Honda CBX 550 - leaking carb, how much should I pay garage?
Uzi2491
PostPosted: 19:49 - 11 Jul 2011    Post subject: Honda CBX 550 - leaking carb, how much should I pay garage? Reply with quote
Hi there,
Recently I bought a 1982 Honda CBX 550 F2 for £250 - the seller told me it would go with a bump start which it did not (the engine would turn over but not start).
I'm not so good with bikes (yet!) so took it to the garage. Their diagnosis: a leaking carb and a bust starter motor. The cost to replace / repair will be quoted to me tomorrow.
I just want to know what you think is a reasonable price for this job? Can I save by trying to find a starter motor elsewhere etc.?
Cheers, advice really appreciated! Smile Question
MickC
PostPosted: 20:14 - 11 Jul 2011    Post subject: Reply with quote
Get a manual and do it yourself!
Seriously you are far better learning these things the price of a couple of hours labour would cover the cost of bits you need. A second hand starter (if it is buggered) will cost you £25-50 tops, gasket sets for your carbs will be around £10 a carb - you only need to repair the duff one. The leak could simply be a stuck float or general crud blocking something up (remove the float chamber and clean it out). There are a lot of very savvy people on here that will give you all the help you need. Also once a garage gets hold of it they can tell you anything and you can end up paying an arm and a leg for things that only cost pounds to put right. I myself have an early 80's honda and the only time i took to a garage the screwed it up big time! A lot of mechanics these days rely on diagnostic equipment to tell them whats wrong, which these older bikes don't use.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Uzi2491
PostPosted: 20:21 - 11 Jul 2011    Post subject: Reply with quote
Thanks for that Mick - I may well have a go at doing it but I've got a lot to learn. I've got very little experience with things like this actually.
Just one thing - where should I go to look for a starter motor? I tried eBay but the one I found has been sold now.
Cheers.
MickC
PostPosted: 20:30 - 11 Jul 2011    Post subject: Reply with quote
Here is a link to a breaker search engine
https://www.bike-breakers.info/
Also for finding part numbers (if you need or want to buy new stuff):
https://www.cmsnl.com/
But don't buy them from there just get the part numbers then go to:
https://www.davidsilverspares.co.uk/home/
they are a lot cheaper!
And I'm sure some of the other people on here will chip in info to help you.
XX XXXx
Teflon-Mike
tl;dr
PostPosted: 01:24 - 12 Jul 2011    Post subject: Reply with quote
A Non Running £250 CBX550....
Have you done any research on these things?
They had a tendancy to snap cam chains & eat thier own cam chain tensioner mechanism, withing 10,ooo miles.
Commin 'Fix' was a 'soft link' cam chain, threaded in from the rocker cover, if you managed to catch the rattle before it became terminal, at which point sixteen very tiny valves often got mangled.
The 'soft' link cam chains often didn't even last the 10K of the OE item.
I would NOT spend a penny...... (on a CBX550, full stop, probably!)... until I had taken the cam cover off, and made sure it has a cam chain, and that its actually tight on the sprokets, and turned the motor over watching valves open and close, and done a compression test.......
That done, I'd look at the carbs first. CV carbs were prone to the diagphrams perishing... actually one of the easier things to 'fix' on a CBX550, overhauling carbs......
Not sure what prices are like on the diagprams and mounting rubbers these days though....
MEANWHILE... little point doing anything seriouse with the engine, unless you have a garanteed 'home' for it.
The CBX550 had a wampy 'inboard disk' brake... very advanced for its day.... read, overly complicated..... and utterly unserviceable!
Hondas are renouned for siezing floating brake calipers, now take a pair of them, turn them inside out and back to front, and slap them inside the hub inside the middle of teh wheel, out of sight, out of mind, until they either start grating, as the pads have gone, or binding becouse they have siezed.... THEN add another over complication in the mechanically linked 'Trac' anti dive mechanism to stiffen fork damping under braking......
At the back you then have the vaunted Uni-Trak multi-link suspension... great system, but again often neglected, and expensive to overhaul.... and another inboard bludy disc brake!
A well fettled CBX550 is a very sweet little bike; and with 75bhp, it was one of the the most powerful air cooled fours of its era. I hink that there are only about half a dozen Honda Air Cooled fours that are actually more powerful, CB900, CBX750, and the CB1100... my '93 CB750 'Retro' had 'detuned' CBX engine, and I think is actually LESS powerful than the 550 lump!
In it's day, it was a very potent tool, and had the power and handling to stay with the early Kawasaki GPz600R's, and could actually outpace the early 'jelly-mould' CBR600, which was no more powerful, and a feck sight heavier....
But it was a fragile beast, and mechanics nightmare.....
And at £250, 'now'... well, back in 1989, I was GIVEN a 1982 CBX550... a seven year old bike..... when second hand middleweights were in short supply, and commanded very high prices..... they were THAT notoriouse! Bike was a 'runner' too; It had had a full overhaul, 'doing' those stupid bludy brakes, just before the cam chain went... demanding a full engine rebuild, before it was submitted for MOT, and failed on fork seals, at which point bloke had just had enough, looked at the Track System, cried a little, and handed me the keys!
If you are not a clued up mechanic, and possibly even if you are.... I am a pretty competent mechanic, and idea of contending with another CBX, REALLY daunts me.... I'd NOT get carried away, with it, I would not spend money on it, until I had the whole thing in bits, and was SURE I could make something worth while out of it.
PAYING mechanics to work on a CBX550?
Get the bancrupsy forms now mate'; thing will be a complete money pit, unless you can DIY it!
Changing the brake pads is likely to be a days labour! And more then the bike's worth, if you pay a pro!
Punt it back out on Ebay; break for bits, or simply write off as a bad mistake.
As a Novice Mechanics machine, there's really only a couple WORSE bikes you could have picked! They are a real nightmare to work on.
temeluchus
PostPosted: 18:34 - 12 Jul 2011    Post subject: Reply with quote
Haven't you read the propaganda? Hondas are all perfect, well finished and utterly reliable!
Teflon-Mike
tl;dr
PostPosted: 20:10 - 12 Jul 2011    Post subject: Reply with quote
When the CBX550 was built, there was no such propaganda; they were still overly complicated 'rice burners' no one expected to last.... and they didn't!
Ironically, the bikes haven't ACTUALLY got much more durable, but expectations have diminished, as bikes have changed in nature from every day road vehicles to fasion oriented leisure implements, how long they are expected to last has reduced.
Honda had a poor reputation for the fragility of thier cam drives, on the SOHC 'fours'... the DOHC fours didn't enhance it any.... The quad cam V-4's blew it completely.
Honda's 1984 VF750F nearly broke the company with the warranty claims it generated. It was only the strength of the yen, and the success of the Civic car, that gave them the corporate muscle to ride that one out, and use the expensive expedience of gear driven cams, to over come the problem, and start rebuilding a tattered reputation. The 1985 VF1000R, was the first bike to use GDC, the VFR750 the bike that was supposed to wrestle back the rep....
But it was the GDC 'Jelly Mold' CBR's, water cooled in line fours, that were Honda's "Humble Pie"....
In 1983, they said the 'future' was the V4, a water cooled IL4 would be too wide, and Air Cooled IL4's were already critasised for that.... GPz600R proved them wrong.... so they copied it, added gear cams, and hid the whole lot in fully enclosed plastic, inspired by Ducati.... and ironically the CBR600 was the bike that the propaganda is based on having gone on to be the most popular modern motorcycle over 250cc....
Ironically, they re introduced chain driven cams not long ago.....
curiousely, as these bikes have started reaching middle age, and the middle market, people are reporting the old Honda Cam Chain knock again!
What goes around.....
HOWEVER.... you do have to give teh CBX credit for fit and finish, it was beutifully engineered and well finished.... they were always the best looking bikes in the breakers!
Even when they weren't a clear dacade newer than the bikes sat next to them, having been wheeled in with their head removed, after an astronomical quite to repair the valve damage after the cam chain went, before their first MOT!
temeluchus
PostPosted: 21:06 - 12 Jul 2011    Post subject: Reply with quote
I'm well aware of that oh wise one. Google "levity". :-p
I had the misfortune of owning a vf750, and trying to resurrect a mates dead cb650.
The vf750 was by far the worst bike I have ever owned. The irony is the gearboxes explode more often than the top end does, provided the ignitors don't give out first.
The cb650 has a number of interesting design choices that make the engine an utter pig to work on for no readily apparent reason. Someone in the honda design dept was sniffing paint thinners when they thought up that engine.
jjdugen
PostPosted: 00:24 - 13 Jul 2011    Post subject: Reply with quote
Never, ever take a cb 6 cyl apart, it never works properly again.
PostPosted: 12:03 - 13 Jul 2011    Post subject: Reply with quote
I'm sure he'll remember that on the slim chance he ever buys one.
temeluchus
PostPosted: 18:16 - 13 Jul 2011    Post subject: Reply with quote
rice burner in my experience, is a derogatory term for japanese bikes in general, usually from harley owners.
Does that make my beemer a wurst burner?
Teflon-Mike
tl;dr
PostPosted: 03:07 - 14 Jul 2011    Post subject: Reply with quote
Vincent wrote:
It's an American phrase from the late 60s/70s which I don't remember anyone here in the UK actualy using
(Shhhhhh I don't admit this very often!) I'm 1/2 Canadian. Spent about 1/4 my teen years there.
Mantra, was as often as not, "If it ent Harleee, it Ent SHY-TE"
To which I more often replied, in the John Cleese accent the colonials so appreciated, "You're not wrong there!" delighting in the irony of the double negatives!
"Jap-Crap" was more often used in the UK...
And due to a nervous elaboration, it's actually taken me all day to remember that!
But then same abortion, had me, with my head under the kitchen side, behind the washing machine, holding a leaking hose, waving my free arm around, stuttering, and yelling incoherently at Snowie, words like; "Petcock" or "Valve" or just "Blue THING" while she looked on, bewildered, until, thoroughly soaked, the word 'TAP" after conceiving not just various different forms, but also imagining the blue prints of their internal workings, eventually found its way into my grasp!
The last post was made 15 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 100.15 Kb
