Sealing Airbox Snorkels
WannaBeDude
PostPosted: 13:22 - 01 Aug 2011    Post subject: Sealing Airbox Snorkels Reply with quote
Mine are plastic / ruberry things, and i can see they need gaps refilling. What do i use, and could this be an issue that caused stuttering in the rev ranges due to too much air getting into the mix.
2T 125 naked mito btw. Ta Smile
Thumbs Up Karma
Bezzer
PostPosted: 14:32 - 01 Aug 2011    Post subject: Reply with quote
Put a bead of silicone round the outside that'll seal it fine.
Small gaps shouldn't be letting that much extra air in to have much of an efffect on the running but at least you'll know when you've sealed it.
WannaBeDude
PostPosted: 14:34 - 01 Aug 2011    Post subject: Reply with quote
Thanks,
What sort of silicone ? would like to order some off fleabay today ! Thumbs Up Karma
Bezzer
PostPosted: 14:51 - 01 Aug 2011    Post subject: Reply with quote
Any type really for that bit of a job, be cheaper and good enough to get some domestic bath/window type from a DIY place. If you want to get the better stuff you can get silicone gasket sealer from a Motor Factor place or even Sikaflex.
WannaBeDude
PostPosted: 15:11 - 01 Aug 2011    Post subject: Reply with quote
Cool, i've got some bathroon stuff, will use that ! thanks again Karma
PostPosted: 15:15 - 01 Aug 2011    Post subject: Reply with quote
That should seal them, but I wouldn't expect a minor leak there to cause any issue at all. The difference in the mixture will be tiny (it is still going to go through the air filter)
Above assumes that it is the snorkel into the airbox that is in question, rather than the pipe from the airbox to the carb.
WannaBeDude
PostPosted: 15:47 - 01 Aug 2011    Post subject: Reply with quote
I've used a bit of frame sealant, another job done, i've done a lot for me, over the last 2 weeks or so, i've saved the hard bit till last, getting her running ! Laughing
The last post was made 14 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 52.46 Kb
