Zinc coating - has anyone done it
PostPosted: 13:37 - 25 Jul 2011    Post subject: Zinc coating - has anyone done it Reply with quote
After reading an Article on Practicle Sportsbikes I am considering getting one of these
https://www.gaterosplating.co.uk/Zinc-Plating-kit.php
Anyone have experience with this stuff before?
PostPosted: 13:50 - 25 Jul 2011    Post subject: Reply with quote
I have a nickel plating kit, but not got round to using it yet. More from wanting to be fully sorted to store the liquids before use (they are not cheap, and no mixing them up if I can't store them).
Really should give it a try some time.
PostPosted: 13:52 - 25 Jul 2011    Post subject: Reply with quote
Is Nickel better than Zinc? I want it to Restore various fixings on my bike, is it safe for things like Brake Caliper bolts? etc.
PostPosted: 13:54 - 25 Jul 2011    Post subject: Reply with quote
Nickel plating should give a brighter finish. Similar to chrome if properly prepared. Not sure with zinc, but would expect a rougher finish, which is probably more in line with the factory finish.
nowhere.elysium
The Pork Lord
PostPosted: 17:48 - 25 Jul 2011    Post subject: Reply with quote
For the terminally lazy/tight, you can buy spray cans of Zinc. The finish is obviously nowhere near as tough, though.
flat spot
PostPosted: 17:53 - 25 Jul 2011    Post subject: Reply with quote
Why bother? Just look for an industrial place who do a shed load for next to nowt.
Teflon-Mike
tl;dr
PostPosted: 17:58 - 25 Jul 2011    Post subject: Reply with quote
I was looking at variouse plating kits; 'Copy Chrome' is the most like real chrome, which for reasons I cant remember is rather impracticle for home electroplating kits, hence Nickel Plating has been more common for much longer. Nickel gives 'chrome like' finish when polished, but tarnishes more easily. The Copy-Chrome seem to be a harder Nickel Chrome alloy, 'more' like chrome, but as easy to plate as nickel. To get good finish, though, most have to be plated over copper plate. Some kits contain solutions to pre-plate with copper.
Zinc plating is galvanizd bucket finish. great rust prevntion, but as asthtically pleasing as a galvanised dustbin!
Coating in Zinc, you get a 'self haling' skin over the metal, that acts as a sactrificial cathode; so the zinc 'rusts' instead of the metal, with bonus that if the zinc is scratched, the 'galvanic cell' st up when th scratch gets wet, sees the zinc oxidise rather than the steel bneath, and, within crtain limits of plating thicknss to scratch width, 'self heal' forming a scab over the wound.
So, Copy Chrome / Nickel for decorative 'bits, Zinc for stuff that you dont see, and want to keep rust free.
Bru
PostPosted: 18:50 - 25 Jul 2011    Post subject: Reply with quote
Funnily enough, I was on that website today. There is a passivate coat which goes with the kit; it covers the zinc to prevent white oxide formation. Basically, it will do the job. Better than painting.
I last used a similar kit from Caswell Europe, which was also expensive, but did a good job of copy-chrome on some small parts.
The Gateros kit reads like a lot of work, but I have seen others' results, and in the long-term, it may be worth it. Decide for yourself which is cheaper in the short-term, with regard to DIY or 'professional' service.
PostPosted: 13:12 - 23 Aug 2011    Post subject: Reply with quote
Right I got the kit and have put a few bits through it, I am fairly impressed, although it was a bit hit and miss, doing lots of items at once didn't work too well, however one off items came out reasonable well. The kit is easy to set up and use just read thought the instructions a few times before starting.
I think I was also let done buy the quality of my prep work. Laughing
Things you will need other than what is included.
5l of distilled water.
Wire brush/drill.
Degreased/brake cleaner.
More copper wire.
Didn't really take any pictures I will do a write up at some point with pics.
PostPosted: 13:32 - 23 Aug 2011    Post subject: Reply with quote
https://www.gaterosplating.co.uk/images/efb0_1.jpghttps://www.gaterosplating.co.uk/images/eebd_1.jpg
This is from the website and is very similar to the results I got, wire wheel them then degrease and drop in the tank. Thumbs Up
PostPosted: 21:51 - 23 Aug 2011    Post subject: Reply with quote
Here is the set up.
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/309379_10150757551470422_698975421_20153786_1539034_n.jpg
Frost
PostPosted: 21:56 - 23 Aug 2011    Post subject: Reply with quote
Timon has a butt load of stuff shot blasted and zinc plated in his VFR400 thread in the workshop section. It all came out lovely, though i expect the shot blasting made a massive difference!
The last post was made 15 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 77.43 Kb
