1991 GPZ500s, does it have aux wiring?
jimspeed
PostPosted: 22:25 - 27 Jul 2011    Post subject: 1991 GPZ500s, does it have aux wiring? Reply with quote
As above really guys does it already have an auxillery wire I can add to for phone charging etc? or am I starting from the battery with a relay again Question
someone mentioned exploding altenators on these bikes too is there an easy way to check if its got the better one fitted or not.
Karma
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
finpos
PostPosted: 23:03 - 27 Jul 2011    Post subject: Reply with quote
There won't be a specific wire on a bike for auxiliary stuff, you'll just have to tap into a wire somewhere to do it - just find somewhere convenient. The feed to the brake light switch is a good place (front or back). On a kawasaki of that age my guess (i.e. you might want to check) is you'd be looking for any brown wire which will be live with the ignition switched on.
The problem with the alternators on those if I remember is that the magnets detach from the flywheel and then create havoc. I'm not sure if there's anything you can do other than wait for one to fall off.
f.
PostPosted: 23:13 - 27 Jul 2011    Post subject: Reply with quote
As above. I would use the rear brake light switch as a trigger wire for a relay powered directly from the battery (via a fuse).
The early shape GPZ500s have flywheels on which the magnets tend to crack and come off. They seem to manage about 20k~25k before this happens. If you are unlucky then it will take out the alternator windings as well. New flywheel isn't cheap (although new ones are redesigned to avoid the problem), while 2nd hand ones are difficult to find.
If you need to remove the flywheel then remember the bolt holding it on has a reverse thread Embarassed .
The last post was made 15 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 37.01 Kb
