What makes a motorbike go round corners?
PostPosted: 17:11 - 02 Aug 2011    Post subject: What makes a motorbike go round corners? Reply with quote
Serious question, I have silly ideas from time-to-time and it occurred to me that I'm not really sure.
Not asking how you initiate a turn, what actually makes it go round the corner once it is leaned over and not just carry on in a straight line while leaning over.
Is it the weight of the rider in relation to the bikes centre of balance? The angle of the wheels in relation to one another? The differing angles of gyroscopic force in the wheels? The angle of the tyre contact patch in relation to the angle of the road surface?
Fisty
PostPosted: 17:13 - 02 Aug 2011    Post subject: Reply with quote
All of the above.
And magic.
Fatter and faster than Fret
Pickledswede
Isn't it because due to the profile of the tyre, when it's leaned over the corner side of the contact patch has a smaller circumference than the furthest away bit, meaning it travels less far for every one turn of the wheel?
-Edit- Reading this back it seems a bit confusing.
When a tyre is travelling standing straight up, every ring around the tyre within the contact patch (so for example a millimetre width of tyre the entire way around the circumference) is the same length. However when you lean it over a different patch is in contact, on the side nearest the centre of the tyre the ring around the tyre is one length, and due to the shape of the tyre, the ring furthest from the centre (and on the side of the corner) is shorter, all the rings in between will be different lengths from large to small. The longer circumference near the centre of the tyre means one turn of the tyre is further on the ground than it is on the other side of the contact patch.
Scythe
PostPosted: 17:22 - 02 Aug 2011    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Bicycle_and_motorcycle_dynamics
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
No cheating here even tho i have read about it.
You need momentum to corner. Once in a leant state it is gravity, centrifugal force and the amount of that momentum will affect how it goes around the corner.
Yes. A Tall heavy rider will affect like a small but heavy..or light. Plenty of racers hang an inside leg whilst having their (heavy) head as far down as possible.
Chew on that. Mr. Green
PostPosted: 17:26 - 02 Aug 2011    Post subject: Re: What makes a motorbike go round corners? Reply with quote
They kind of explain it in the "A twist of the wrist 2" DVD.
Yes.
No.
Andy_Pagin
PostPosted: 17:27 - 02 Aug 2011    Post subject: Reply with quote
Okaay.. Either grab yourself a degree in mechanical engineering (or at least 'A' levels in physics & pure & applied maths) and it will all become clear (probably Confused ),
or...
like the rest of us thickos, just accept it's 'magic' Very Happy
PostPosted: 17:29 - 02 Aug 2011    Post subject: Reply with quote
I don't know if this can be the case. If you put car tyres on a motorbike, it still goes round corners.
flat spot
PostPosted: 19:56 - 02 Aug 2011    Post subject: Reply with quote
Here's a practical thing to do. Hold a push bike wheel by its axles and get it spinning. A big wheel off a racer is best. When you lean the wheel over forces actually turn the wheel in your hand (right or left) the way it you would want to corner if you lean that way on a bike.
It's sort of difficult to explain, but if you do it all will become clear. It's also quite entertaining for a while.
ajbsmirnoff
PostPosted: 20:12 - 02 Aug 2011    Post subject: Reply with quote
stupid wine induced double posting
ajbsmirnoff
PostPosted: 20:13 - 02 Aug 2011    Post subject: Reply with quote
Howling Terror wrote:
centrifugal force :
wouldn't it be centripetal force - the force pulling you towards the point around which you are turning ?
while cetrifugal pushes the tyres onto the diesel soaked tarmacadam for purchase and such ?
Tristan.
PostPosted: 20:27 - 02 Aug 2011    Post subject: Reply with quote
Read John Robinsons "Motorcycle Tuning: Chassis" explains it very well in the first chapter. In short it's a combination of the radial thrust due to the profile and position of the tyres (similar to what pickledswede said) balanced with the weight distribution body position etc.
Cheeseybeaner
PostPosted: 20:30 - 02 Aug 2011    Post subject: Re: What makes a motorbike go round corners? Reply with quote
The wheels.
binge
Emo Kiddy
PostPosted: 20:40 - 02 Aug 2011    Post subject: Reply with quote
When a wheel is upright, the "leading edge" of the tyre falls directly in front of the current contact patch on the road.
When a wheel is lent over, the leading edge of the tyre is now off center to the "center line" of the bike.
Ben
Killer Rat
PostPosted: 20:44 - 02 Aug 2011    Post subject: Reply with quote
on the way home tonight i was pondering stinky's question and have noticed that on some bends with my bike (cbf125) if i take a sharp bend in 2nd at 30mph i can keep the bike on the tyre line, however, the same bend at the same speed but in 3rd gear i find the bike veering into the oncoming lane.
I was wondering if revolutions come into play when holding a line.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
binge
Emo Kiddy
PostPosted: 20:48 - 02 Aug 2011    Post subject: Reply with quote
They sure do!
I've taken corners in the past on my TLR at 40mph, and the bike has been practically upright.
Take the same bend at 130mph, and you've pretty much got your knee on the deck.
Ben
Killer Rat
PostPosted: 20:52 - 02 Aug 2011    Post subject: Reply with quote
They sure do!
Ben
*doffs hat* Karma
binge
Emo Kiddy
PostPosted: 21:01 - 02 Aug 2011    Post subject: Reply with quote
Killer Rat wrote:
*doffs hat* Karma
I've just re-read your questions, and realized that I've answered it slightly wrong, although the statement is still true.
The point you're getting at, is that at low RPM (Gear too tall for the speed you're doing), causes the bike to run wide into the corner.
The reason for this, is because the RPM is so low, it gives a sensation of "coasting", which also causes a bike to run wide.
Ben
PostPosted: 21:06 - 02 Aug 2011    Post subject: Reply with quote
OT. Know one thing. Smile A bike that's set for the rider doesn't half feel nice in a corner Finally got round to tailor the duc to my weight..Life is good. Thumbs Up
Couldn't it be centripetal force - the force pulling you towards the point around which you are turning ?
sounds more like it. Mr. Green
Last edited by Howling TerrorOutOfOffice on 21:08 - 02 Aug 2011; edited 1 time in total
Skudd
Yes. A Tall heavy rider will affect l:
just what are you trying to say? Shocked Laughing
PostPosted: 21:09 - 02 Aug 2011    Post subject: Reply with quote
My understanding is that it is the shape of the tyre that causes the bike to gor round a circle. Like a cone rolling on its side.
Leaning over more just means steeper angle of the cone and the tighter the circle. But that needs to be counterbalanced with the centrapedal force pushing the bike to lean in the opposite direction and gyroscopic forces leaning it over.
^^^@Skudd. Nowt probably...
Thank fuck keith turned up.
PostPosted: 21:13 - 02 Aug 2011    Post subject: Reply with quote
I could well be wrong, or missing a major factor.
Skudd
karoshi
PostPosted: 22:36 - 02 Aug 2011    Post subject: Reply with quote
can't think that the rpm of the wheel would make the difference though, it's still - roughly - the same size, if you could take the same line through the corner in 2nd and in 3rd the same bit of tyre would hit the same bit of road?
however at the higher speed the mass of the bike has more momentum going forwards which will overcome the grip of the tyre more forcing the bike wider.. which is why racing slicks give faster laptimes?
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
The last post was made 15 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 15 - Page Size: 136.46 Kb
