NSR 125 Chain Replacement and Brake Bleeding
anthony_r6
PostPosted: 19:13 - 05 Jul 2011    Post subject: NSR 125 Chain Replacement and Brake Bleeding Reply with quote
Got a new chain that I could do with putting on my NSR 125. Do I need a riveter to do this? And to remove the other one, can I just loosen the back wheel, remove it from the sprockets and that's it?
Also, how do you rate this https://cgi.ebay.co.uk/Motorcycle-ABS-Brake-Bleeding-Kit-BRKKIT07-/330577397868?pt=UK_Motorcycle_Parts&hash=item4cf7f2c86c#ht_1315wt_905 for bleeding brakes?
skatefreak
PostPosted: 06:59 - 06 Jul 2011    Post subject: Reply with quote
unless theold chain has a split link:
https://www.dirtbikebitz.com/images/products/drive/renthal_link.jpg
then i would recomend cutting it off as you will have to get the swing arm off otherwise.
The new chain, again, unless its a swing arm you will need a chain tool (or a ball bearing and hammer Smile ) to flair out the final rivet.
For bleeding, i use a 6 inch peice of pipe, pour brake fluid into the resivour, compress, open bleed bolt, close bleed bolt, release, repeate and jobs'a good'un.
Seems a little pricey just for bleeding the brakes...
Best regards
-Jvr
The last post was made 14 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 32.39 Kb
