MOT Passable (body work)?
J.M.
PostPosted: 21:27 - 03 Aug 2011    Post subject: MOT Passable (body work)? Reply with quote
edit:
for anyone interested, how I've fixed the chain guard is in my last post.
original
Hey everyone,
I've got my first MOT (not the bike's) coming up at the end of November (yes I know it's a while away). I just want to make sure that I've got absolutely no problems with the bike before I take it there because, well, I don't exactly have the cash to throw at a re-test that I could have saved myself from.
Mechanically the bike feels great, and I'm not worried about that, and the tires still have more than enough tread, but there are a few places on the bodywork that I'm slightly concerned about - so I'd really appreciate if someone could comment whether they're okay or not.
I'm attaching the images to this post, but I'll describe them here:
This is the chain guard (if that's it's name). The damage was done before I purchased the bike but I've had a bit of Gather tape holding it together without problems - I took it off for the photo.
Again, damage done before I bought the bike. The fairing is secure - I'm just not sure whether having a zip-tie there will cause a fail or not?
The same situation here, damage done before I bought the bike - so the same zip-tie question.
The other part, if you've got a keen eye, is the indicator. I had a fall small off back in April at low speed and caused the crack you see left of the zip-tie and broke the indicator off. I repaired the indicator and tested it, it all works fine, and the solder is covered by waterproof electrical tape. Because the indicator snapped off, it's held together by the Gather tape. It's secure, there's no play in it, and it all works fine which I can tell you because I've been riding this bike everyday since the repair with no problems (even in heavy rain).
The only other 2 slight things:
The full beam button sometimes sticks - The neutral light doesn't work (I've replaced the bulb and checked the fuses).
So what's everyone's thoughts. Should this pass, or do I need to start searching my pocket with a magnifying glass?
Cheers![/b]
2004 R1 & 2018 XSR900
PostPosted: 21:29 - 03 Aug 2011    Post subject: Reply with quote
Bodywork's not an issue provided it's not hanging off.
Chain guards possibly an advisory, nothing more than that.
J.M.
PostPosted: 21:31 - 03 Aug 2011    Post subject: Reply with quote
Nope, nothing's hanging off at all. Everything feels secure to me as well. I just tend to worry, so I wasn't sure if bodywork being like it is would fail me.
Just asking early because if it is, I need to account for it now so I can afford to buy them before the test! Razz
Thanks for your answer Smile
Bezzer
PostPosted: 22:44 - 03 Aug 2011    Post subject: Reply with quote
Neutral light doesn't matter but a sticking main beam would fail the MOT. Take the switch off clean it with contact cleaner and see what's catching/sticking before you have it MOT'd.
Have a look at the chainguard they always stamp the type of plastic on them, it'll be on the inside somewhere. If it's ABS or uPVC types you can use solvent weld on it to stick it together so you'd hardly know. If it's a poly type then it's a two part epoxy type adhesive you'd need.
The more you do to make it presentable the better the tester will feel about it, all the little issues together would ring alarm bells and make him really look it over passing nothing up.
J.M.
PostPosted: 22:50 - 03 Aug 2011    Post subject: Reply with quote
Okay thanks,
I was thinking I'd have to purchase a new chain guard, but I'll check out the plastic to see if it's repairable like you say - that would be good to do even if it's not needed.
Right okay. The high beam has never really been an issue for me as 99% of my riding is done while it's bright out - the rest of the time I just use my thumb to hold it in so it's at a point where it's on - but not clicked.
But fixing it was always a priority to do. Is it a tricky job at all? I ask because I don't want to risk causing damage to the likes of the horn/indicators.
Cheers Smile
Bezzer
PostPosted: 22:56 - 03 Aug 2011    Post subject: Reply with quote
Bike switches are usually very simple things but fiddly, just take it off and have a look inside, hopefully the main beam switch part is easily accesible so you can check it out.
J.M.
PostPosted: 23:08 - 03 Aug 2011    Post subject: Reply with quote
Alright cheers Smile I'll hopefully get chance to take it off tomorrow and give it a look.
PostPosted: 00:18 - 04 Aug 2011    Post subject: Reply with quote
Bodywork is fine, unless it can foul a moving part or has sharp, sticky-out bits that could injure someone.
The chain guard might fail because it can foul the chain. I'd glue it up for the test.
First off with your switch, I'd scoosh loads of WD40 into it and switch it on and off a good few times. This alone will normally fix a gummed up switch.
J.M.
PostPosted: 00:20 - 04 Aug 2011    Post subject: Reply with quote
Okay then, I think I'm safe with the body work because I haven't found any bits which seem dangerous at all to me - and I've been riding it about 4 months now.
Would gluing it up pass an MOT though, surely if they tugged it at all it could give way again?
Thanks, I'll give that a shot before I take it apart! Smile
PostPosted: 01:50 - 04 Aug 2011    Post subject: Reply with quote
Dependes how well glued and with what glue.
I personally couldn't give a crap about aesthetics so i'd glue a strip of plastic to the outside with hot glue or (if it's the right sort of plastic) a solvent glue like jordanmoore mentions.
Another trick I've heard of but never tried is to melt a lego brick in acetone and use that to glue over the broken bit.
el_oso
PostPosted: 13:27 - 04 Aug 2011    Post subject: Reply with quote
gluing it may prove to be difficult. i would put two strips of aluminum across the join and bolt them together
https://www.bikechatforums.com/files/fixing.png
Duke 390
Car: Jeep Wrangler 4.0L
J.M.
PostPosted: 13:35 - 04 Aug 2011    Post subject: Reply with quote
Right then, looks like I've got some methods to try with repairing the chain guard - I'll see what bits and pieces I can find later one (once the weather cheers up a bit) and then decide what to do.
One thing I was thinking though - a bit of plastic on the inside and then use a soldering iron to melt it all together?
I guess that I'll probably try the melting/gluing first, then if that's to no avail I'll try the aluminium across it with the bolts.
Also I'd just like to note that I've managed to get the full-beam button not sticking any more by using a bit of WD40 on it - took a while but it's working just great now Very Happy
jimbothe
PostPosted: 13:58 - 04 Aug 2011    Post subject: Reply with quote
Tie wraps for the win. Bodge tools of the gods.
https://i22.photobucket.com/albums/b342/jgillard/IMAG0049.jpg
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 14:13 - 04 Aug 2011    Post subject: Reply with quote
This is what I would do Thumbs Up
Bezzer
PostPosted: 14:21 - 04 Aug 2011    Post subject: Reply with quote
They certainly are Very Happy but he's trying to tidy it up a bit for the MOT , always best to do tidier repairs if you can else it's going to be covered in them what with the fairing as well and the tester will give it right going over.
PostPosted: 16:31 - 04 Aug 2011    Post subject: Reply with quote
Black tie wraps then. Thumbs Up
jimbothe
PostPosted: 16:50 - 04 Aug 2011    Post subject: Reply with quote
It's still going to be tidier than flapping around and it will at least look like he has acknowledged the problem and has tried to do a efficient temporary repair.
Excuse me while I go and lie down after using all those big words. Laughing
Bezzer
PostPosted: 17:33 - 04 Aug 2011    Post subject: Reply with quote
Yep same as he's acknowledged all the other stuff, zip ties all over the fairing, gaffa taped front indicator etc, you see all that and the chainguard as well and it will get a right going over to make sure nothing is else is hidden or bodged and picked up for the slightest thing.
jimbothe
PostPosted: 18:50 - 04 Aug 2011    Post subject: Reply with quote
Sometimes it's the bikes that look like a pile of shite that knock spots off the bikes that look mint.
I've had my fair share of 'shitters' that have sailed through mot's.
I would think a chap who has taken the time to notice and repair a broken lug or fairing, however it has been done would not miss much mechanically, whereas a guy who does nowt but constantly clean and pretty up his bike 'can' be the complete opposite and miss such things as dodgy electrics and worn bushes / bearings etc.
Just saying, don't judge a book by it's cover as it doesn't always make for good reading. Wink
J.M.
PostPosted: 20:35 - 04 Aug 2011    Post subject: Reply with quote
I'd like to stray away from those zip-ties if possible - don't want too many on there for the MOT as already mentioned Wink
I guess I'll try and to a tidy repair first, if that fails it's a flip between the zip-tie / aluminium methods!
Ideally I'd love to get the bike looking mint, but I feel that getting my test out of the way is really the more important thing - it's already been 4 months!
I don't personally feel that there's anything else wrong with the bike at all other than mentioned - so I'm hoping to be a happy chappy when I have to take the dreaded ride over there Razz
st3v3
PostPosted: 01:34 - 05 Aug 2011    Post subject: Reply with quote
Nothing wrong with Bostic and cable ties... Laughing Laughing
Stinkwheels' first post was exactly my input here, but he bet me. Neutral Razz
Btw, Gaffa tape, is gaffa. What's Gather tape? Mr. Green
J.M.
PostPosted: 19:12 - 05 Aug 2011    Post subject: Reply with quote
Right you are, just cautious about using too many! If there is such a thing Wink
Ah yes, Gaffer, I'm sorry - I've never seen the word written down before Very Happy
J.M.
PostPosted: 14:09 - 09 Aug 2011    Post subject: Reply with quote
For anyone interested - this is the chain guard after my attempt to fix it!
Sturdy as the rest of the chain guard, just not quite as.. elegant. Razz
I managed to find some similar material and just grabbed my soldering iron. Melted the extra material into the join and then mucked up the top, bottom and sides a bit to mix the material from either side of the break in with the new material to make a solid join.
Then, if you can tell, I tried to make it a tad tidier with sandpaper - but it didn't really do much!
Either way, I don't think that should be breaking again - and it looks more tidy in my opinion Very Happy
jimbothe
PostPosted: 18:15 - 09 Aug 2011    Post subject: Reply with quote
It's done the job mate thats the main thing. Thumbs Up
If you can be arsed to tidy it up more then use a blow lamp and move it over the area making sure not to leave it in one place too long and simply smooth it over with a wet finger. Works a treat.
J.M.
PostPosted: 23:28 - 09 Aug 2011    Post subject: Reply with quote
Alright then, cheers! If I can find one lying around somewhere I'll be sure to give it a go Smile
The last post was made 15 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 134.57 Kb
