Dual Carriageway Roundabouts
Chriss
PostPosted: 10:27 - 04 Aug 2011    Post subject: Dual Carriageway Roundabouts Reply with quote
Hi,
I have a few questions, relating to what is seem as right and wrong.
Is it seen as acceptable to use lane 1 of 3 lanes to take the 4th exit off a roundabout?
Is it just as wrong to use lane 3 to take the 3rd exit off a roundabout?
Roundabout in question below, including streetview. Travelling north east on the A1:
https://img199.imageshack.us/img199/6383/a1roundabout.png
https://img810.imageshack.us/img810/5506/a1streetview.png
Thanks for thoughts.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 10:31 - 04 Aug 2011    Post subject: Reply with quote
As in the far left lane....all the way round the roundabout?
Laughing If so, I wouldnt try it...thats what the furthest right hand lane is for Neutral
I would also use the 3rd lane for 3rd exit... highway code book thing would probably agree...
Chriss
PostPosted: 10:37 - 04 Aug 2011    Post subject: Reply with quote
Well, turning right effectively.
I will elaborate in case you didn't realise. 3rd exit in this case is straight ahead.
PostPosted: 10:38 - 04 Aug 2011    Post subject: Reply with quote
Sorry, was just using the main roads as a guide.
3rd exit then, i'd be in the left or middle lane. Not the outside one.
chillyman0
PostPosted: 10:46 - 04 Aug 2011    Post subject: Reply with quote
I use Middle lane for straight over on that roundabout, you could also use the left but I wouldnt use the 3rd as you would probably end up cutting someone up
As for the left lane to go all the way round, if someone did that and cut me up their rear wing would get a hefty boot!
1996 gsf600n (sold)
Chalky.
PostPosted: 10:47 - 04 Aug 2011    Post subject: Reply with quote
I would say
Left turn - Lane 1
Straight on - Lane 1 and 2
Right - Lane 2 and 3
T.C
PostPosted: 11:01 - 04 Aug 2011    Post subject: Reply with quote
Chalky. wrote:
I would say
Left turn - Lane 1
Spot on
If you were to use lane 1 (left hand lane) to take the third exit, not only do you leave yourself wide open to being taken out, you would not have a leg to stand on as far as any claim is concerned as you would be held liable.
You also create the possibilty of being successfully prosecuted for a minimum of careless driving.
As mentioned above, lane 1 for 1st exit or straight ahead, lane 1 or 2 for straight ahead (unless arrows or road markings direct otherwise) and anything beyond 12 0'Clock right hand or outside lane only.
This rule also applies for 2 lane carriageways.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Chriss
PostPosted: 11:10 - 04 Aug 2011    Post subject: Reply with quote
Thanks for the input all, with an authority like T.C. agreeing with you all, I feel that's well and truly answered.
Personally, I was using:
Lane 1 for 1st and 2nd exit
Lane 2 for 3rd exit only (straight a head)
Lane 3 for 3rd and 4th exit
Here is why I asked. Looks like I cut up the funny little white car in the video but at the time it was clearly going straight ahead, which it did, hence I over took it.
Learn from mistake kids! Embarassed
UnknownStuntm...
PostPosted: 11:19 - 04 Aug 2011    Post subject: Re: Dual Carriageway Roundabouts Reply with quote
Bicycles can use lane one to go round as far as they like - worth remembering if there's one about - I've seen it look like they're coming off at an exit then continue... And the Highway Code agrees with this behaviour.
PostPosted: 11:31 - 04 Aug 2011    Post subject: Reply with quote
Chalky. wrote:
I would say
Left turn - Lane 1
Agreed.
Although its not uncommon for cagers to use lane 3 for straight on and cut you up when your turning right. As has happened to me a couple of times. Normally by inidans oddly enough.
Deaks
PostPosted: 12:03 - 04 Aug 2011    Post subject: Reply with quote
That fiesta driver was being a knob. Theres no way you should be using lane 1 for turning right.
I have to survive something similar on my way to work and will regualarly see people using lane 1 for turning right, even though the lanes are actually labelled.
I react the same way as well, if I dont end up hitting them, look directly at them a couple of times then shake my head in a 'I'm not angry, I'm just disappointed ' way.
Suzuki SV650S '04 (09/08-02/11), Triumph Tiger 1050 '07 (02/11 - current).
Live to Ride. Ride to Feel Alive.
l0p0l
PostPosted: 12:20 - 04 Aug 2011    Post subject: Reply with quote
I totally agree with Chalky ! Living in Milton Keynes I am fairly use to three lane dual carriageway roundabout approaches.
Just make sure if you are going straight on or right, you check that left shoulder after the 1st exit. Many folks especially the older generation tend to either go straight on using lane 1, or worse will carry on right around the roundabout. Rolling Eyes
Kawasaki ER6n
Looking for 60's BSA / Triumph project
PostPosted: 12:22 - 04 Aug 2011    Post subject: Reply with quote
Thats...correct though... Laughing
Peirre oBollox
PostPosted: 21:04 - 04 Aug 2011    Post subject: Reply with quote
Slightly off topic
If the vehicle was an HGV, the rules for lane discipline are slightly different. IF lanes 1 & 2 where both marked with White arrows as right turn lanes & the exit point for both lanes where the same. Then technically an HGV is supposed to use the lefthand one of the 2 lanes, As certain rules of the highway code such as lane discipline, & speed limits for trucks are different to other types on the road.
which is probably why you end up cursing truck drivers for driving past the exit you though they should have taken
Killer Rat
PostPosted: 21:22 - 04 Aug 2011    Post subject: Reply with quote
Chalky. wrote:
I would say
Left turn - Lane 1
This^
Although at times i find it easier to follow the painted arrows as this is what i expect cagers to do.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
The Tot
PostPosted: 21:33 - 04 Aug 2011    Post subject: Reply with quote
Ahh that old chesnut!
It's a dodgy roundabout because the lights only operate at peak time, and because it's on a national speed limit, you get guys who just straightline the roundabout and keep their feet planted!
But in that case, I keep left if I want to go to Elstree/Bushey (lane 1). Keep in the middle lane if I'm heading up to Hatfield (Lane 2) and if I need to up to Barnet, it's Lane 3. And i stick to that. You're in the borderline zone where driving standards are shocking, i.e. the moment you breach the M25, expect people to drive like idiots, and because it's NW London, prime culprits are asian women! They don't look. And if they see a bike coming on the roundabout, they're like deer in headlights, despite the fact it's priority to traffic on the roundabout! I've seen many near misses on that stretch. It also doesn't help that the roundabout is cambered with trees in the middle of it!
I move into lane 2 on the exit before the one you're going to take. On a bike, I'd like to have the safety of not being sideswiped by a car whose not seen me! Unless its the immediate exit, I never position myself left in case inattentive drivers are joining. Also beware that on the barnet exit, you have that shell garage, so cars pulling in and pulling out. Leaving that space = safety and visibility (unless like me you exit the roundabout >40mph!)
If I want to avoid that roundabout, I get off at Apex corner and head for the totteridge exit through the back of Mill Hill County High
Never argue with autism
bikertomm
PostPosted: 21:45 - 04 Aug 2011    Post subject: Reply with quote
Chalky. wrote:
I would say
Left turn - Lane 1
What Chalky said Thumbs Up
Skudd
PostPosted: 22:01 - 04 Aug 2011    Post subject: Reply with quote
T.C wrote:
Chalky. wrote:
I would say
Left turn - Lane 1
Spot on
I would add to this in as much that if you were a slow moving vehicle or horse rider then the left lane would be the more correct lane to use, also that I would say that you should return to the left hand lane at the earliest safest oppertunity provided lane markings and signs don't say otherwise. If you are in the second or third lane be prepared for those in the first lane who may be taking their first or second exit which may be your second or third exit.
Moo.
PostPosted: 22:24 - 04 Aug 2011    Post subject: Reply with quote
Jesus! That black fiesta was in the wrong! But it looks like they had no clue where they were going and just switched last minute.
Ive always been told, if the turning you want to take is past the 12 o clock position from where you enter the roundabout, use the inside lane (lane 2/3 in this case) But i'd say use lane 3 for going all the way around or 2nd to last exit, something like that.. Very Happy
A2 Passed 18/6/10
Jim Mc
PostPosted: 23:29 - 04 Aug 2011    Post subject: Reply with quote
As far as I'm aware because there are no specific markings on the lanes, you may use any lane for any exit.
Although common sense dictates you would not do this.
D O G
PostPosted: 00:16 - 05 Aug 2011    Post subject: Reply with quote
If it was light traffic, I'd be using all three!
cagiva gezzer
PostPosted: 11:54 - 05 Aug 2011    Post subject: Reply with quote
I use that roundabout heading out of London a couple of times a week (however I mainly take Tot's Mill Hill route). I'm always in lane three going straight ahead. You also have to take into account how many lanes are coming off.
In this case there's three on, three off, with enough space all the way around the roundabout.
Thinking about it, there are a lot of people in lane two going right, going north or south. . . .
Chriss
PostPosted: 11:58 - 05 Aug 2011    Post subject: Reply with quote
Aye, but I think we're doing it wrong according to T.C. and as pointed out, we are a risk of cutting people up in lane 2 turning right heading towards Barnet.
Also, a side note, the petrol station there doesn't have an exit onto the roundabout as far as I'm aware, at least not since it was rebuilt.
The last post was made 15 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 123.39 Kb
