Chain, sprockets and clutch
Mellow Matt
PostPosted: 07:24 - 08 Jul 2011    Post subject: Chain, sprockets and clutch Reply with quote
Could anyone point out some decent places where I could buy a chain and sprocket set (and chain fitting tool?) and a clutch kit for my TLR please?
Also, would a chain that fits the standard sprockets fit on a -1 front sprocket coupled with a rear +1 sprocket?
Ta Smile
1999 GSX-R 600, 1999 TL1000R
anthony_r6
PostPosted: 08:20 - 08 Jul 2011    Post subject: Reply with quote
It should do, you're removing a tooth and adding one, which brings it right back to where you were. Also, I don't know about were to get your replacement parts, but try wemoto? I got a chain, sprocket, brake pads, etc from there.
Mellow Matt
PostPosted: 10:39 - 08 Jul 2011    Post subject: Reply with quote
I'll check out Wemoto thanks Thumbs Up
Yeah, that's what I thought about the chain but wasn't sure if the different sizes of the sprockets would mean the diameters change by different amounts with the addition/subtraction of a tooth...
PostPosted: 10:44 - 08 Jul 2011    Post subject: Reply with quote
The chain length should be the same, but the gearing will obviously change.
Try B&C Express for most of that stuff.
Mellow Matt
PostPosted: 18:40 - 13 Jul 2011    Post subject: Reply with quote
Thanks guys, it's time I get my arse in gear (ah-ha!) and get all this sorted.
Can anyone tell me if this Tsubaki kit is £40 better than this DID kit?
Also, would this be up to the task of removing my old chain and fitting the new?
Finally (sorry for all the questions!) I think my clutch is on the way out, so any reason why I shouldn't these clutch plates and springs? I know they're cork and I could get kevlar, but I think that might be overkill...?
Thanks! Very Happy
DrDonnyBrago
PostPosted: 08:27 - 14 Jul 2011    Post subject: Reply with quote
Thanks! Very Happy
I'd go for the DID, they are OEM fit on a huge number of bikes, I have one on atm and can't fault it. I don't see any real reason to pay more for something that does the same thing.
As for the tool, cheap ones are never really up to the task of removing a chain, use a hacksaw/grinder/bolt croppers to remove the old chain and just use the tool to install the new one.
IMO those type seem crap, I bought this one (the original one you posted is also cheaper on this site though).
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Categories/Tools__Essentials
and rate it well for the price, mine needed a tiny modification to work for the DID chain - two holes in one of the attachments need widening slightly - dremel/file/drill will do it in a few seconds. The link I posted also do C+S kits very cheap, take a second to see if your bike is listed as they are normally £20-£30 less than wemoto.
i.e. https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/3126VM
Chain tool instructions
https://www.pashnit.com/pics/products/motionpro/08-0058.I8-0058.pdf
The tool I listed is a clone of the one in the instruction pdf above, the bit you would need to modify is the part labelled L with the two holes in it - just make them wider.
EDIT: whenever anyone asks about chains and sprockets I seem to pimp that website, I assure you I don't work for them they are just the cheapest Thumbs Up .
Mellow Matt
PostPosted: 17:57 - 14 Jul 2011    Post subject: Reply with quote
Awesome, thanks a lot Donny Very Happy
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 56.14 Kb
