NoNoNoNoNo !!!
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
kev
I Hump Things
PostPosted: 23:45 - 27 Aug 2004    Post subject: Reply with quote
Are you sure your headstock bearings haven't worn out?
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Flywheel
PostPosted: 13:16 - 28 Aug 2004    Post subject: Reply with quote
how many miles has it done? if its more than 20000 could well be the bigend if it hasnt been replaced before. Does it jirk a bit when you ease of the throttle cause thats almots defently the bigend.
I konw that the guy said it was fine but you can never be sure unless you find out for yourself.
good luck
binge
Emo Kiddy
PostPosted: 04:01 - 29 Aug 2004    Post subject: Reply with quote
Well if it is knocking when the throttle is eased off. Then it could well be the big end...
Are you Sure its coming from the engine. because i have got a friend with a Cagiva Mito Evo. and when he lets off the throttle he gets clutch rattle. He got a race clutch and its fine now...
Good luck...
Ben!
Sparks!
Sir Tart-a-lot
PostPosted: 04:04 - 29 Aug 2004    Post subject: Reply with quote
Have you checked all engine mounts and bearings for headstock etc as Kev says... it may only make noise when letting off the power I don't know but it's well worth checking if you've already rebuilt the engine!!
Won't hurt to go around checking all the bolts and engine mounts, bearings etc anyway so well worth trying?
baldy
PostPosted: 00:35 - 30 Aug 2004    Post subject: Reply with quote
Hi,
My nsr did this and i thought it was my big end. turned out to be my chain was loose and was slapping on the chain guard.
One day i will rule the world, just not today.
map
Mr Calendar
PostPosted: 12:43 - 31 Aug 2004    Post subject: Reply with quote
Quick question if this isn't already sorted.
Does it do the 'knocking' under load (i.e. while being ridden) and/or when revved both in and out of gear on the stand?
The last post was made 22 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 61.52 Kb
