| ashh v |
 ashh v L Plate Warrior
 Posted: 02:36 - 19 Jul 2011 Post subject: NEED HELP WITH DNA 50 AGAIN! |
Hey, i have a dna 50 unrestricted.
Right, when i go to pull away, it pulls at around 4500-5000rpm, then takes absolutley ages to reach top speed, but it wont go past 7000-8000rpm at full, and soon as i reach the slightest one degree incline, the bike will just start losing power, rpm will reduce, and speed plummets down. I have absolutley no idea whats wrong. Also i have done a few plug chops, and its running extremely rich, (blacker than black plug) and it has a 75 main jet in, so i bought a 68 and it was running too lean, then i bought a 70 cos thats all they had, and it started to cough and do strange things to me. Would appreciate it if there was brilliant help out there, cos ive heard these bikes go about 59 unrestricted stock, and im getting 30-40 on flat, 50 at a push down a mile long steep hill. hmm thanks (ALSO BY SAYING IT PLUMMETS, I MEAN I GO ABOUT 15MPH MAYBE LESS!!) |
| TUG |
 TUG World Chat Champion
| jjdugen |
 jjdugen World Chat Champion
| Livefast123 |
 Livefast123 Nearly there...
| ashh v |
 Posted: 13:57 - 19 Jul 2011 Post subject: |
So if the choke is stuck, that means it would be stuck in the bottom position, or if it wasn't functioning correctly, so if thats the case, why would the bike be running rich, because the choke would be stopping the fuel, therefore making it leaner? hmm
Regards with the jetting, it had a 56 stock in, but there is a sports exhaust so rejetted it. 75 is too rich, but 68 is extremely lean, (wont even pull away), and 70 doesn't seem to work either, it just cuts out at full throttle.
Does anyone know the operating rpm of these DNA's, such as going about 40ish mph, what rpm should it be because mine sticks at 7000rpm and if it goes down hill, the rev needle will try to go up to 9, then fall back, then go back up, etc :/
So regards to the choke issue, i dont actually think its working, because when its cold, im guessing the choke needle protracts to let more fuel through?
Thanks again, appreciate all the help.
EDIT: The bike revs perfectly on the stand, straight up to 9000-10000, its as soon as its under load it won't... hmmmm |
| Livefast123 |
 Posted: 15:35 - 19 Jul 2011 Post subject: |
Choke makes the mixture richer
The way I understand it works is that the default position for the choke is on, so that when the bike is cold etc it will start without any issues. When the engine starts current is fed into a small heater which melts a wax pellet and your choke goes off. If the choke connector is full of crud/faulty or the choke is faulty then it will be jammed on as there is no current for the heater. This will make your bike extremely rich all the time giving you the symptoms you describe.
Get a manual choke conversion for it as the electric ones are expensive and troublesome. When you have eliminated the choke from your list you can get on with the rest of it. You are never going to get the jetting right with your choke stuck on.
Engines will usually rev up on the stand as there is no load on it. Mixture effects it much more under load.
The other issue it could be is that your rollers are too light / heavy for the new exhaust you have put on. Rollers should be the correct weight to allow the engine to stay in the powerband and it depends on the exhaust where in the RPM range this lies. If you haven't changed them I would contact the exhaust manufacturer and ask what they recommend. ____________________ Current ride - Yamaha MT-07 |
| TUG |
| ashh v |
| TUG |
| ashh v |
 Posted: 08:21 - 22 Jul 2011 Post subject: |
| TUG wrote: | | ashh v wrote: | Okay its not the choke, becuase its completely off and doing nothing.
thanks for the help everyone |
Choke is off and the hole blocked off?
If your 100% certain it isn't the choke then check what size jet your bike should have fitted, remove the carb and check that it is fitted, if not buy one and fit. Again check what the needle height should be then check yours and set it (thats if it even has an adjustable needle).
Are you sure it is a rich mixture blacking the plug and not oil?
I'd check what condition your filter is in before taking the carb apart, give it a clean with brake cleaner or hot soapy water. Strain out the water and let it dry completely. You then want to put a THIN film of oil on the filter, i must stress this, its only to stop small particles 2 or 3 small drops of 2t will be enough.
Refit filter then try running it. Check the simple stuff first. |
Thanks for your help dude, ive tried it all, and yes itr running rich as the plug is covered in petrol, the air filter is cleaner than clean.
There should be a 56 main jet, but a sports exhaust has been fitted so it ran too lean, so then upjetted to a 75 making it rich, tried a 68, to lean, far far too lean. Oh and the needle has been adjusted so it isnt running lean on the needle, its soon as full throttle is placed. No idea, thanks anyway |
| adamcfc |
 adamcfc Borekit Bruiser
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:01 - 22 Jul 2011 Post subject: |
Honest question: do you Gilera pedbois receive some sort of owner's manual which recommends that you TITLE ALL YOUR FORUM POSTS IN CAPS?
I have to ask, because you all seem to do it. Frankly, I'm amazed that you put the bike in the title - usually it's just "NEED HELP" or better "URGENT NEED HELP NOW!!!!11!!". We can just assume that those posts are about a ped, almost certainly unrestricted, and likely a Gilera.
I know this isn't helpful, but... I have to know. ____________________ Biking is 1/20th as dangerous as horse riding.
| TUG |
| GREENI3 |
 GREENI3 World Chat Champion
| TUG |
The last post was made 14 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
