help! put the wrong oil in!
sc125
PostPosted: 12:50 - 22 Jul 2011    Post subject: help! put the wrong oil in! Reply with quote
right firstly i accept im a numpty, have a 99 hornet 600 and i am a mechanic so i thought i would change the oil and filter at work, used the oil we had there (euros stuff in a big drum) ever since i changed it ive noticed my bike doesnt feel as quick. went down to my workshop and asked my mates advice and straight away he said 'did you use motorcycle oil' forgetting the clutch sits in the oil so it has to be correct? so ive been riding it like it for 100 miles or so and changed it for castrol motorcycle stuff yesterday. question is will it eventually sort itself? ive noticed now and again on the way home it felt quick again but only now and again, any advice? thanks Mr. Green
PostPosted: 12:58 - 22 Jul 2011    Post subject: Reply with quote
You might need new clutch plates, because car oil has friction modifiers in that can contaminate wet clutches.
What I'd do is take the clutch plates out and soak them in motorcycle oil overnight, then put them back and see if it is any better.
You can do this without draining the oil on some bikes by laying the bike on its side on a mattress or similar.
sc125
PostPosted: 13:10 - 22 Jul 2011    Post subject: Reply with quote
thanks, so theres no chance of it sorting itself out through riding it then? i have already drained the car oil and emptied the oil filter, feel like a complete twat lol
jimspeed
PostPosted: 13:52 - 22 Jul 2011    Post subject: Reply with quote
is the clutch actually slipping tho? if its not then don't worry lots of folk just use normal car oil in their bikes and have no probs (I think its usually the more expensive car oils that cause the probs).
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
devojunior
so when you go to say ( halfrauds) and you see 10w 40 as it says i need for my bike i cant use the car stuff it has to be motorcycle specific ?
PostPosted: 13:55 - 22 Jul 2011    Post subject: Reply with quote
Cheapo car stuff is usually OK. Normally Magnatec and the like is what causes this.
PostPosted: 13:57 - 22 Jul 2011    Post subject: Reply with quote
Don't panic - just change the oil and it should improve. Most car oils contain friction modifiers and the long-life stuff used in the most modern engines is very slippery, but if you just change it all should be fine. I actually use diesel engine oil (not long-life) in my bikes and it never causes any problems.
Brick_Top
PostPosted: 14:01 - 22 Jul 2011    Post subject: Reply with quote
It would help if you answered this question.
The oil is only going to affect the clutch in terms of performance, and it should be very obvious when riding hard if it is slipping or not?
If it isn't slipping then forget all this, it's in your head.
C
sc125
PostPosted: 16:06 - 22 Jul 2011    Post subject: Reply with quote
well thats the problem the clutch isnt slipping. i assumed because it uses a multi plate system you wouldnt notice it like you would in a car. its just definetly not as quick as it was. only since i did the oil change tho. going for a 25 mile ride in a bit so will kick its arse and see if it improves. thanks for all the input guys.
PostPosted: 16:42 - 22 Jul 2011    Post subject: Reply with quote
I put Cheapo Castrol GTX in my TDM and it ran like a bag o shite. Many people say car oils are fine but my experience says stick to bike ones.
PostPosted: 16:46 - 22 Jul 2011    Post subject: Reply with quote
Ok put it this way - if you have put 'more slippery' oil in your engine how do you think that has caused you to make less power? By all rights the engine should turn more freely and you should gain power not lose it.
If you have lost top-end speed, and the only thing you have done is changed the oil, then your clutch is slipping. 'Kicking it's arse' will quite likely burn out the clutch.
PostPosted: 16:51 - 22 Jul 2011    Post subject: Reply with quote
How do the gears feel? heavier or lighter to engage?
What weight oil did you put in it? What weight oil does your bike take.
koolio
PostPosted: 18:16 - 22 Jul 2011    Post subject: Reply with quote
Don't know about new bikes, but many old bike manuals pre-1980s instruct removing the plates and soaking them with kerosene (paraffin over here) which cleans them, then drying, then inspecting and finally re-installing.
sc125
PostPosted: 18:19 - 22 Jul 2011    Post subject: Reply with quote
i put 10w-40 car oil in and my bike takes that grade, replaced it with 10w-40 motorcycle oil, the gears do seem slightly heavier but again that may be in my heeed. just took if for a blast and it still doesnt seem right to me, just doesnt seem to pull as hard as it used to as if im having to push it rather than it pulling itself round the revs. and surely if i used a more 'slippery' oil once it gets hot it wll get thinner and then cause more friction between metals?. i always use the 99 octane fuel too. feels quicker with it and i get more miles for a few pence more. wouldnt because a problem would it? never has before
sc125
PostPosted: 18:21 - 22 Jul 2011    Post subject: Reply with quote
coolio was thinkng the same, have loads of thinners a white spirit etc at my workshop so was gonna clean the plates down with that or something.
PostPosted: 18:47 - 22 Jul 2011    Post subject: Reply with quote
You won't get metal-metal contact from the oil getting hot.
Fuel CAN make a difference, not because of the octane rating but just that some fuels will run your engine better than others. I've noticed many times that my bikes have run differently immediately after a fill-up.
Are you sure that it's not just a case that changing the oil has made your bike run smoother and less noisy? You can usually notice it after an oil change.
Brick_Top
PostPosted: 19:59 - 22 Jul 2011    Post subject: Reply with quote
As I said before you should be able to tell easily if the clutch is slipping as the revs will surge without the bike accelerating in proportion to the revs going up.
The oil thinning out 'slowing your engine down' is complete and utter nonsense.
PostPosted: 20:03 - 22 Jul 2011    Post subject: Reply with quote
Clutch slip is possible but not that likely and should be very obvious.
If it has made that much of a difference I would suspect the most likely things are the oil level being far too high or oil getting spat onto the air filter through the breather (possibly from the oil level being far too high).
carvell
Scuttler
PostPosted: 20:18 - 22 Jul 2011    Post subject: Reply with quote
With regards oil, all you need to know is this:
https://shaftdrive.files.wordpress.com/2010/11/api-circle.jpg
Any old oil is fine, as long as it doesn't say 'energy conserving'.
Yamaha TDM 850
weasley
PostPosted: 23:13 - 22 Jul 2011    Post subject: Reply with quote
Nah, viscosity is viscosity. I doubt very much that the wrong oil of the right viscosity will make any discernible difference, especially if the clutch isn't slipping. Red herring inducing paranoia effect.
PostPosted: 23:20 - 22 Jul 2011    Post subject: Reply with quote
Not really. Some car makers just specify normal engine oil in gearboxes anyway.
However engine and gearbox oil viscosities are not the same. 10W40 engine oil is equivalent viscosity to something like 75W90 gearbox oil (they are not directly comparable).
The viscosity chosen (ie, the OP used 10W40 which is probably what Honda specify) then that is the oil thickness.
EDIT - pretty much what Weasley said.
flumpy7 This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
czakal
PostPosted: 09:26 - 23 Jul 2011    Post subject: Reply with quote
I once made a post about the topic of car vs bike oil. I used car oil in my Kymco Pulsar for its first oil change and so far it seems fine. The most common advice I got was that for a 125 it doesn't matter so much. Is it also possible to use car oil in bigger bikes?
serlant
PostPosted: 09:35 - 23 Jul 2011    Post subject: Reply with quote
grrrr i'll get a pic of the clutch in my XJ600 that still didn't slip after riding about 12000 miles on car oil...
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 130.91 Kb
