GPZ 500 Air Filter Cleaning
nigel_robbins
PostPosted: 09:58 - 29 Jul 2011    Post subject: GPZ 500 Air Filter Cleaning Reply with quote
Hi,
I plan on cleaning the original foam air filter on my GPZ 500 which has done 15k miles.
Does anyone know the best way of doing it...
How should I clean it (e.g. what solvent should I use) ?
What oil should I use and how should I apply it ?
Thanks !
PostPosted: 10:11 - 29 Jul 2011    Post subject: Re: GPZ 500 Air Filter Cleaning Reply with quote
nigel_robbins wrote:
Hi,
Thanks !
If its an OE one, then throw it away and buy a new one. If its a K and N, then compressed air is a good way to do it.
whitedevil
PostPosted: 14:33 - 29 Jul 2011    Post subject: Reply with quote
oe ones can be cleaned just fine as long as they're not damaged and replaced evey 4 times iirc.
I cleaned mine with parrafin, dried it out with a hair dryer and then applied a very thin layer of clean engine oil remove excess oil with shop towel.
Or you could do the FOG mod which involves putting a k&n air filter in and cutting a 1inch hole in the back of the left hand side airbox, then turning the pilot screws out 2.5 turns. (then adjust to fine tune to your bike)
It makes the bike run much much better imo and gets rid of the flat spots through the rev range.
More info can be found at www.ex500.com
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
PostPosted: 14:55 - 29 Jul 2011    Post subject: Reply with quote
Kawasaki list it as to be washed with a bath of high flash point solvent and then dry it by blowing through with compressed air (in the opposite direction to the way air would normally go through it).
Should then be oiled by soaking a lint free towel with SAE 30 oil and then tapping the outside of the filter with the towel.
PostPosted: 00:09 - 30 Jul 2011    Post subject: Reply with quote
Hot soapy water also works, then setting it aside to dry.
Don't try to reuse it too often though! Although I suspect this one was more a case of the previous owner never having looked at it since the bike was new (24k miles). Moral of the story, If you buy a bike that's "just been serviced", don't believe a word of it.
https://i48.photobucket.com/albums/f216/stinkwheel/airfilter-1.jpg
Ingah
PostPosted: 00:18 - 30 Jul 2011    Post subject: Reply with quote
That looks in a similar condition to that my sub-air filter was in.
+1 to the "don't trust previous owner(s) to have done the servicing properly" idea!
-- Ingah
nigel_robbins
PostPosted: 12:18 - 08 Aug 2011    Post subject: Reply with quote
Hi,
Here's an update...
I applied washing up liquid to the foam and washed in warm water.
After rising out with clean cold water I dried as much as I could with kitchen paper.
The filter was left overnight in the airing cupboard to dry. I guess if you don't have time you could also use a hair dryer.
Before refitting I added 30w oil to the foam working it in with my hands.
Thanks for all the replies !
The last post was made 15 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 53.9 Kb
