CG125 W No spark , Help!
UpcomingChris
PostPosted: 20:20 - 13 Jul 2011    Post subject: CG125 W No spark , Help! Reply with quote
So i have a CG125, One day it was fine, Put it away, GOt it out about 2-3 weeks later, Wouldn't start, Had a ifddle with it and found out there appears to be no spark, Will do more tests on the spark tomorrow.
Battery is fine, Fuse is fine, I'm thinking it could be the HT Lead or the Coil?, If so how would i check either one?, i'm no mechanic, Please help!
sandman1976
PostPosted: 20:36 - 13 Jul 2011    Post subject: Reply with quote
Have you changed the spark plug?
Unscrew the spark plug cap off the ht lead and put it somewhere near the frame/engine and see if you get an electrical arc.
use an electrical tester and see if there is a pulse to the coil, earth one lead of the tester to the frame and touch the other to the input terminal of the coil, turn the engine over and you should get a pulse signal, if you do its the coil, if you dont its at the cdi OR points area.
UpcomingChris
PostPosted: 22:38 - 13 Jul 2011    Post subject: Reply with quote
Yeah it's a brand new plug, I've tried testing it like you said and there is no spark
"input terminal of the coil", Would i need to take the Tank off to get to this?, I think it's hidden under the tank., If it's the CDI what does this mean?
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 35.81 Kb
