Patent, how does it work?
0l0dom0l0
PostPosted: 23:55 - 10 Jul 2011    Post subject: Patent, how does it work? Reply with quote
So, I've had an idea for something but it uses already found technology. The technology in question is the re-use able hand warmer pouches, the ones you click the little bit of metal and a chemical reaction sets off making them produce heat. I want to adapt the idea for something else.
How would I go about getting the rights to use this technology?
As an example, it's like me wanting to create a new type of hoover using the bag-less Dyson technology. In order to do that I would need to get the rights of Dyson to use their technology. How would I go about this?
Help is much appreciated Karma
PostPosted: 14:34 - 11 Jul 2011    Post subject: Re: Patent, how does it work? Reply with quote
Are you sure they're still in patent?
Seen a few different types of them around from plenty of different sources - ie ones for boots etc.
Im-a-Ridah
PostPosted: 15:32 - 11 Jul 2011    Post subject: Re: Patent, how does it work? Reply with quote
You can't use their technology unless you pay them royalties. If you can't afford to pay whatever they demand, then you can't use it. If you want to use it, then you need to negotiate a contract with them (probably going to cost you a fair bit). That said, they will probably say no, since there is little reason to create competition for themselves. Also, even if you have a patent, if you can't afford to fight a potentially very expensive court battle, then it's worthless protection really. If the company has vast amounts of resources to fight the battle, and you don't, then you risk losing everything and they are risking little at all.
Also, are you sure your idea is actually patentable? Have you checked against the requirements for one?
Bru
PostPosted: 20:26 - 13 Jul 2011    Post subject: Reply with quote
This site allows you to search for patents, although it is certainly not exhaustive:
https://gb.espacenet.com/search97cgi/s97_cgi.exe?Action=FormGen&Template=/gb/en/home.hts
With regard to your idea, apart from the obvious of not disclosing it publically, be aware that:
the idea must be novel, and not obvious (eg. 7-spoke alloys because you have never seen more than six...)
the application can be novel. Dyson did not invent the bagless technology - he took it from industrial separators (see his website). In this example, you would not need to licence the technology from Dyson, unless you attempted to build a vacuum cleaner (although I am sure they have attempted to close similar options).
An application is not expensive, but not guaranteed to be granted. Also, don't shoot your bolt too soon - if a patent is granted, and you are not prepared to exploit it, then that time is wasted.
colin1
Captain Safety
PostPosted: 21:04 - 13 Jul 2011    Post subject: Re: Patent, how does it work? Reply with quote
I don't think concepts like bag-less vacuum cleaner are patented, it's more the designs that get it to work. So designing your own bag less vacuum would be fine, but reverse engineering your own, by taking apart their design and copying it would not.
Having said that, even there I think it can be done, if you know the specific legalities of what you can and can't copy.
Itchy on here works for Bentley which is part of VW. His specialism is metrology which is about measuring things, and I think a major application of that, is taking apart your competitors product, and examing it closely, possibly reversing engineering, so you can work out a way to copy it legally, or at least understand what they are up to.
I think using those handwarmers, in a novel way, may actually be a great way of reducing costs of bringing a new product to market. As if you can use off the shelf components that are already used for something else, you don't have to develop them yourself.
I'm sure the hand warmer manufacturers would be happy to sell you the contents and clickers in bulk, and maybe even make the size of containers you want. What I dont know is how you would go about defining a patent, so they cant then copy your idea and cut out the middleman (ie you).
PostPosted: 22:14 - 13 Jul 2011    Post subject: Reply with quote
Just do it. They'll only come after you if you're successful.
Frost
PostPosted: 23:08 - 13 Jul 2011    Post subject: Reply with quote
Whatever it is make it, or do it. If it's successful them you can worry about negotiating payment. If it's a flop you've wasted no time. If it's successful but not profitable you can always lie about that and offer to sell the derivative invention to the holder of the original patent Wink
0l0dom0l0
PostPosted: 01:17 - 14 Jul 2011    Post subject: Reply with quote
Some good thoughts here people thank you!
I've had a serious think about this and how I could create something in the long run. It's looking good Very Happy.
I did post a reply but for some reason it hasn't worked. I've had a re-think and I'm going for an electrical heat instead as I don't think I'll get enough heat from the warmers.
That patent site is awsome. Best bit though, my ideas not on there Very Happy.
Going to get cracking I think!
DrDonnyBrago
PostPosted: 11:53 - 14 Jul 2011    Post subject: Reply with quote
Those hand warmers that click are a pain in the cock to reuse too, they need to be boiled for some time. If it is a motorcycle clothing based application then taking them out and boiling them every night would quickly get boring, they are also quite bulky when they have been activated. Electric/battery powered is probably a better bet for most things I can think of that you might want to warm up.
Will be interested to know what you are up to when the time is right Thumbs Up .
0l0dom0l0
PostPosted: 13:11 - 14 Jul 2011    Post subject: Reply with quote
I was initially concerned as I didn't think I would be able to get a battery that was small ish, would hold enough juice and be cheap enough but it turns out I can quite easily.
It's not motorcycle related sadly although maybe I'll give that a go in future Very Happy.
DrDonnyBrago
PostPosted: 14:32 - 14 Jul 2011    Post subject: Reply with quote
I'm intrigued, what needs to be small and warm?
The only things that come to mind are love eggs and nose warmers Surprised . When you have your patent, I want to know what it is Wink .
PostPosted: 15:13 - 14 Jul 2011    Post subject: Reply with quote
Cock warmers?
Just me then?
The last post was made 15 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.37 - MySQL Queries: 13 - Page Size: 78.12 Kb
