125cc Vulcan not starting
andyboy359
PostPosted: 20:00 - 03 Aug 2011    Post subject: 125cc Vulcan not starting Reply with quote
Hi.
My bro in laws Vulcan 125 will not start we have
1. got a new spark plug, coil and htc cable
2. charged the battery
3. checked all electrics (they all work)
4. checked carb and cleaned it.
When we try to start the bike from start it engine just wont start same with kick start, but when we bum it the engine TRYS to turn over how ever it will not. There are no mods on the bike.
Thank you guys.
andrew dunne
lozza59
PostPosted: 01:14 - 04 Aug 2011    Post subject: Reply with quote
do you have a spark at the plug? when did the bike last run?
Frost
PostPosted: 01:20 - 04 Aug 2011    Post subject: Reply with quote
Tried flushing the system and fresh fuel?
Tried turning it over a bit without the plug in to make sure it'd not flooded?
Tried touching the spark plug side against the engine when kicking it over to see if there's a spark?
made sure the float height is correct, the jets aren't blocked, the carb is sealed on properly, checked throttle cable slack, checked the choke isn't stuck on?
IF all else fails you might need to compression test it, but thats probablyt he last thing you'll need to try.
lozza59
PostPosted: 01:21 - 04 Aug 2011    Post subject: Reply with quote
you cant persuade it to start with a good bum then? lol
andyboy359
PostPosted: 13:06 - 05 Aug 2011    Post subject: Reply with quote
Yes it has spark.
we cleaned the carb.
tried it with out the spark in it.
checked choke cable, it is cut, so you just trun it on and off at the carb, and throttle it fine.
and i think jets are fine Razz
what ells d you think it could be Sad
andrew dunne
andyboy359
PostPosted: 16:32 - 05 Aug 2011    Post subject: Reply with quote
worked out the problem, we "think" it is the rods in the head of the engine that push the exhaust vale and in take vale one was broken Smile so ordered new ones and gona give the bike an oil change Very Happy thanks guys
andrew dunne
andyboy359
PostPosted: 17:59 - 07 Aug 2011    Post subject: Reply with quote
It was the push rods we put the new ones is with some new oil and she runs fine Very Happy thanks guys.
andrew dunne
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 50.79 Kb
