braided lines - goodridge or HEL?
el_oso
PostPosted: 12:07 - 01 Aug 2011    Post subject: braided lines - goodridge or HEL? Reply with quote
anyone have any experience with these companies? also couldn't find any information about warranties for the goodridge kit. goodridge kit comes with zinc plated mild steel, HEL is completely stainless and comes with full lifetime warranty.
HEL kit direct from HEL £49.36
Goodridge from Amazon £40.74
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 12:18 - 01 Aug 2011    Post subject: Reply with quote
Goodridge do several different finishes I think. Just do not under any circumstances buy any with alloy fittings (not sure they are even available anymore).
I would be equally happy with either in stainless steel. But if the shinyness didn't bother me for that bike I would be inclined to save money and have the plated fittings.
PostPosted: 12:29 - 01 Aug 2011    Post subject: Reply with quote
I have Hel lines on my TDM and have been happy with them. Thumbs Up
MarkJ
PostPosted: 12:33 - 01 Aug 2011    Post subject: Reply with quote
I've always used HEL and they've been great Thumbs Up
Had some Goodridge lines on the RSV which didn't have the plastic covering. Not sure if they were cheaper because of this or if Goodridge never supply them without the cover, but when they're just bare braided lines they can chew into mudguards & fork legs if they rub.
DrDonnyBrago
PostPosted: 13:01 - 01 Aug 2011    Post subject: Re: braided lines - goodridge or HEL? Reply with quote
What bike is it for?
Hel kits direct from Hel are normally more expensive than from elsewhere.
As it happens I have HEL lines, they are very well made, look nice etc etc etc..
WannaBeDude
PostPosted: 13:03 - 01 Aug 2011    Post subject: Reply with quote
I have Venhill front and Hel rear ! Embarassed Thumbs Up
el_oso
PostPosted: 14:17 - 01 Aug 2011    Post subject: Reply with quote
bike is a thundercat
HEL kit direct from HEL is ~£50, wemoto ~£56 + delivery.
if anyone can point me to a HEL kit with stainless fittings for less than £50 you will be rewarded with karma
Duke 390
PostPosted: 14:23 - 01 Aug 2011    Post subject: Reply with quote
Sounds like Hel is cheapest direct, but also double check both are the same kit (ie, 2 line / 3 line).
In use there should be no difference between Hel and Goodridge if you buy the same spec. But Goodridge do more specs of kit.
Irn-Bru
PostPosted: 14:28 - 01 Aug 2011    Post subject: Reply with quote
Got HEL lines for my DRZ not long ago, spot on, rear is a bit too good now though, locked it up a few times at first Embarassed
DrDonnyBrago
PostPosted: 14:37 - 01 Aug 2011    Post subject: Reply with quote
Get them from here:
https://www.helmobile.com/hel-performance-brake-lines-for-yamaha-yzf600-r--thundercat--1996-2002-318-p.asp
and use the discount code FORUM.
£58 for 2f front and 1 rear line with free delivery.
Can always email them and ask how much just for the 2f front lines.
el_oso
PostPosted: 14:41 - 01 Aug 2011    Post subject: Reply with quote
the HEL kit is direct replacement. 2 lines straight from the mc.
Duke 390
PostPosted: 14:45 - 01 Aug 2011    Post subject: Reply with quote
Excuse me being picky but that is not a direct replacement (although suspect the Goodridge kit is the same). Stock will be 3 lines at the front, one from the master cylinder down to a splitter, and then a couple of further lines, one to each caliper.
Which is a better system is a whole different kettle of fish. The 2 line setup means finding a way to locate the new lines so they do not rub.
el_oso
PostPosted: 15:02 - 01 Aug 2011    Post subject: Reply with quote
stock is 2 lines straight from the master cylinder on my bike. there is no y-splitter.
Duke 390
PostPosted: 15:08 - 01 Aug 2011    Post subject: Reply with quote
That is a surprise. Pretty unusual to do it like that on a production bike (adds about 1/3 more length of hose to expand).
el_oso
PostPosted: 15:15 - 01 Aug 2011    Post subject: Reply with quote
i thought so as well. never before seen a race set up it on a bike without braided lines.
Duke 390
PostPosted: 15:27 - 01 Aug 2011    Post subject: Reply with quote
It is cheaper though. If they are desperate to save costs. The pipe costs next to nothing compared to the fitting, banjo bolts and the splitter.
Race style makes it sound like they are better. Rather than just complying with a requirement for racing that they hoses can't split below the bottom yoke.
Dazbo666
PostPosted: 18:12 - 01 Aug 2011    Post subject: Reply with quote
Had Goodridge line on the GPZ, and currently have HEL lines on the Bandit.
In my experience, the quality, performance and visual appearance is all VERY similar... however I prefer to go stainless with fittings, cos I ride all year round, and want to reduce the likelihood of corrosion etc
Word of the day : DILLIGAF
stonesie
PostPosted: 19:17 - 01 Aug 2011    Post subject: Reply with quote
DonnyBrago wrote:
Get them from here:
Karma has been given Karma
£61.50 for 2 front lines and a rear for my SV650S with the delivery charge Thumbs Up Mr. Green
el_oso
PostPosted: 19:22 - 01 Aug 2011    Post subject: Reply with quote
i have also decided to go with stainless fittings. really couldn't deal with the corrosion as i ride all year.
goodridge with stainless fittings is £48.
HEL is £50 with coloured PVC shield and coloured stainless fittings.
the prettier ones won it for me, plus they had lifetime warranty. still unable to find warranty info about goodridge lines
Duke 390
The last post was made 14 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 108.81 Kb
