ticked off !!
DIYdemon
PostPosted: 16:54 - 20 Jul 2011    Post subject: ticked off !! Reply with quote
just spent 50 quid for someone to replace a cvt clutch for me on my speedfight 50 cc moped , due to the fact it was slipping , before it was all fooked it got around 35 mph easy and could go up quite steep hills , however now im afraid it gets to about 30 on the straight and gets half way up the hills , =/ im not sure if its the new clutch or something just need a proper moped mechanic to look at it. with it being my only source of transport it is lacking power im very lucky if it reaches 30
also * i know people will be saying " mopeds are only supposed to go 30mph ", but if it went 35/40 before something is wrong i just need some advise Crying or Very sad
ZXR 400 !! The green machine
PostPosted: 17:02 - 20 Jul 2011    Post subject: Reply with quote
Replaced the belt?
Aftermarket exhaust?
Possible someone had a better clutch in there before? Maybe uprated
Teflon-Mike
tl;dr
PostPosted: 17:19 - 20 Jul 2011    Post subject: Reply with quote
Or maybe you haven't taken it 'easy' for the first couple of hundred miles to bed the clutch in and the slippers are now glazed, or you haven't given it a chance to bed in.
calyx
PostPosted: 17:59 - 20 Jul 2011    Post subject: Reply with quote
Remove the clutch cover, find a makeup mirror, check clutch shoes with that mirror.
Any uneven wear?
Is the clutch bell purple?
Boris - London
DIYdemon
PostPosted: 18:42 - 20 Jul 2011    Post subject: Reply with quote
well i have just got off it and the same problem has occurred were i rev but i don't move so it isn't the clutch my next option is to change the belt , while i have the cover off anything else i should consider looking at ?
calyx
PostPosted: 08:59 - 21 Jul 2011    Post subject: Reply with quote
Measure the width of the belt. (on about 4 different places)
Download a workshop manual and check if your belt width is within specs.
Your belt should be grease free and has no cracks or other damage.
BTW probably your mechanic did not turn the variator by hand as he was tightening the bolt. This causes variator pulley to compress against the belt.
Search youtube for "cvt belt". You'll have a better idea.
Boris - London
DIYdemon
PostPosted: 20:01 - 21 Jul 2011    Post subject: Reply with quote
ok thanks i will do i hope it is the belt save me a lot of money Mr. Green
DIYdemon
PostPosted: 20:21 - 24 Jul 2011    Post subject: Reply with quote
ok hear are a few pics of the inside of my transmission case
https://s1185.photobucket.com/albums/z343/DIYdemond/
tell me if u see something out of the ordinary
The last post was made 15 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 58.16 Kb
