12v battery
BigGeeking
PostPosted: 14:36 - 25 Jul 2011    Post subject: 12v battery Reply with quote
hi all
just a quick one, hehe
i have a 12v 4amph battery what will be the resting volts?
and what will the
volts be under load if i test when pressing the starter button.?
also when i charge my battery what shoud the volts be immediatly after charging i read about 13.5v then after 1 hr rest it should drop down to 12.7v is this correct.
thanks my bike fixing chums. Mr. Green
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
PostPosted: 17:18 - 25 Jul 2011    Post subject: Reply with quote
Have a look here.
https://www.totalmotorcycle.com/maintenance/battery.htm
Looks good Thumbs Up
dolly3900
PostPosted: 10:33 - 27 Jul 2011    Post subject: Reply with quote
Hiya,
Your numbers sound about right, 12.5V-12.8V is about right for nominal voltage after standing for a bit.
Charging (from your bike running) should be reading about 13.5V-13.8V and about the same with a charger, although many cheapy chargers will read different as they use a very simply rectified mains voltage, which is OK for charging, but difficult to measure accurately on a standard multimeter.
If your battery is reading below these, then you may have a problem with the battery, possibly a dry or very low cell.
If that is the case and it is not a gel or sealed battery, then you should be able to top up the offending cell with some Sulphuric Acid (get from a motor factors) and as long as the plates are not damaged or twisted, you should be able to resurect the battery.
Failing that, a new battery is not going to cost you too much, just bought one for £20 including VAT and acid.
Hope this helps
Mike
dolly3900
PostPosted: 10:34 - 27 Jul 2011    Post subject: Reply with quote
additional........
Just read the link posted in the first reply, pretty much what I was saying
Smile
rustgold
PostPosted: 14:00 - 27 Jul 2011    Post subject: Reply with quote
I have to ask, have you had the battery sitting for a long time and have you tried to start the bike from the battery?
I don't get on too often, so in case the answers are yes, a battery that's been sitting will lie about the voltage. Something about particles within the battery forming balls (permanently) depleting the capacity of the battery.
Caution : Doesn't come with 1698-B sanity certification
https://www.facebook.com/rustgold
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 45.85 Kb
