Jetwashing a bike
QM
PostPosted: 18:21 - 07 Jul 2011    Post subject: Jetwashing a bike Reply with quote
I have had my GF's mother mother comment on the state of my bike and yes it could do with a clean but I cannot be bothered to do it by hand so I was wondering if it would be okay to use the jet wash at my local garage instead?
05 Honda CG125 now 03 Honda CB600F Hornet
Clanger
Stirrer
PostPosted: 18:24 - 07 Jul 2011    Post subject: Reply with quote
It should be okay around the engine, but I would avoid the wheels, because it can stuff up the wheel bearings. In which case, you may as well get the bucket and sponge out at home... Thumbs Up
bombom
PostPosted: 18:29 - 07 Jul 2011    Post subject: Reply with quote
id keep it away from the top of the engine tho where the spark plugs are because you aint getting it running again for a while if they get soaked
Sham
PostPosted: 18:31 - 07 Jul 2011    Post subject: Reply with quote
They are ok as long as you keep the nozzle a good distance off and not get tempted to 'go close' for that stubborn mark. Some of these washers have very powerful nozzle pressures that make short work of paint finishes, coatings and the like. As stated, keep away from sealed bearings and such.
Personally I don't like them, preferring a bucket of water and a sponge.
If your bikes that bad, be careful about blasting too much grime away - it could be keeping together. Wink
QM
PostPosted: 18:34 - 07 Jul 2011    Post subject: Reply with quote
Its just a lot of road grime particularly on the wheels which is one place I hate cleaning as they are wire spoked and take an age to do.
Sham
PostPosted: 18:51 - 07 Jul 2011    Post subject: Reply with quote
I hear what you're saying about spoked wheels! Had a Triumph Scrambler and it took ages cleaning the crud off them! I would be tempted. You have to be careful of small rust spots, a pressure washer can force water into them and make matters worse. I probably accelerated the demise of an old VW doing this.
tommybhoy
PostPosted: 19:38 - 07 Jul 2011    Post subject: Reply with quote
You Could try these guys
https://www.allyearbiker.co.uk/index.html
Current bike..Honda VFR 800 Vtec
A billion seconds ago it was 1959.
Berk
PostPosted: 19:43 - 07 Jul 2011    Post subject: Reply with quote
My step-father jet washes his scrambler regularly, normally to get all the crud off from his last weekends racing. No idea if he misses any areas though, but the wheel bearings sound like a good thing to avoid.
It also means we have the mud of half of Europe around our driveway..
kawakid
PostPosted: 21:17 - 07 Jul 2011    Post subject: Reply with quote
You should look after your bike, my z750 gets washed after every ride, it only takes 10 mins and the bike looks perfect even after 4 years.
With my er6 I am a little lazy and wash it once a week, but i do use a pressure washer, the trick is not to get too close. What I do is I give it a good hosing down then about 10 mins with car shampoo and very hot water to remove any grime, then pressure washer again to clear off suds.
I've a twin and a 4.
DrDonnyBrago
PostPosted: 21:23 - 07 Jul 2011    Post subject: Reply with quote
Washing bikes is for the gheys.
Leave it dirty, it'll be filthy within a day or two anyway.
MinhDinh
PostPosted: 21:45 - 07 Jul 2011    Post subject: Reply with quote
I have jet washed my bike once and I kept well away from the wheels. Pain in the arse to clean the wheels but the only way is getting stuck in with some type of solution for the gease...
The jet wash is good to get rid of the muck after you brush it, but there's no substitute for hard work!
Hit the G spot. Wink
Slacker24seve...
PostPosted: 08:34 - 08 Jul 2011    Post subject: Reply with quote
Protip: Avoid old shitty paint on fork legs. The silver paint on my Hornet's forks went from 'lightly pitted' to crap in 0.5 seconds.
If the bike is looking really crap I'll spray the engine/downpipes with Gunk, leave for a few minutes while I have a fag and a coffee then blast off with the power hose. Good old fashioned elbow grease for the rest though Thumbs Up
Banger rallies are ace
Stowelly
PostPosted: 10:20 - 08 Jul 2011    Post subject: Reply with quote
did my gsxr on one of those car jetwashes the other day, it didnt get any of the oil off the bike, my white wheels where still black, but my clocks where nice and visible again! also must have got water in the airbox or carb as it ran like shit trying to get it home afterwards. will stick to sponge and the hose pipe next time!
robbieguy2003
PostPosted: 11:48 - 08 Jul 2011    Post subject: Reply with quote
As others have said, use it but keep it at a reasonable distance. Mostly around 1.5ft for me. I bought a cheaper pressure washer in the hope that it wouldnt be as powerful, i think at max it's 100bar, still a lot, but lower than quite a few of them.
I find it's worthwhile for a general clean, it's great for getting crud from the back of the swingarm (near where the tyre is).
As others have said, keep it away from bearings and you'll prob be fine. I seen Honda using it on their crossers at Silverstone at this years GP. They cleaned them all up not long after the event.
As above, i done this and managed to crash shortly afterwards on a really tight (hairpin) bend, leant the bike over, mid corner the back started sliding, i thought it'll catch in a sec, it'll catch, it'll catch, ah fuck it's not catching...
I'd suggest using it at home or if you use these garage ones give it 10 mins to dry and take it very very easy.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
c-m
PostPosted: 12:01 - 08 Jul 2011    Post subject: Reply with quote
Nothing wrong with jet washing a bike. Just keep the hose a good distance away to reduce the pressure.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
wiznyme
PostPosted: 12:08 - 08 Jul 2011    Post subject: Reply with quote
tommybhoy wrote:
Is this any good, would happily pay £60 not to have to wash bike for a year & yes I do know just how lazy I am Embarassed
Don't sweat petty things, or pet sweaty things
“Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?”
bunglebubs
PostPosted: 15:10 - 08 Jul 2011    Post subject: Reply with quote
I jet wash both of mine regularly never had a problem with either of them. But it doesn't get rid of really stuborn marks and the wheels sometimes need a bit of extra cleaning after.
899 Panigale, K7 GSXR 750
adamck
PostPosted: 15:58 - 08 Jul 2011    Post subject: Reply with quote
i snow foam my bike Razz
Example pic (not a pic of my bike)
https://i93.photobucket.com/albums/l54/blakeatron/27thJune049.jpg
then i hand clean it Smile
<insert><something><useful>Here</useful></something></insert>
The last post was made 15 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 97.95 Kb
