Balls. broke my sump.
dextersaurus
PostPosted: 16:01 - 31 Jul 2011    Post subject: Balls. broke my sump. Reply with quote
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc6/281298_2076257119774_1645368025_1950641_3338885_n.jpg
So it sprouted an oil leak once i got it running again, and when i went to check the bolt the thing had a big crack down it.
So that's me without a bike for a month till i can afford another one, and i'll have to beg borrow and steal to afford petrol in the car or busses.
Perfect!
Anyway, this is how it looks now, till i can afford a new fairing set.
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/283851_2076111156125_1645368025_1950436_7516579_n.jpg
Dunc
jimspeed
PostPosted: 16:46 - 31 Jul 2011    Post subject: Reply with quote
was that the drain plug? looks like a job for chemical metal to me mate, tip her up so its no longer dripping out, give it a swill with some carb/brake cleaner/petrol and fill the hole up or stick the bolt in with quicksteel or similar..
or take the bus lol Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
dextersaurus
PostPosted: 16:56 - 31 Jul 2011    Post subject: Reply with quote
Yeah it was.
Need to get a new sump now, i'd rather not risk it with chemical metal and the like, then dumping the oil all over the rear tyre at 70+.
Bus it is Sad
Dunc
andys675
PostPosted: 17:23 - 31 Jul 2011    Post subject: Reply with quote
looks like a job for lumiweld
swampy
PostPosted: 17:55 - 31 Jul 2011    Post subject: Re: Balls. broke my sump. Reply with quote
You did that with your balls ?? Shocked
Handsome
PostPosted: 17:57 - 31 Jul 2011    Post subject: Reply with quote
Mr Dunkable wrote:
Yeah it was.
Bus it is Sad
Dunc
B&Q do some chemical metal with a temp of 150 degrees, it's worked on one of my sump plugs after I stripped the thread out of the bottom of the engine, sticks like shit to a blanket...
This is on a bolt and washer though, how you'd get on with it being a gaping crack ( snigger ) I have no idea Dunc...
dextersaurus
PostPosted: 18:04 - 31 Jul 2011    Post subject: Reply with quote
i'd cracked before now, it's when i went to take it off that it broke right off.
It was an oil leak that pointed it out to me.
Dunc
Robby
Dirty Old Man
PostPosted: 21:06 - 31 Jul 2011    Post subject: Reply with quote
Don't mess about with chemical metal, get a new sump. Once you've properly prepped the area (sump off), glued the bit back on with chemical metal, and retapped the thread you probably will have spent the price of a second hand sump on glue and tools. Not many cheap tap and die sets come with M12+ taps.
Plus, the chemical metal will fail horribly anyway.
loply
PostPosted: 21:28 - 31 Jul 2011    Post subject: Reply with quote
I don't think you would necessarily need to re-tap it Rob?
And if you did, you wouldn't need a full set, just a single M12 finishing tap wouldn't set you back more than a quadruple Jack Daniels at a reasonably priced bar.
Personally I would carefully cut some marks in the cracked surfaces to provide additional surface area, prep it with whatever you have to hand (WD40, soap, hot water) and then try liquid metal. I'd be surprised if it doesn't work but clearly the problem will be not re-cracking it when you torque the bolt back up. I'd be tempted to replace the crush washer with an O-Ring.
Whilst you do this insert an M12 thread into the hole so that the liquid metal can't muck the threads up, if you remove it a bit before the metal sets it will come out properly later.
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 22:01 - 31 Jul 2011    Post subject: Reply with quote
If you still have the bit, and prep it properly, lumiweld will be stronger than the original part. Bit more of a fiddle to use than epoxy though.
What it needs is a dowty washer. Bonded rubber seal in a metal washer. Just needs to be nipped up to be totally oil tight so no more over-torquing.
KLR600
PostPosted: 23:22 - 31 Jul 2011    Post subject: Reply with quote
That's creepy, I did exactly the same thing recently except I hit my sump on a kerb!
https://img.photobucket.com/albums/v331/serenaur/IMG_8515.jpg
Probably not much help but I was able to source a second hand sump at a good price by emailing every single breaker on ebay that listed any part for my bike (and some that didn't, I was a bit desperate!) and by putting the feelers out on the owners club forum, basically anywhere that stocked any part for my bike or where other people might know where to find one.
It's not like you've got a rare bike so just keep trawling ebay/breakers and you'll find a cheap one soon enough Thumbs Up
<Take Cool Photos!>
The last post was made 14 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 72.16 Kb
