| Tenko |
 Tenko Could Be A Chat Bot
| Bloggsy |
 Bloggsy Spanner Monkey
| Tenko |
| mr jamez |
 mr jamez World Chat Champion
 Posted: 17:17 - 02 Aug 2011 Post subject: |
Most people I know with old Brit bikes just use unleaded in them.
To have an old engine made suitable for unleaded... you have to remove the cylinder head and replace the valve seats with hardened ones.
To fix an engine that has receeding valve seats due to running on unleaded when it should have leaded... you have to remove the cylinder head and replace the valve seats with hardened ones.
I think you can see where this is going. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| temeluchus |
| temeluchus |
| Tenko |
| hmmmnz |
 hmmmnz Super Spammer
| .Chris. |
 .Chris. World Chat Champion
 Posted: 23:18 - 03 Aug 2011 Post subject: |
I've got an old car which originally ran on leaded fuel and there's several schools of thought as to what to do.
1) Stinkwheel's suggestion - run it until the valves/seats burn out, and either swap another head on, or have the existing one converted. This is a particularly good option if heads are cheap and readily available, as even if you do manage to completely bugger one up, you can just put another one on. Valve seat recession also tends to take many thousands of miles to show, so if you do a low mileage it won't be a problem for ages.
2) Use additives. Be careful what you buy if you decide to do this, as not all of them work properly. The FBHVC did tests shortly before leaded fuel disappeared and not all of the additives tested worked correctly. Castrol valvemaster is approved, and readily available. Costs about £10 for bottle that treats 250l of fuel, so adds about 4p/l to fuel costs. Don't bother with any of the 'fuel catalyst' things you put in the tank - they're pure snake oil.
3) Have it converted. Shouldn't cost too much for a 4v twin - £300 seems very steep, seeing as I had an 8v car head converted for £140 a few years ago.
Any of these routes are equally valid to be honest. If he's only using the bike occasionally, and being gentle with it, I'd be tempted to go with the first suggestion. Particularly so if he can find a spare cylinder head to keep 'in stock', ready to swap over. ____________________ Chris
1985 Kawasaki Z550F |
| HD |
 HD World Chat Champion
| reggie |
 reggie Spanner Monkey
| HD |
 Posted: 10:48 - 04 Aug 2011 Post subject: |
Less of a problem with bikes as most were built also for the US market and so needed to cope with unleaded. Think it is any bike built post 1976 from Honda (for example) that is OK for unleaded (although quite often bikes might have been built before that but not sold until afterwards - possibility that all the CB400/4s fall into that category).
The lead was added to increase the octane rating, but was also found to protect valve seats allowing cheaper ones to be used.
A hell of a lot of bikes do not need even 95 RON fuel, so the octane rating isn't an issue for them (exceptions are mainly European bikes). However it was a problem for cars but most can easily have the ignition timing adjusted to cope with unleaded rather than 4* (will lose a bit of power).
The valve seats are a bigger problem but only to far less vehicles. Without the protection from the lead residue they wear out (and one they start they will fail to seal and burn out even more quickly). You can avoid the problem by either using a suitable additive or replacing the valve seats.
If you are looking at a 1980s car then it almost certainly will have had the timing retarded by now, but might not have had the valve seats done.
The last post was made 15 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
