Ignition barrel stuck?
skatefreak
PostPosted: 20:10 - 17 Jul 2011    Post subject: Ignition barrel stuck? Reply with quote
Hey all.
So the kymco stryker has gone to a friend to get him through his test but he's gone and lost the only key for the bike...
We know a chap who says he can dismantle the barrel and make a key... if we can get the ignition barrel off. It appears however, there are two rivets holding the ignition barrel assembly on (the same as on my NSR125 RY).
I dont suppose anyone could give me a clue as to how to get the barrel out to get a key made?
Best regards
-Jvr
mccluskeyd
PostPosted: 20:34 - 17 Jul 2011    Post subject: Reply with quote
If you can get a hold of a manual, it will probably show how it is fixed on.
If it is a couple of rivets ; when putting back on you will have to drill out the old rivets & pop rivet the barrel back in.
Usually it is not rivets ; it is a couple of bolts that you cant see underneath in a lot of these trail bike types ; so be careful what you grind off before you are sure how it comes to bits ; it may be a costly mistake to go at it before you are sure !!
An other alternative is once you take it off, put in a generic ignition switch ; there are many on e.bay for about a tenner, but you will have to be sure the amount of terminals match, etc....
All the best with it...
DMcC.
yen_powell
PostPosted: 20:52 - 17 Jul 2011    Post subject: Re: Ignition barrel stuck? Reply with quote
skatefreak wrote:
Hey all.
Best regards
-Jvr
Take the top yoke off turn it upside down and put it in a vice. Get a centre punch and hammer. Use the centre punch to gouge a small lump out of the outside edge of the dome of the security bolt. Now put the centre punch in the gouge and tap the screw anti-clockwise to undo it. Takes a few seconds usually.
The only people that are inconvenienced by these stupid bolts are genuine owners wanting to remove the barrel.
XT1200Z and a DR350 in bits
The last post was made 15 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 36.98 Kb
