Scored piston - repair cost? (CG 125)
Christian 2.0
PostPosted: 19:06 - 12 Jul 2011    Post subject: Scored piston - repair cost? (CG 125) Reply with quote
Hi,
Recently my CG125-BR 1999 began smoking furiously out of the exhaust, specifically when accelerating. Quick look in the mirror, blue smoke - oil. Figured the head gasket had gone, so caressed her home gently. What was really unfortunate is that for the next few days I literally had no other choice than to ride the bike for a few miles here and there. Topped up the oil before each trip, still smokey and sounded like it had a sore throat, no real power loss and still responding well.
Anyway, managed to find some time the other evening, took the top end off, found that the head gasket had gone. Bought a new one, fitted it and hey presto! Still smoking.
Had a chat with the chap at the garage today who said I've shot the piston, which will mean boring the cylinder and getting a new piston/rings etc. It's also likely that the cylinder head is warped and will need skimming.
How much can I expect to pay for the repair? Obviously the CG engine is so simple and easy to work on, though I don't have the facility to do the repair myself.
I have had the slap on the wrist for using the bike whilst damaged.
Has anyone got a rough idea how much this is likely to cost? I anticipate somewhere between £150-200, is that reasonable?
PostPosted: 19:11 - 12 Jul 2011    Post subject: Reply with quote
check it yourself...new piston and rings is about £30.
garage folk are nice, some are honest, some are bastards.
Get photos and put them on here..
Nexus Icon
PostPosted: 20:51 - 12 Jul 2011    Post subject: Reply with quote
What's the head made of on a CG nowadays? Is it really likely to have warped?
Greetings from Shitsville!
sickpup
Old Timer
PostPosted: 22:02 - 12 Jul 2011    Post subject: Reply with quote
So what type of head can't be warped?
Nexus Icon
PostPosted: 22:18 - 12 Jul 2011    Post subject: Reply with quote
They all can but aluminium ones are the only likely victims, tbh.
Teflon-Mike
tl;dr
PostPosted: 22:42 - 12 Jul 2011    Post subject: Reply with quote
For a ballpark:
https://www.ridersmotorcycles.co.uk/scripts/prodList.asp?idcategory=49&curPage=2
TO FIT: CHINESE 125CC PUSH ROD CG125 COPY ENGINES HONDA CG125 UP TO 1998
TOP END GASKET SET £4.50
CYLINDER HEAD COMPLETE £55
CYLINDER BARREL KIT £41.50
Cylinder 'kit' comes with piston, rings gudgeon pin, circlips, base and head gasket.
MIGHT be all you need.
Head is built up with valves, springs and collets.
That kind of money, these chinky bits can be cheaper then machine shop time to get barel bored and head skimmed.
I'd budget aprox £30 for a new piston, £30 for a rebore, £50 for a head skim and valve & seat grind.... elsewise.
Check e-bay, Riders aren't the only folk offering these parts, though they are prety competative.
Christian 2.0
PostPosted: 11:54 - 13 Jul 2011    Post subject: Reply with quote
Many thanks for the replies.
@Paddy: Unable to take pics, the bike's strapped up in back of van waiting to be taken in tomorrow.
As for everyone else, learned some useful information. Appreciate it. Will post back here when the job is complete with a breakdown of final cost for others' benefit.
Cheers Smile
Christian 2.0
PostPosted: 16:50 - 19 Jul 2011    Post subject: Reply with quote
Had the bike back today.
Total cost parts and labour (as well as a bit of servicing) came to: £147, which is pretty much what I was expecting. Thumbs Up
Other than not pinning the throttle back all the time and taking it easy for the first 100 miles, is there anything I should be avoiding whilst wearing the new piston in?
PostPosted: 17:39 - 19 Jul 2011    Post subject: Reply with quote
Cars usually... they seem to make you stop suddenly.
Try not to just hold it at the same RPM for miles, work it a little and tbh, treat it how you normally would, just change the oil after 150 miles and pop fresh stuff in there and you are back to normal Thumbs Up
Christian 2.0
PostPosted: 17:48 - 19 Jul 2011    Post subject: Reply with quote
Cheers Paddy, avoiding cars is one of my favourite pass times. Smile
unitycrippledatmo wrote:
Did they do the valve guides as well?
Don't think so, they didn't mention it. Engine had only done 4k miles anyway when I knackered it, so I'd imagine they were already in pretty good nick.
There is a gap of 3 years, 354 days between these two posts...
badmanrising
PostPosted: 13:41 - 10 Jul 2015    Post subject: Reply with quote
brought bike non runner took carb and top end off and noticed piston had nearly fused with rings expect new pisto needed and part it goes into but what i need to know do i also have to replace top part of head that houses springy things Very Happy they look alright little dark on inside of cover looks like dark oil stain i expect that was to do with inside of piston
badmanrising
PostPosted: 13:42 - 10 Jul 2015    Post subject: Reply with quote
brought bike non runner took carb and top end off and noticed piston had nearly fused with rings expect new pisto needed and part it goes into but what i need to know do i also have to replace top part of head that houses springy things :D they look alright little dark on inside of cover looks like dark oil stain i expect that was to do with inside of piston
spannermonkey...
PostPosted: 20:25 - 14 Jul 2015    Post subject: Reply with quote
Ivor Searle in Soham in Cambs. Charge £25 for a skim on a stripped head and about £41 for a full head rebuild if you can't remove valve gear and for a re hone £25, depending how deep the score is, it could be honed if within limits, so new rings only.
Otherwise new piston and rings I would go 2 sizes over. Don't bother going one size over as your score is probably deeper and you'll waste money. so go .50mm over sized.
It's cheaper to take the engine parts loose.
Take the cylinder with new piston with your piston clearance to a machine shop.
When you strip the head for the skim and barrels, wash it all really well after any work as you will find loads of debris from the machine shop.
Lap your valves in but don't go beyond the valve seat/face limits as per the manual. Otherwise it won't hold compression as good if you exceed this. Replace valve stem oil seals.
You can do a confidence check at home, once you rebuild the head lay it upside down and with the spark plug in. fill the head chamber with a really thin oil and leave to stand. If you loose oil a valve is leaking. I left my cylinder head over night and lost nothing. Just a quick check really.
Use engine oil when you install your rings and piston to reduce any chance if snagging it and will slide better.
Once you put your new head on, your valve clearances will be tight as the valves have recessed into the head, so they will need adjusting.
Then run it in with a mineral oil and don't semi or full types as they have great anti wear properties and a rougher bore will seal better than a smooth one resulting in a better piston ring seal. Run it in until the engine starts to free up as per the book and don't over rev it as you'll undo all your work and wreck the bore.
Good luck. I've just done my old ZX7r top end rebuild in the past many other engines.
Current machines - Aprilia RS250. Kawasaki H1A 500. Past machines - Kawasaki ZX7r P6, Yamaha RD250E (the one that got away), BSA Racing bantam (revs over 10'000 sweet as), Yamaha RXS100, Suzuki GP100, Suzuki GS500K2 - best all year machine ever - come rain, sleet and snow just epic.
trevor saxe-coburg-gotha
PostPosted: 06:01 - 15 Jul 2015    Post subject: Reply with quote
You do know it was bumped five days ago...
The last post was made 11 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 114.71 Kb
