Author |
Molten_Fire |
 Molten_Fire L Plate Warrior
Back to top |
unitynotsocri... |
 unitynotsocri... Banned
 Posted: 19:53 - 01 Aug 2011 Post subject: |
i think it should be a two pin relay.try Wemoto there about £8. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
Back to top |
Molten_Fire |
Back to top |
unitynotsocri... |
 Posted: 21:00 - 01 Aug 2011 Post subject: |
if it came with a three pin relay and thats the wiring on the bike then the power rating on the relay is too high to flash.Eg if you had a relay that was for a slightly higher wattage/bulbs the flashing would be a little slow.the one you've got is probably too higher wattage for the bulbs ,or the two wire relay is being wired wrong .
80 watts is a lot ,i think that a 35/40watt one should do it.A car one will be too much. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
Back to top |
The last post was made 13 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 40.34 Kb
