Choke Problem !!!!
Bike Jockey
PostPosted: 00:00 - 17 Jul 2011    Post subject: Choke Problem !!!! Reply with quote
when starting from cold full choke only speeds up engine speed to around 1500rpm but when choke is pushed off slightly to about half way engine revs go up to around 3500rpm, after a couple of mins once warm and choke is backed off engine runs ok ish but with slight popping can be heard and tickover is 900/1000rpm up and down, if you twist throttle engine will miss slightly and if you keep blipping the gas it will stutter and then backfire also smells quite rich on the exhaust gasses.
Also at slow speed in first gear its hard to maintain a steady speed
Any one got any info on this
Thanks
temeluchus
PostPosted: 05:16 - 17 Jul 2011    Post subject: Reply with quote
Youd have better luck in the workshop section *facepalm*
Drain all the float bowls (look for little bolts sticking out the side of the bottom of the carbs). Probably water in there.
Summat like this, youll need to do all 4 on your blandit.
https://rickramsey.net/CRF230Flg/Carb30.jpg
olionel
PostPosted: 10:30 - 19 Jul 2011    Post subject: Reply with quote
could it just be your plungers sticking? take em out look at the springs etc.
1989 CG125 - Childhood Sweetheart (she got kidnapped by baddies)
1998 ZXR400 - Teenage Love (lasted three years, then she turned lesbian and left me)
2001 XRV750 - Wife Material (still getting to know her but head over heels in love)
The last post was made 15 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 35.86 Kb
