RS 125 Power Figures and A2 Licence
HD
PostPosted: 21:57 - 25 Jul 2011    Post subject: RS 125 Power Figures and A2 Licence Reply with quote
Hey,
I am planning on taking my A2 in December. At first I was considering getting a Bandit 600 as it seemed the best, cheapest and most sensible option of getting a bigger bike.
However, money has gotten a bit tight and the insurance has gone up since my last quote. I will do quotes up towards the time but if it does remain high I have another option.
My mate is selling an RS 125 but is planning on keeping it for a bit if I want it. I know a lot what has happened to it in the last 12 months and have made some conclusions as to the reliability, ride comfort, practicality etc.
One of the things holding me back is the power/weight ratio for the A2 licence. For it to meet the 0.16kw/kg figure, it must be making no more than 27bhp as it ways 126kg (apparently).
I know it is derestricted but the power valve is either not working or disconnected. Someone the guy knows recommended he disconnects it as it can reduce reliability of the bike. I'm not saying whether or not he is right or wrong but I would like to know some figures, if possible.
I am aware in restricted form it makes 14.6bhp. So how much would it make with the powervalve connected, and without? Some places say 33bhp or there abouts but it must be at least a little bit lower than that? If it would keep it below 27bhp, how much would it be to for a new powervalve system?
Any info would be appreciated!
Ta Thumbs Up
WannaBeDude
PostPosted: 21:59 - 25 Jul 2011    Post subject: Reply with quote
A2s 33 bhp afaik, fuck 27 .. RS will be 25/26 and drink fuel ! Thumbs Up
PostPosted: 22:15 - 25 Jul 2011    Post subject: Reply with quote
Depends on the model of RS125. Older ones Aprilia didn't quote a power figure (bit of a storm in around 1989 when Gilera launched the SP01 and a magazine got 107mph from it in a road test - to stop the backlash against 16 year olds riding them they stopped quoting power figures and a load of the Italian magazines stopped performance testing them). UK road test for the early RS125 was 28.5hp at the back wheel (but the 25kW / 33hp is meant to be a crank figure) but later ones are less powerful (latest are only a bit over 20).
Weight wise, it depends on which weight is counted. Early ones have a frame plate for 115kg, but that is dry weight (and probably a bit hopeful). Rules for the 25kW limit are here:-
https://www.opsi.gov.uk/si/si1999/uksi_19992864_en.pdf
Page 7 of that states the weight used for the power to weight ratio is:-
“power to weight ratio”, in relation to a motor bicycle, means the ratio of the maximum net power output of the engine of the vehicle to its weight (including the weight of any side- car) with—
(a) a full supply of fuel in the tank, (b) an adequate supply of other liquids needed for its propulsion, and
(c) no load other than its normal equipment, including loose tools;
So with a full tank of petrol, etc, there is probably at extra 20kg on top of the weight on the frame plate.
As to the power valve, leaving it disconnected it will probably cause more problems. They are a pig to unstick it left closed for too long.
HD
PostPosted: 22:25 - 25 Jul 2011    Post subject: Reply with quote
Was hoping you'd be along Keith Laughing
It is a 54 plate so the bigger/curvy model. I believe they are the fastest? and IMO the best looking. Custom paintjob too that is quite tasteful.
So I am looking around the 125kg weight mark then?
I have ridden it like it is and there is a jump in power at around 8k as it hits the powerband so is that just the engine or is that the powervalve kicking in so is it really disconnected? How much of a difference does the power valve make? What issues/gains are there in the real world?
Any idea what power I am looking at with/without the pv?
Sorry about all of the questions, just don't want to make the wrong choice Laughing
PostPosted: 22:37 - 25 Jul 2011    Post subject: Reply with quote
At that age it will have the smaller carb and also probably a pretty poor exhaust. The original shape ones should be quite a bit quicker.
At a guess a bit short of 25hp at the back wheel.
Weight wise if you use the wet weight then 135kg.
If there is a kick at about 8k then either it has a working power valve (so not that much of a kick) or the power valve stuck fully open (rather bigger kick). Restricted it would go to sleep just past 8k (would still rev out, just not do anything useful if you rev it further).
HD
PostPosted: 22:40 - 25 Jul 2011    Post subject: Reply with quote
Definately doesn't go to sleep haha.
Well the exhaust is an arrow. It was a full system but he got a hole in the front pipe. Not sure if the front pipe is now an arrow or an original but it still has the arrow can.
Again, not sure about the carb size.
Guess before I buy it I may do a dyno. How much would I be looking at?
So it is looking as though it will be legal to ride on A2 then? Mr. Green
PostPosted: 10:23 - 26 Jul 2011    Post subject: Reply with quote
The can alone won't do much other than make it noisier.
Carb will be a 28mm one unless someone has changed it (they used the 34mm up until about 1997).
Dyno run should be cheap. Suspect it will produce something just under 25hp.
A2 legal is going to be fun to prove either way as the power limit is at the crank, and realistically you can't measure that (even pulling the clutch and measuring the drag in the transmission to try and guess it will mean ignoring drag in the primary drive).
HD
PostPosted: 12:06 - 26 Jul 2011    Post subject: Reply with quote
I'll have a look at the carb next time I see him.
Also, if I lift up the tank, will I be able to see the power valve and if or if not its working?
I thought they measured the bhp from the back wheel? I could have sworn thats what happened to that guy on that sv650 forum I read? Confused
Cheers for the help anyway!
PostPosted: 12:14 - 26 Jul 2011    Post subject: Reply with quote
Rolling Eyes You'll be fine.
Seriously, I wouldnt say my RS was putting out much more than 20-22 and that had a full arrow system, rebuilt and run in correctly and was running tip top indicating around 100.
It would probably work out cheaper to get the bandit, or look at smaller cc, such as the CB400SF... heck a B King is cheaper for me than a Bandit Laughing
PostPosted: 14:12 - 26 Jul 2011    Post subject: Reply with quote
The soloinoid is a gold coloured cylinder on one frame rail. 2 wires go from it to the loom, and a cable goes from the other end to the power valve above the exhaust port. You should be able to peel back the rubber boot around the power valve to check that the valve moves, although it will be a pain to see with the battery in place. The valve is open below 2500rpm, then closed until around 8000rpm (varies depending on the power valve control unit) when it opens again. So you should be able to see it opening and closing just beyond idle.
That is where they measure if, but not where the law specifies. Last states "net power output" which will be based on EU Directive 80/1269/EEC, which is based on German standard DIN 70020 which is measured at the engines output shaft.
Testing an individual bike to these standards would be prohibitively expensive though.
ace-card
PostPosted: 14:48 - 26 Jul 2011    Post subject: Reply with quote
When I had mine, I took it to be dyno'd, having just rebuilt it and just "run it in"........26bhp at the back wheel with a 34mm carb, pipercross cone and standard exhaust (didn't have the money for a performance one after MAJORLY blowing my budget Shocked ). The guy reckoned that after a few more miles, when everything loosened up, I'd achieve possibly a couple more bhp........sold it six months later, so we will never know! With regards to the powervalve, make sure you have the correct slack on the cable....needs to be adjust to between 7 and 8mm IIRC.
Think you'll be fine with regards to riding it on an A2....I was riding around on mine with just a CBT (not condoning this though Wink )
2007 Skyjet SJ-125, 2001 Aprillia RS125, 1988 Honda CG125, 1997 Yamaha YZF600R
Mama said "life is like a box o' chocolates....have what's nice, then offload the crap to everyone else!" Wink
HD
PostPosted: 20:41 - 26 Jul 2011    Post subject: Reply with quote
Cheers for the help guys.
Paddy - Looked at lots and lots of options and the Bandit seem(ed) to be the best option but am liking the idea of an rs, plus its cheaper!
Keith - I'll have a look for the pv next time then, thanks!
ace-card - See this is what I'm thinking about haha. I think they allow about 10% over the bhp limit so would they allow that over the weight limit? But there's small chance of me being tested anyway. Shit loads of people ride around here illegally on CBT's here too haha! I just want to not get raped if I do get caught and it goes further Razz How much was your dyno? And was it purely just power figures or did they test other things?
PostPosted: 20:45 - 26 Jul 2011    Post subject: Reply with quote
Only until it breaks, at the most awkward times... Rolling Eyes Evil or Very Mad
HD
PostPosted: 20:49 - 26 Jul 2011    Post subject: Reply with quote
Haha I know! But I've had more problems than anyone I have ever heard of with my bike so I'm used to it haha. Hopefully it will never get to that. It's had quite a lot done to it recently. Going to give it a once over when I get it to hopefully preserve it a bit more. Will also be saving for when anything does go wrong... Laughing
clancy
PostPosted: 20:54 - 26 Jul 2011    Post subject: Reply with quote
the RS may be cheaper but youll probably end up spending the same amount fixing it. not to mention the pain in the ass of it breaking.
personally i would buy a different bike, better condition more reliable one. and one thats easier to prove that its legal for you to drive.
money wise i doubt theres much difference in it for you, when i got my 400, quotes for 400/600s where cheaper than 125s with a full liscence. have a look at insurance prices for loads of bigger bikes, might find one you like that really cheap to insure Thumbs Up
KLX 300r
HD
PostPosted: 21:01 - 26 Jul 2011    Post subject: Reply with quote
Thats what I've been thinking the whole time!
In the beginning, bandit was 350-400, vfr/cbr etc were all about 800, sports 600s I couldnt get a quote for and nothing else I really like within my price bracket (£1000-1500).
Unless you guys can recommend something then it looks like rs or bandit. Bearing in mind those quotes were what I did months ago several times.
I did a quote the other day and Bandit was either 550 or 650, vfr/cbr etc were 1200, wr 250 was 100 more than the bandit and the rs was 350...
I will probably keep it for a year then get something else for the second year of my restriction but for the first year, it seems the best financial option. If I have problems then I can save to pay for them but for the initial cost of the bike/test/insurance, even a bandit is over my price bracket mostly (would like an mk2 with low miles).
Cheers Smile
clancy
PostPosted: 21:04 - 26 Jul 2011    Post subject: Reply with quote
insurance cant be guessed, changes to much for anyone mate. best bet would be to look on ebay/bike trader for bikes in your budget you like, then check insurance at same time. get a list of affordable bikes and go from there
bare in mind one bike might not be the same to insure as an identical bike, dont ask me why but thats what happens
KLX 300r
HD
PostPosted: 22:47 - 26 Jul 2011    Post subject: Reply with quote
No I have. Like got plates and done go compare. Thats how I get those quotes, they're not guessed Laughing
And Rob, don't really like the look of them, mostly out of my price range and I know they are faster but seeing its restricted, it won't matter anyway. Cheers though! Thumbs Up
kawakid
PostPosted: 23:27 - 26 Jul 2011    Post subject: Reply with quote
Good luck on doing it in December.
Hopefully it will be milder than last year, I usually commute 365, but it was impossible last year.
I've a twin and a 4.
HD
PostPosted: 23:52 - 26 Jul 2011    Post subject: Reply with quote
Unfortunately, its my birthday :/
My CBT was delayed 3 times cos of snow and ice haha.
When I finally did it, my second week was all snow and ice riding and I didnt crash once! Just dropped it once cos I couldnt stand up so I fell and the bike went too! Laughing
clancy
PostPosted: 12:58 - 29 Jul 2011    Post subject: Reply with quote
nah sorry didnt mean it like that, i know that what you did. you said about a bike with cheap insurance, i just meant its hard for me/us to say as it changes so much from person to person.
like my mate lives across the road from me, his insurance on a gixxer was over £1500 and loads of people said no to him. mine was like £600 :s no idea how it works lol. the general rule is that naked bikes are cheaper to insure though....but if you like sports bikes id say its %100 worth the extra bit of £££ for insurance
KLX 300r
HD
PostPosted: 13:47 - 29 Jul 2011    Post subject: Reply with quote
Oh sorry, I didn't see what you meant either haha.
Thats what I keep telling myself. At the end of the day, I'm only (well will be) 17 and I'm riding around on a big naked. The rs will be a more fun bike and yes I may/probably will have problems but like you said it is worth the extra dosh. And its cheaper on insurance anyway.
I will probably get a different bike the second year of my restriction then at the end get a bigger unrestricted bike. Thinking gsxr 600 but then I think if I have a 600 then why not go the extra bit further and get a 750 but 33bhp to 120? is a big jump Laughing
But thats too far away to think about atm haha.
Cheers Laughing
PostPosted: 14:00 - 29 Jul 2011    Post subject: Reply with quote
The cc and hp jump does not matter dude.
I went from 100hp car to like 600hp Laughing
Bike was 11hp > 50hp then back down to 9hp > 110hp... its fine, just get used to it before you wind the bike up and shoot off Laughing
All I can say is my 750 is sterling, I cant really fault it...enough power to do most things Thumbs Up
HD
PostPosted: 15:15 - 29 Jul 2011    Post subject: Reply with quote
Hmm I guess. I am quite sensible when I want to be Razz
The last post was made 14 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 141.68 Kb
