| lozza59 |
 lozza59 Nova Slayer
 Posted: 21:10 - 12 Jul 2011 Post subject: cb125 oil leak, crankcase breather |
hi all
when i first got the bike it would wee all over the path outside the house, came from the same place as it does now, the crankcase breather pipe, also what comes out is oil mixed with a white substance, must be a lot of pressure in there right?
i did a top end rebuild, how would i know if i got the timing right? i mean if i got it a tooth off either way it would still run but with problems right?
another thing i did was i took off the rocker cover and started the bike, the left hand side of the cam with the clip gets great oil supply and the other side seems to just get a drizzle,
i took the rockers off to check the little metal dowel wasnt obstructing it and removed it all together, still the same,
my lack of knowledge is pushing me towards just finding another engine for it. would like the original sorted but that would cost me a fortune im sure. any help appreciated  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:08 - 12 Jul 2011 Post subject: |
The white stuff in the oil is 'mayonase', an emulsion of oil and water.
You get it most often on engines that dont get warmed up properly and only do short runs, from the condensation in the crank case.
Oil should be changed at 1,250 miles, OR every six months, which ever is the sooner..... if bike doesn't do many miles, but gets left to sit, without time based oil changes, condesnation mayo builds up over time.
Also a sign of a head gasket failure.... but only on water cooled engines.
Oil from breather?
Well, have a pair of cases on my kitchen door as I type..... the breather vent is on the top of the gearbox enclosure, and it vents from another chamber forming a 'labertine trap'... basically a convolution of 'path' with a small sump, between the actual crank case and the vent. Sits above the level of gear oil, so that as pistons fall and rise any change in volume can be accomdated by air being sucked into the case, or dispelled, without blowing out any oil....
Older engines vent quite notoceably; often if you have worn or gummed piston rings, causes high crank case pressure from 'blow by' and you also get quite bad oil 'charring' from hot combustion gasses hitting exposed oil.
You have just done top end rebuild..... have you cracked a ring, putting pistons in?
BUT, may be a far simpler reason...
How are you checking the oil?
No idea about the cam journal oil feed... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lozza59 |
 lozza59 Nova Slayer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 00:56 - 14 Jul 2011 Post subject: |
On stick geearing (15T front, 39T Rear Sprox, & standard tyre sized (3.00 front, 3.25 rear)
If you do the maths on quoted rduction ratio's,
At the 12K red line you would get:
33.60 mph from 1st gear
49.43 mph from 2nd gear
64.17 mph from 3rd gear
76.43 mph from 4th gear
85.89 mph from 5th gear
Speedo can over read by anything, but 5mph is typical. And the Tacho's arn't always so accurate, but, ball park isn't far off, though you'll struggle to max out in 4th, and 5th is pretty much an 'over drive' just to knock revs back.
Max power is at 10,500rpm, which givs a top sped of 75.15 in 5th... and it's not far off.
I was running the corporal on 14T front sprocket:
31.36 mph from 1st gear
46.14 mph from 2nd gear
59.89 mph from 3rd gear
71.34 mph from 4th gear
80.16 mph from 5th gear
Gives, 70.15mph at 10,500, in top..... which, is about what I have got out of it, clocked on GPS, but the speedo was off the scale past 80, and the tacho was burried well into the red!
The bike's forte, though is it's mid range. They struggle at the top end, and take a fair bit of winding up to eek that last few mph out of them. The shorter 14T sproket seems to help, mak th gearing a bit more useable.
Critical 50Kph for Mod 1, comes up at 11,500 in first, but you have to be in 2nd or 3rd when you come through the loop; with 15T, its just before 8K, 2nd, or 6K 3rd... With 14T it puts 50K right slap on th red line in 1st, so you really have to use 2nd, when it comes up at just over 8K, or 3rd whn it comes up at 6,5...
Th 'Pup' is also running CG tyre sizes... easier to get decent fitment, for the loss of 1/2" of rubber either end, you can get softr rubber, that's better supported, with less side wall. Gives slighly better handling; steering is lighter and more responsive, from smaller rolling diameter; but slightly lower gearing. Pushed 50Kmh, into the red beyond 12K in 1st, and just undr 8,5 in 2nd, and slap on 6.5 3rd... so we're swapping the 14T onto th Pup for Snowie to do tests on....
The biks dont really have the power to pull the claimd 75mph top speed, under anything but ideal circumstances anyway, and 5th is way over geared for what it can really pull. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lozza59 |
 lozza59 Nova Slayer
 Posted: 01:14 - 14 Jul 2011 Post subject: |
wow unbelieveable!!!
on a 125 too!
amazing little bikes
at one time i thought of getting a cbr 125 motor to see if i could get that in there, still think about it sometimes.. but i would feel as though i might be wrecking the bike, the engine kind of makes it what it is.
i was just shocked when i looked down and saw 40 with it screaming in 2nd. i know none of my other 125cc bikes ever did that, might have pushed 35 in second from a kymco once.
thanks for the info  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 02:16 - 14 Jul 2011 Post subject: |
| lozza59 wrote: | wow unbelieveable!!!
on a 125 too!
Lol! Wrong way around! CB125 Twin into CBR chassis!
Daft thing is, though, the CB125 Super Dream is actually more advanced in many ways than the CBR!
CBR has watr cooled single cyl engine; has four valve pnt roof combustion chamber, but its dsigned for emmission controls not power. CB lump, is over square screamer, and was designed with one thing in mind, proving that Honda could match or better the performance of rivals 'inferior' two strokes.
Full powr CB lump makes 17bhp, which in 1977 when it was launched was as much as the Yamaha RD125 (air cooled) twin, and better than Suzuki's X3. The '82 Super Dream, in UK 'Reduced Effct' dtuned form, matched the Yam RD-LC and Kwak AR-LC's 12.5 Learner Legal BHP... but in full powr Euro version, also matched the 17bhp of the unrstricted Yamaha RD125LC, and the early versions of Kwak AR. Only later RD's and AR's bested it, when they addd power valves.
MANWHILE: CB125 got 'propper' multi link monoshock rear suspension. Kawasaki's AR had thier 'Unitrack' milti link system, but the RD mad do with a simple cantilever..... like the 'cost cut' CBR125 makes do with!
All bikes had 18" wheels, and shard the same tyre sizes. The Kwak had the 'best' chassis, with muti tube back bone chassis. RD had basically a spine frame. But CB got a pressed monococ, which wasn't vaunted, as it was associated with 'cheap' but was actually as stiff as a multi tube around the headstock... and guess what... modern CBR's prssed steel frame, may look like a 'sports' bikes beams, but THAT is actually a production cost cutter!
And CB still has one of the best breaks in the business. Hondas cable operatd discs on early twin shock, and CB100 were roundly slated... supposed to offer more 'feel' they were just crap... so they gave CB advanced twin piston hydraulic gripper, which was much more powerful than single piston breaks on other 125's of the era, and STILL up to standard of modern sports 125's.
Thinking along similar lines.... I was more inclined to think CB twin engine into CBR chassis, but actually probably a retrograde step!
Ultimate CB125, I think would be to take an AJS Regal Raptor DD125 engine.... benley based, but with Regal designed water cooled barel and heads......
And build a water cooled, fuel injected, turbo'd 125 twin... then, what the heck, NSR chassis would b logical for lighter stiffer frame and more rakish geometry, BUT?
Think I'd just nick the wheels and front forks, then add NS125R fairings, for an authntic '80's 'Honda' look..... and decal it out with a livery inspired by the CX650 'Turbo'..... big 'techno' style Turbo legend along the fairing, and plenty of meaningless acronyms!
But.... no.... CB125 is what it is... a damn well concived 'Sporty' 125 four stroke, ROAD BIKE from an age when bikes had to work for a living.... looks boring by today's standards, BUT that's half its appeal.
It was built to work, as an everey day bike, a bike that was easy to ride, as a novice, that was frugal, easily managed, was comfy, could handle longer runs, and provide some fun from more spirited riding.
It was everything people SAY they want in a 125... but people didn't buy them!
They were 'boring'!
The lack of jazzy graphics or fancy fairings failed to inspire. The fluid power delivery, didn't deliver a 'power band' or offer the exitement, or forbidden plasures of easily de restricted power and melted pistons!
More truthfuly, they were just too expensive. And an electric start, like 'big bikes' was little recompens for the extra money, and lack of cudos!
But yes, they are surprisingly spritely.... and get on set up well, and it's not just the engine that imprsses.
I have a habbit of just jumping on bikes and taking them for a trundle, while working on them, to try them out.
Scared myself of 'The Pup' when I snagged my toe on the floor... I was NOT supposed to be doing such stuff in my frigging boating pumps!
And I ride with the ball of my foot on the peg, NOT my heel!
(I'd gone up the road to try out carb set up, and was toe dragging on the roundabout to come back again! It just LEANS!) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 15 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 60.58 Kb
