Will this fit a Suzuki TS250 - I think yes.. but if im wrong
sandman1976
PostPosted: 17:39 - 06 Jul 2011    Post subject: Will this fit a Suzuki TS250 - I think yes.. but if im wrong Reply with quote
Hey all, do you reckon this will fit a suzuki TS250ER?
the plugs are the same, and its a 250 engine, and a suzuki.....
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140571649682&ssPageName=STRK:MEWAX:IT#ht_500wt_1156
Your thoughts please...
Thanks.
Andi.El
PostPosted: 19:20 - 06 Jul 2011    Post subject: Reply with quote
I do not think so
TS250, one cylinder, CDI part number 3290030520
GT250X7, two cylinder, CDI part number 3290015321
sandman1976
PostPosted: 20:09 - 06 Jul 2011    Post subject: Reply with quote
BLUEX5 wrote:
OP's post is pure BCF gold
Aye well we not all experts Razz
Hence the asking first lol Smile
Trying to figure if mines actually a cdi engine, a bike place i have been on the phone to deduced it to be a 79-83 model but couldnt decide whether it should have a cdi or nott...?
Ok thanks chapps!
P.
PostPosted: 20:27 - 06 Jul 2011    Post subject: Reply with quote
Surely, you could just buy loads of TS250 bits down the local bike scrap yard?
Andi.El
PostPosted: 20:35 - 06 Jul 2011    Post subject: Reply with quote
I looked at the wiring diagrams of the TS250 and GT250X7. The CDI of the GT may be work i a TS250, because the GT is a paralell twin. I do not know if the ignigtion advance triming will work correct, the stroke of TS and GT are different. The TS has 64 mm stroke and 70mm bore and a singel fire ignition coil, the GT has 54mm stroke and 54mm bore and a double fire ignition coil. Otherwise I drive a Kawasaki GPZ600 with a GPZ900 ignition box. It works, only the RPM limiter is 1000 RPM earlier.
So what do you risk if you buy the CDI for 10 Pounds? In the worst case it does not fit and you burned 10 Pounds. From 1972 to 1981 Suzuki used two differend CDI units for the TS250, Nipon Denso and Kokusan.
sandman1976
PostPosted: 21:00 - 06 Jul 2011    Post subject: Reply with quote
Hmm so how do i deduce which cdi unit is for mine?
This look right? Is for a TS250 ER which i suspect mine is.
https://cgi.ebay.co.uk/SUZUKI-ER-TS-250-CDI-BLACK-BOX-/130450983321?pt=UK_Motorcycle_Parts&hash=item1e5f7c0999#ht_500wt_922
Teflon-Mike
tl;dr
PostPosted: 10:55 - 07 Jul 2011    Post subject: Reply with quote
I would have thought you start by pulling the rusty fly wheel rotor and looking for a pair of points.....
If you find some.... you dont need a CDi....
If you don't find some.... then either they are missing, or you need a CDi.
TS250, was Suzuki's generic 'dirt bike' in the late 60's & early 70's, and the basis for thier early compers. The Scramblers were slightly more successful than the trial bikes, which were over weight and ill tuned. Suzuki attempted, to make them more 'useful', but ultimately it wasn't until Beemish did a full trials chop job on one they came anywhere near close to working, and suzuki gave up, and 'licenced' the Beemish special.
This is an irrelevence to you, OTHER than; my starting point would be, knowing that they used the TS motor in the Beemish, to call Sammy Miller.... 'Old Dirt donks iz Uz'..... and have a chat.... they used to do some stuff to support the beemishs, but if they dont anymore, they will know who does.
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 63.4 Kb
