Who uses the rear brake in the "real world"?!
ace-card
PostPosted: 23:23 - 12 Jul 2011    Post subject: Who uses the rear brake in the "real world"?! Reply with quote
Ok, so I had my first mini scare on my new TCat yesterday, the day I picked her up Rolling Eyes .......went to turn into an industrial estate ENTRANCE, when a car emerged in front of me, exitting Shocked ! On went the front anchor, and what I'm sure was a "bit" of rear (as we are all taught in order to pass our tests!), when suddenly, I felt the rear sliding out slightly Sick Obviously nothing MAJOR as such, as I wasn't going very fast and managed to correct it. In slightly different circumstances however, this could have been bad news, and it got me thinking.......
"if it's that easy to lock up the rear, is it worth using?"
Maybe it's just a matter of getting used to the amount of pressure required for this bike on the rear, taking into account the much better braking capacity in comparison to the CGs drums (that require you to literally stamp on the pedal to get a reaction out it!! Shocked). Although, this never happened to me on the RS, which also had very responsive brakes. When chatting to my step-dad about it (whose an experienced rider on both supersport and large tourer bikes), he told me not to bother using it.
So, what do you guys reckon.....to use or not to use??!!
2007 Skyjet SJ-125, 2001 Aprillia RS125, 1988 Honda CG125, 1997 Yamaha YZF600R
Mama said "life is like a box o' chocolates....have what's nice, then offload the crap to everyone else!" Wink
blurredman
PostPosted: 23:29 - 12 Jul 2011    Post subject: Reply with quote
I use it to stop the squel on my front brake Laughing
In an emergency (people pulling out) I use the front brake which gets their attention my way and that i'm coming.
c_dug
PostPosted: 23:48 - 12 Jul 2011    Post subject: Reply with quote
I use it, if used correctly it will help stop you quicker in almost every situation and helps maintain balance at very slow speeds. If it locks up too easily then to me it says you don't have enough practice using it.
Find an empty car park or bit of road and practice some emergency stops. You'll never replicate the panic reaction of a real life emergency stop, but the more familiar you are with how your bike acts, the better prepared you are to cope with it at the time.
PostPosted: 23:58 - 12 Jul 2011    Post subject: Reply with quote
If you're trying hard enough on a modern sportsbike, you can lock the rear without even touching the rear brake. That's why people fit slipper clutches.
In answer to your question. I use the rear brake a lot, especially for slow riding in traffic.
Teflon-Mike
tl;dr
PostPosted: 00:03 - 13 Jul 2011    Post subject: Reply with quote
Depends on bike & Circumstances.
In 'normal' riding, brakes shouldn't need to be used very hard, very often. 'Perfect' riding would have you arrive at a corner at the correct speed, to tip in, on the throttle alone, and have you maintain a high average speed throughout, hardly using brakes at all.
It's not a perfect world, though, and balencing down changes, a little rear brake can quite nicely keep the chain stretched and the shift smoother, and the bike better balenced, and on junctions and tighter corners, like you might have been tought for cone work for Mod 1, trailing the back brake can help keep the bike settled, as you turn.
Wonderful thing about motorcycles, is the dynamics, and the amount of rider input and subtle input you can use to effect control over the bike, in different circumstances... to say 'never' whether the front brake or back brake, or counter steering, counter leaning, hanging off, peg loading, or any other 'technique' would be to chuck away what can be a very useful tool in the armory.....
some tools are a lot more use than others though, and things like knee dragging, is something most often done purely becouse racers do it, rather than any real practical benefit, and counter leaning, is a tool that I get argued down over its merit time and time again..... BUT, they are both tools, and pretty specialised ones....
USING THE BRAKES... however is one of the fundementals, and takes up a large chunk of CBT..... and before trying to employ more elevated techniques like ahead leaning or hanging off, learning how to exploit the control offered by brakes, is a pretty good skill to master..... NOT using the brakes, is an even better skill to aquire... which is very different to simply 'ignoring' one or other brake....
Old Git Racing
PostPosted: 01:15 - 13 Jul 2011    Post subject: Reply with quote
In the 'real world' not very often. As T Mike says you shouldn't get to the point where you need it, but invariably you will sometime. As for its value as a retarding device in a panic braking situation I'd say it was next to useless or even possibly dangerous if you have any sort of lean angle on due to the lack of force being applied through the tyre, because all the weight is transferred to the front wheel.
In the 'not real world' you can use it to set up the bike for corners or control the front coming up too far without having to get off the gas.
I once did three races on the TZ with no pads in the back (long story why not) without knowing, Good job I never used it eh. Rolling Eyes
OGR
temeluchus
PostPosted: 01:38 - 13 Jul 2011    Post subject: Reply with quote
My k75 will happily slow down and stop from speed only on the back brake.
Dazbo666
PostPosted: 06:28 - 13 Jul 2011    Post subject: Re: Who uses the rear brake in the "real world"?! Reply with quote
ace-card wrote:
.....went to turn into an industrial estate ENTRANCE, when a car emerged in front of me, exitting....
Assume a healthy sense of paranoia. Also assume ALL other road users are inconsiderate bumbling idiots, and an alarming amount of the time you'll be correct
ace-card wrote:
"if it's that easy to lock up the rear...
...put this one down to inexperience with the bike, although planning a little further ahead, and keeping the speed down... Thumbs Up
ace-card wrote:
....When chatting to my step-dad about it (whose an experienced rider on both supersport and large tourer bikes), he told me not to bother using it....
If your step-dad chooses to adapt his riding style, and not to use his rear brake, then that's his choice and it's up to him, but in my opinion for him to tell you not to use it is somewhat irresponsible
Word of the day : DILLIGAF
YourMumRang
PostPosted: 06:42 - 13 Jul 2011    Post subject: Reply with quote
This is news to me! I do it like they told me on the cbt. 90% rear brake 10% front.
Barely ever use my front.
Interesting.
95Theses
PostPosted: 06:51 - 13 Jul 2011    Post subject: Reply with quote
Interesting.
Shocked
I think you heard that wrong or misunderstood, they teach you the other way round. Front brake for stopping, back brake for control at low speed.
Think about it, when you brake the weigh transfers forwards, meaning the front tyre bites into the road more giving more grip and the rear tyre lifts up giving much less grip.
Dazbo666
PostPosted: 06:58 - 13 Jul 2011    Post subject: Reply with quote
Interesting.
Your instructor told you to use 90% rear brake on your CBT??? Shocked
That would drastically increase your chances of locking the rear, and unless the test conditions have dramatically changed over the last 5-6 years, that would've meant a test failure.
For the record my DAS instructor taught 50% front, 50% rear in the dry, but more like 60F/40R or even 70F/30R in the wet Thumbs Up
PostPosted: 07:05 - 13 Jul 2011    Post subject: Reply with quote
Thats because you were doing slow speed stuff in a car park. You're told not to use the front brake until you do the emergency stop. The recommendation is rear brake only for speeds of up to 10MPH and anything over that use the front to scrub off speed
Your instructor either got it the wrong way around or you did. 70% front and 30% rear in the dry and about 50/50 in the wet.
On a side note. I've never locked up the rear wheel. The rear brake just isnt strong enough on a big bike unless you hammer the brake down.
Nexus Icon
PostPosted: 07:07 - 13 Jul 2011    Post subject: Reply with quote
I use it all the time, I imagine. To be honest, I don't over-think exactly how I use the brakes, I just use them and stop. It's a bit like the whole counter-steering discussion; if you spend time thinking about it all you're probably going to f*ck it up anyway.
In a real emergency situation I'm certainly not going to be thinking, "Right, front brake heavy plus a little back brake now to balance... Ooh, too much, try a bit less... Yep, perfect, perfect, I'm slowing nicely..."
Bang!
Greetings from Shitsville!
DrDonnyBrago
PostPosted: 07:12 - 13 Jul 2011    Post subject: Reply with quote
I use it every day.
Slowing down quick - use a bit of rear brake, even more so in the wet. I drag the rear brake at low speed to keep it stable, use it on hill starts and when waiting at crossings etc where I know i'll be going soon.
Nexus - that is why it is a good idea to practice emergency stops, so that you don't need to think about them and you can do them properly if you need to rely on it in a critical moment.
Slacker24seve...
PostPosted: 07:13 - 13 Jul 2011    Post subject: Reply with quote
I've never locked it unintentionally. I use mine all the time in slow traffic and if I've gone into a left-hander too quickly.
You should be able to change the angle of the pedal so it's nigh on impossible to lock it. Try that Thumbs Up
Banger rallies are ace
garth
PostPosted: 07:17 - 13 Jul 2011    Post subject: Reply with quote
On the track not at all, last time out my back brake didn't have a master cylinder or fluid. (It spat it over my tyre so I took it off)
On the road I use it quite alot though, slow speed stuff, arsing about and town work.
Musketeer
PostPosted: 07:19 - 13 Jul 2011    Post subject: Reply with quote
I use rear brake a lot.. especially in winter or wet Cool
YourMumRang
Well my instructor was a right cunt who shouted at the other lad with me for no real reason so this doesn't suprise me.
I'll get practicing my front brake asap.
Seb
PostPosted: 07:32 - 13 Jul 2011    Post subject: Reply with quote
As above, rear brake = control and balance rather than actually slowing down for the most part, does depend on the bike though, some big twins have so much engine braking that your not far off locking the rear before you even go near the brake Smile
2010 Triumph 1050 Sprint ST
easyroller
PostPosted: 07:41 - 13 Jul 2011    Post subject: Reply with quote
^ This.
Plus I make sure to give it a light tap or two when I'm just using engine braking to slow down in order to let the cagers behind me know I'm slowing down!
....unrestricted and on two wheels since '04
Daimo
PostPosted: 07:46 - 13 Jul 2011    Post subject: Reply with quote
Every day.
Rear brakes good on the bandit, so use that when coming into 6th gear chicanes (roundabouts).
Also use the rear on hard braking for that little extra force.
Also use the rear when balancing at traffic lights.
Dazbo666
PostPosted: 07:50 - 13 Jul 2011    Post subject: Reply with quote
Dazbo666 wrote:
For the record my DAS instructor taught 50% front, 50% rear in the wet, but more like 60F/40R or even 70F/30R in the dry Thumbs Up
Shocked edited for accuracy. My mistake Embarassed my instructor and pinkyfloyd are correct.
For the record, I can only remember locking the rear twice in 6 years. Once was a genuine emergency stop, and one was thru pure inexperience/riding like a twat
I can't understand people who say "I never use the rear brake". It doesn't unsettle the bike in the same way that the front does, and it is useful for hill starts, entering a corner, approaching junctions etc. Obviously in a situation like the one you describe I'd be on the front as hard as I could and I'd probably just give the smallest dab of rear (considering my bike is very short wheelbase and will lift the rear easily). Still, I do use the rear all the time.
shereen
PostPosted: 07:58 - 13 Jul 2011    Post subject: Reply with quote
When it is dry out I use the front only. If the road is damp or if its raining I will use front and rear. Like 70% front 30% rear.
To be honest it varies from one bike to another how much front and how much rear you need to use and obviously depends on what the conditions are outside. As someone has already suggested, go and practice in a car park, you will soon know how much rear you can apply without locking the wheel up. I think you just need to get a better feel of your brakes.
sickpup
Old Timer
PostPosted: 08:09 - 13 Jul 2011    Post subject: Reply with quote
Mick Doohan in an interview wiyh PB once said 'only wankers don't use the rear brake'.
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 139.1 Kb
