| jimspeed |
 jimspeed World Chat Champion
 Posted: 21:52 - 14 Jul 2011 Post subject: Low compression, or do I? |
Ok bear with me I'm used to nice simple car engines..
In my quest to get this GPZ400R running right I have compression tested it , I only have the 500r manual but am thinking its not going to be far different.
I got with a hot motor and open throttles
70 psi across all of them
now the manual states that the 500 should be between 105-145psi at 500RPM
I'm guessing that the starter is not going to give that sort or rpm tho?
they are all the same and oil does not effect the readings,
she runs really nice now on light throttle but still will not go on anything over 1/4 throttle just runs at 4k with the throttle wide open .
I'm thinking that the cams may be different in the 400r to the 500r which may give a lower copmression reading (in cars if you fit a "race cam" you often find the compression readings get lower due to bigger overlap etc).
starts on the button and runs tidy even from stone cold which is kinda making me think the compression is ok  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Frost |
 Frost World Chat Champion
| jimspeed |
| Ariel Badger |
 Ariel Badger Super Spammer
| jimspeed |
 Posted: 22:53 - 14 Jul 2011 Post subject: |
throttle wide open, car battery connected as the bike one is dead and I'm not buying one till I know it is fine,
it really does run too well to be that far down on compression tho (most modern car engines will missfire with 100psi, VW's suffer sticky valves done loads now)
Thinking alout it has to be too lean on the mains somehow (can't see any no's on the jets or adjustment on the needles) she revs if I "flood" all 4 carbs , I'll vid it tomorrow  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
| jimspeed |
| Frost |
| timsmith |
 timsmith Two Stroke Sniffer
| jimspeed |
| TQ |
 TQ Trackday Trickster
| Frost |
| jimspeed |
 Posted: 21:24 - 18 Jul 2011 Post subject: |
sod it its going on ebay as it is I really wanted to get it running nice first and mot'd but I don't really have the time to spend on her,
carbs are clean and balanced ,the floats are spot on and i've fixed everything else that was wrong with it so just going to put the tank and panels back on and stick on the bay (I may just try it to see if its any better under load tho).
If anyone fancy's a cheap GPZ mail me  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
| prawny1 |
 prawny1 World Chat Champion
| jimspeed |
 Posted: 22:22 - 18 Jul 2011 Post subject: |
Tried both the airbox on and off mate, But the airbox has a broken top and I think this may not be helping. I have found someone who has a top and its on its way to me now then I'm going to try it up the road and see if its any better or not.
The last post was made 15 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
