, many attempts at starting, she gradually began to come to life.
Finally i managed to get throttle response and the bike was revving freely before again losing response. Close but no cigar it would seem.
So as it stands the bike will start and rev for maybe 30 seconds to 1 minute before it loses throttle response and cuts out. For the time it is running, it regularly threatens to die before it picks up again. Eventually tho, it always dies a death.
I dunno what else to look at. We appear to have fuel air and spark. Any ideas?
Nope.
PostPosted: 20:12 - 05 Jul 2011    Post subject: Reply with quote
1) Have you cleaned out the jets and carb bowl?
2) Spray some WD40 on the manifold and if it revs up then you have an air leak.
3) Clean the air filter
4) Check that the engine has compression
russed99
PostPosted: 20:20 - 05 Jul 2011    Post subject: Reply with quote
1) No i haven't
2) I'll give that a try
3) I've tried to run it without the filter on but i haven't cleaned it.
4) I've done a compression test and it was over 100 p.s.i.
Thanks for your help
Nope.
PostPosted: 20:26 - 05 Jul 2011    Post subject: Reply with quote
russed99 wrote:
1) No i haven't
The first step is to clean out the jet and carb bowl as ive said before.
russed99
PostPosted: 20:48 - 05 Jul 2011    Post subject: Reply with quote
I'll give it a try tomorrow. Thumbs Up
The last post was made 14 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 44.5 Kb
