dt 125 indicator/hazards problems???
P3TR0L H34D
PostPosted: 13:02 - 17 Jul 2011    Post subject: dt 125 indicator/hazards problems??? Reply with quote
Im back again with more dt issues lol. I have found that my indicators work fine until I try to put the hazards on lol
If I switch my hazards on all indicators do a quick half blink, then nothing! Its like they are tripping out, then when I try my turn switch nothing happens. Then what I have to do is press the middle (off/reset) button 3 or 4 times and they work again, until I try my hazards and it repeats the same cycle. MOT time is near and Im out of ideas!!
I have traced the wires back to the coupler for the left hand switch and all indicator wires. I have found that one side is dark green + black and the other is brown and black. If I unplug the brown or dark green, it knocks out the relevant side but the side that remains working suddenly works for the hazards. This is the same for both sides. So I can have L indicators and hazards or R indicators and hazards, or L & R indicators with no hazards!!!!
Not sure if it makes any difference to working out what is wrong, but first off I have fixed the clutch switch problem. What that was doing was the same thing but when the clutch switch was activated as the clutch engaged. It would also 'trip' the indicator system and the middle would have to be pushed 3 or 4 times to reset. The way I found solved this was to unplug the clutch switch coupler and it is fixed.
Has anyone got any suggestions as to why this is? (on a side note I don't currently own a multimeter) THANKS in advance
finpos
PostPosted: 13:27 - 17 Jul 2011    Post subject: Reply with quote
Most likely explanation is that your battery is not as clever as it once was and can't supply enough current to operate 4 bulbs plus the flasher unit.
f.
P3TR0L H34D
PostPosted: 14:07 - 17 Jul 2011    Post subject: Reply with quote
Thanks Finpos, but my battery is new Sad , although may not be fully charged so I'll try that. Only thing is it still has this problem with the engine running???
finpos
PostPosted: 19:08 - 17 Jul 2011    Post subject: Reply with quote
Easiest way to find out is to use a car battery - otherwise charge the one you have. Engine running will only help at rpm over approx 5000 (i.e. Not at idle)
F.
P3TR0L H34D
PostPosted: 20:01 - 17 Jul 2011    Post subject: Reply with quote
Still didnt work with a charged battery.....bugger Sad
First ever bike - 1980's Honda XL 250 (Offroad), 2004 KTM SX 125 Rattray Edition, 2004 Yamaha DT125RE, 2006 Husky WRE 125, Speedshite 100, Current- Car....... Sad
The last post was made 15 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 43.62 Kb
