Wanted: Dummies guide to replacing rear brake pads!
huskie69
PostPosted: 17:36 - 20 Jul 2011    Post subject: Wanted: Dummies guide to replacing rear brake pads! Reply with quote
Can anyone help me or at least point me in the direction of an easy to follow guide on replacing my rear pads (SV650). I've got a haynes manual but I might a well be reading a Chinese manuscript - it's not really written for beginners!
I've found a few sites on the interwebs but most contain jargon which I'm completely clueless on. Some have suggested I remove the caliper from the bracket, others say it can be done without removing the caliper. Also, what should I use to push the pistons back in? (bearing in mind I don't have any specialist tools).
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
PostPosted: 17:38 - 20 Jul 2011    Post subject: Reply with quote
Remove caliper from bike (leave brake line attached)
Take pads out.
Push pistons in with bit of wood and a clamp (I used a small handheld vice on the car and bike)
Replace pads.
Refit.
PostPosted: 17:40 - 20 Jul 2011    Post subject: Re: Wanted: Dummies guide to replacing rear brake pads! Reply with quote
Well, if you can't understand a Haynes manual... then maybe the best method is to phone a garage and book it in!
Seriously, it isn't a hard job and I can't understand how a haynes manual could make it sound difficult. If you really want to learn and you really can't decypher the Haynes, then I suggest you get someone to do it for you and watch them as they do it.
No offence Paddy, but if this guy can't understand the Haynes, then your method could leave a little to be desired! There are How To guides on this very forum usually with photos and I think they are in a sticky at the top of the workshop.
PostPosted: 17:41 - 20 Jul 2011    Post subject: Reply with quote
You forgot cleaning and then lubing. (On the front of SV650s this is VERY important, never done much with rears, but not going to hurt.)
Oh and if you look at the top of this section, there's a post called "BCF Workshop Guides & Handy Links"... go to that and read Marjay and Korn's guides - both go through all you need and more.
PostPosted: 17:44 - 20 Jul 2011    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=19435
https://www.bikechatforums.com/viewtopic.php?t=22573
https://www.bikechatforums.com/viewtopic.php?t=63228
huskie69
PostPosted: 18:04 - 20 Jul 2011    Post subject: Reply with quote
Thanks guys, that's all I'm after and kicking myself for not browsing the stickies first! In a bit of a panic as my MOT expired last week - I thought I had another 2 weeks left Embarassed and need pads replacing before I get it motted. Regarding the Haynes - there are some sections that I can follow and seem pretty straight forward. Other parts are completely over my head. What I really hate is that the B&W images are always taken on an immaculate bike or part and don't look anything like the grubby oily parts I have on mine Wink
Burnside
PostPosted: 19:09 - 20 Jul 2011    Post subject: Reply with quote
Take pics as you go along then post em here Smile
I started out with nothing and I still got most of it left.
huskie69
PostPosted: 23:01 - 23 Jul 2011    Post subject: Reply with quote
Done - piece of piss! I had visions of me losing the pins or getting sprayed in the face by dot4. Just took caliper off, then removed the bar which held the pads in place, pushed the piston in by hand, put new pads in, slid caliper over disc and refitted. Job done.
dragstaar
PostPosted: 21:41 - 24 Jul 2011    Post subject: Reply with quote
Wow, a brake pad fit which didn't involve lots of huffing and puffing, and removing cylinder caps, and seized pistons, and seized pins.
Thats got to be a first!
Also, I hope you copper greased the back of the pads? stops the dirty squeal they make. I also copper grease all my caliper bolts too
ajbsmirnoff
PostPosted: 09:01 - 25 Jul 2011    Post subject: Reply with quote
I thought hitting your thumb with a hammer was the done thing during such a job.
cb1rocket
PostPosted: 11:50 - 25 Jul 2011    Post subject: Reply with quote
LUCKY SOD!
I had to destroy my caliper to get the fuckers off! Make sure you do use lots of lube, esp on the pins!
What year SV?
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 72.53 Kb
