| czakal |
 czakal Nitrous Nuisance
| fatpies |
 fatpies World Chat Champion
| czakal |
| fatpies |
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 23:38 - 21 Jul 2011 Post subject: |
Hi Seb,
If your brake is working fine at the moment then it wont require drastic maintenence.
What tends to happen with hydraulic brakes is road crud builds up on the sides of the piston, which corrodes the piston and damages the piston seals.
You can do an inspection and light clean up of the brake without having to remove the pistons, and therefore not having to refill the system with hydrailic oil. If you do this regularly, then you wont ever have a piston seize again.
You can remove the caliper from the fork (while keeping the hydraulic cable attached), remove the brake pads, pump the lever to push the pistons out half way, and clean them up. Remove any dirt, and clean up the pistons with brake cleaner. If there isn't any rust on the pistons, then push them back in, reassemble and you're good to go.
If the pistons show corrosion then they will need to be replaced at some point, as this will damage the seals and cause leaks. However, minor rust will likely clean up well enough, and not be a concern.
Does that help at all ? ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| Ade75 |
 Ade75 Borekit Bruiser
| prawny1 |
 prawny1 World Chat Champion
| TUG |
 TUG World Chat Champion
 Posted: 00:16 - 22 Jul 2011 Post subject: |
Heres what happens, simple version:-
Road salt reacts with all metals on the bike - Corrosion and rust occurs.
Brake calipers are aluminium, salt corrodes.
Corrosion then occurs in the seal seats pushing the seal against the piston, this causes binding (brake pad always touching disc).
If not cleaned out at this point, more pressure will be applied to the seal against the piston until it then gets pushed out, the caliper piston can no longer return even with pressure from you.
 ____________________ Haz ER-5, innit! |
| czakal |
| Robby |
 Robby Dirty Old Man
| TUG |
| czakal |
The last post was made 14 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
