| koolio |
 koolio Spanner Monkey
| herulach |
 herulach World Chat Champion
| temeluchus |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 09:16 - 12 Jul 2011 Post subject: Re: Loctite Red/Blue? |
I wouldn't bother copper greasing if you are using loctite, the loctite is both a locking compound and an antiseizing measure. Use copious amounts of copper grease on any hot parts (exhaust studs etc) as normal grease will burn off. Always use thread lock on brake mounting bolts!
For normal engine bolts you don't really need loctite, a dab of copper grease and the bolts done up to the correct torque is plenty. Loctite is expensive so I only use it in the locations where the workshop manual suggests it is of some benefit. I use the blue loctite, have used it on loads of things of various temperature and it has held , the engine itself doesn't get THAT hot, the exhaust is the bit to avoid. |
| koolio |
| Pete. |
 Pete. Super Spammer
 Posted: 10:38 - 12 Jul 2011 Post subject: |
Don't use it on any plastic fairing/mudguard screws (not likely in your case but good general info). The vapours released during curing causes plastics to craze and crack arount the bolt holes if you use loctite.
As a general rule - red is permanent, blue is semi-permanent. anything you want to remove later don't use red on. Of course nowadays with so many grades it's better to look up the actual spec of the number on the bottle. ____________________ a.k.a 'Geri'
| DrDonnyBrago |
| koolio |
| DrDonnyBrago |
| MarkJ |
 MarkJ World Chat Champion
The last post was made 15 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
