buying a 2003 SV650 - what to look out for?
mealies
PostPosted: 11:46 - 14 Jul 2011    Post subject: buying a 2003 SV650 - what to look out for? Reply with quote
Having just sold my trusty ybr125, I am hopefully buying a 2003 SV650 this weekend. Not knowing too much about these bikes I need some advice on what to look out for.
The price is ~£1500. it's done 31,000 miles. 2 previous owners. Its been used all year round. Looks in very good condition apart from the engine cover which has some paint flaking off. The tyres are bridgestone bt-021 and look fairly new.
What else should i check/look out for?
Andrew
PostPosted: 11:54 - 14 Jul 2011    Post subject: Reply with quote
Google a review of the tyres...
Thats more mileage than my GSXR750...and thats high mileage to me Laughing
Good little bikes, personally I would have gone wth something different, I found it boring.
Check the rear suspension for excessive corrosion and wear.
truslack
PostPosted: 11:56 - 14 Jul 2011    Post subject: Reply with quote
Head bearings, wheel bearings, swingarm bearings, check for smoke from exhaust, fork seals, sprocket condition (especially front sprocket, you may need a torch and it can be awkward to see). If it has service history then check when the valve clearances were last inspected/changed.
All the usual things to look for when buying any new bike really.
mealies
PostPosted: 12:21 - 14 Jul 2011    Post subject: Reply with quote
not sure what you mean about the tyres as i know nothing about them but reviews seem to be ok.
cool as long as the usual checks will suffice i should be fine then. Already checked the bike out once and am pretty happy with it - but will check again when i buy it
huskie69
PostPosted: 13:04 - 15 Jul 2011    Post subject: Reply with quote
My '53 plate was bought at 34k miles (notched up another 5k in the last 3 months on it!).
I had to have the cam chains and tensioners replaced in the first month so listen out for a rattle when its fired up (will probably sound like it's coming from underneath the petrol tank). If there is one, stay away unless you don't mind spending another 600 squids on it!
Also got a very sticky lock barrel. Not sure if it's just mine or whther it's a common problem.
I think if you head over to sv650.org, there's a pages listing all known common problems.
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
PostPosted: 13:19 - 15 Jul 2011    Post subject: Reply with quote
https://www.reviewcentre.com/reviews158255.html
I found them to be...fairly wank at best Thumbs Up
ThoughtContro...
PostPosted: 13:25 - 15 Jul 2011    Post subject: Reply with quote
Did the tensioners really need replacing, did they just need freeing up, or did you hear the tic tic and let some garage talk you into the work.
K3's had an improved cct, compared to the old mk1s, which are poo. In fact they're the recommended replacement for em.
Don't believe me? Search "cam chain noise" over at forums.sv650.org, and you can do a fair bit of thread reading
Prize cunt
huskie69
PostPosted: 13:37 - 15 Jul 2011    Post subject: Reply with quote
I got the chains and CCTs back from the mechanic after the job and the chains did appear worn. I would have replaced the ccts myself but I couldn't get at them Sad Even a bikey mate of mine couldn't get to them so I had to get the garage to replace them. The chains only cost £80 - it was the labour that cost a fortune - almost £400.
PostPosted: 14:07 - 15 Jul 2011    Post subject: Reply with quote
Bit paranoid aren't you Laughing Wouldnt have bothered with the chains personally..
herulach
PostPosted: 15:01 - 15 Jul 2011    Post subject: Reply with quote
I'd second the fact that BT021s are a bit wank, the fazer had a new pair on at 23k when I brought it, rear needed changing (square as a square thing) at about 27.5k and front is getting that way now (just over 30k) can't see it lasting much more than another 500 or so miles before it starts pissing me off enough to change it. (Riding is c. 70% motorway commuting) Certainly wouldn't get another pair.
YBR 125>FZS600
Souleh
PostPosted: 15:11 - 15 Jul 2011    Post subject: Reply with quote
Think the SV's are usually a reliable wee bike so just usual new bike checks;
Bearings
Brakes seized / Pad life / Fluid colour
Chain sprocket life
Fork seals
throttle and clutch cables are smooth etc
Tyre life
Clanger
Stirrer
PostPosted: 21:31 - 15 Jul 2011    Post subject: Reply with quote
They are notorious for rust on both front yokes, rear torque arm, exhaust downpipes, all engine bolts, and the front forks. I would hope that the forks have already been upgraded (oil and progressive springs because they were notoriously springy).
Hopefully the previous owner would have replaced most of the dodgy items, I think the curvey naked was the best one going. But then I am biased. Wink
Flip
PostPosted: 23:46 - 15 Jul 2011    Post subject: Reply with quote
What to look out for?
If it has the digits S. V. 6.5 and 0 on it. Walk away. Razz
hornetmike
PostPosted: 23:50 - 15 Jul 2011    Post subject: Reply with quote
Honda Hornet
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
PostPosted: 00:56 - 16 Jul 2011    Post subject: Reply with quote
Mine's sat outside for the last few months and there's no sign of rust on it...? Neutral
mealies
PostPosted: 16:24 - 18 Jul 2011    Post subject: Reply with quote
After a manic weekend just thought i would post an update on this.
Got the bike Sunday as i was happy with it's condition. The ride back was a lot of fun, apart from the last 5 miles. i had managed to sprain my wrist and fracture my thumb way back on the day of my mod1. Whilst it has healed it's the first time i have got on a bike after the splint was off so it was ruddy painful towards the end. So until its strong enough no commuting in on the bike Sad
To end on a positive note rang the insurer to amend my existing policy from the 125 and no change in premium. Result!
ThoughtContro...
PostPosted: 16:35 - 18 Jul 2011    Post subject: Reply with quote
Cool as. Your post is missing some pics tho Razz
Prize cunt
The last post was made 15 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 94.42 Kb
