1996 zzr600 pointers
Mrjoolz
PostPosted: 12:01 - 04 Aug 2011    Post subject: 1996 zzr600 pointers Reply with quote
Guys,
Looking at a ZZR600 tomorrow. 1996 on an N with 12,000 miles on it. Can you please give me a list of potential things I can look for to make sure its a good deal.
I'm hoping to take it out for a quick blast, and wondered if there are any things to check for, i.e. fork seals.
many thanks guys.
Joolz
PostPosted: 12:06 - 04 Aug 2011    Post subject: Reply with quote
Downpipes, Kawasaki "RustSpecial" was an option at the factory. Ifits fitted with stainless, thats a bonus Thumbs Up
12,000 seems overly low for what most people would consider a sporty-ish commuter. Especially a 1996 Neutral
Usual things... tyres, check the brakes, when the valves were done... not sure if they are every 12k or 15k??
Check corrosion on rear suspension. Fork seals should be noticeable straight away, just check for any signs of rust appearing on the fork stanchions, these will obliterate seals quickly.
PostPosted: 12:19 - 04 Aug 2011    Post subject: Reply with quote
Really check the brakes on these they are dire.
Mrjoolz
PostPosted: 12:28 - 04 Aug 2011    Post subject: Reply with quote
Funnnily enough I also thought 12k was low for it. One fork seal has gone and already, and they said they would replace.
I wonder hard it is to put mileage back on these bikes?
Gyres look fine. Has stainless down pipes on it which were replaced last year
too fast
PostPosted: 12:31 - 04 Aug 2011    Post subject: nothing Reply with quote
just check for normal service items - brakes (seals should be replaced regularly), swing arm & linkage bearings, headstock bearings, wheel bearings. At that mileage it should have a service history. Very revvy bike so valve clearances are critical. Avoid if it has been played with as they loose low end power with 'race end cans' and dynojet kit. Won plenty of races when they first came out, and they handled better than the ZX6F model for similar weight (ZZR600 430Lb, ZX6F 400Lb ) - allegedly - brakes were the same too
PostPosted: 12:31 - 04 Aug 2011    Post subject: Reply with quote
Good when looked after though. I heard that ZZR600s were heavy on steering head bearings because the bike is heavy and the brakes are good.
PostPosted: 12:38 - 04 Aug 2011    Post subject: Reply with quote
If its driven by the front wheel...like my CBR125. Piece of cake with a drill set to slow Laughing (BTW I have no intention on selling the CBR with false mileage, clocks and engine were fitted from a 5k mile bike and we wound them forward to 21k)
PostPosted: 13:07 - 04 Aug 2011    Post subject: Reply with quote
Being a typical Kawasaki they used minimal grease on the steering head bearings and linkages. Check them and don't be surprised if they are gone.
Doing the fork seals is a remarkably difficult job. Not because of the forks but because getting them off the bike is a pain. There is negligable clearance between the bottom yoke and the air intake tubes making it very difficult to get an allen key onto the pinch bolts to undo them. Also, from experience, if someone has just stuck thicker fork oil in when changing the seals the handling is dire.
Exhausts do rot, but at that age I would be surprised if it still had the original exhaust.
Calipers are a pain. Not great at best but also seize up easily and suffer badly from corrosion.
Rear shock adjusters for preload will probably be seized.
Clutch cables do not seem that long lived. Also is it possible for the clutch actuating arm to drop down if the cable snaps at that end. And that lets a load of engine oil out.
Seat height is fairly low and pegs a reasonable height. A bit cramped for me and I am hardly tall.
One we have is brilliant on petrol (doing 60mpg on the motorway) and the tank is a reasonable size.
Getting the fairing off is a pig of a job. Like one of those wooden cube puzzles that only come apart in one certain way. Similarly getting the airbox back in place is a pain but fortunately it doesn't need to come off often (plug change or valves really).
Oil cooler seems to get showered with rubbish and looks wrecked. Ours is still hanging on though.
2nd gear can fail. Seems very dependent on use though. Ours has done about 60k and 2nd is still fine. Have a spare engine in the garage which has done about 20k and jumps out of 2nd.
Frame is easily damaged if dropped. Widest part of the bike is pretty much the frame rails around the outside of the engine.
Footrest rubbers seem to fall off. Not a major issue but strictly speaking an MOT failure.
Changing a headlight bulb is a pig of a job if you are unlucky. On ours the bulb blew the day we bought it so wandered back to the dealer in the hope of a free bulb. They offered to fit it as well which was difficult. Then the metal clip holding the bulb into the headlight dropped into the light. Took the 2 mechanics and me about an hour just to change the bulb.
The battery is under a cover under the seat. Just means if you need to change the battery or jump start it that there are an extra 4 unnecessary bolts to undo.
If you change a wheel bearing then be aware that on one side there is nothing to seat the bearing onto. Day dream while fitting a bearing and you will land up knocking it through so it is clanging around in the middle of the wheel (can be got out though).
Oddest problem was the span adjuster on the brake lever disappearing. Not pleasant suddenly having the lever come back to the bars with very little braking effort.
UnspeedySam
PostPosted: 13:49 - 04 Aug 2011    Post subject: Reply with quote
Go and buy this month's ride magazine. They have a buyers guide. Although a lot of it seems to have been covered in this thread. If you get fed up with it before march I'll have it Razz
imanupstart
PostPosted: 13:55 - 04 Aug 2011    Post subject: Reply with quote
This is so true, just ripped the fairings off mine. Ripped being the operative word!
pits
PostPosted: 15:18 - 04 Aug 2011    Post subject: Reply with quote
[blatantplugon]And if it is a single sided exhaust, I believe I have a stainless steel end, pm me if interested[/blatantplugoff]
jjdugen
PostPosted: 16:28 - 04 Aug 2011    Post subject: Reply with quote
There are two types, the D and the later E. The later the better (obviously).
I've just finished a ground up rebuild on a '93 E type........
Paint finish is thin, especially on swingingarm. Best to take it all out, repaint and regrease the linkages. The shock was a rusty mess, replaced it with one of a ZX6, ride height adjustment (just drill a suitable hole in the shock mount plate and feed the ride height clevis through. Two suitable bolts, under and over, and you now have ride height adjustment and compression/rebound damping adjustment). Works a treat and cost £35 off the 'Bay.
The 'ram air' system is marketing bollocks and all the plumbing just gets in the way, Ditch it, block off the big holes in the frame Now the engine is much more linear with no appreciable loss of power.
Nissin calipers from CBR600/fireblade/VTR1000 fit with a minimum of modification. Well documented on the ZZR sites. Cheap upgrade to calipers made out of metal rather than cheese.
I find the bike to be a perfect mix of performance (for UK roads) comfort, economy (except when ragged) and generally solid build quality. This one is heading up to 50000 miles, I had budgeted for a replacenet engine, but its still strong with no gearbox problem so they 'can' last very well.
I like 'em, especially as they are SOOO cheap.
Mrjoolz
PostPosted: 16:39 - 04 Aug 2011    Post subject: Reply with quote
just called dealer to ask if I can come across and test ride it tomorrow morning at 9.00am. Looking forward to it actually, as I have never ridden one of these. Last couple of bikes have been super sports, but interested to know what this will feel like for my commuter work horse.
If it actually does 200 per tankfull, wicked. I checked for insurance and it is 97.00 TPF&T if I get Datatool Veto fitted to it, and have been honest bout 0 no claims as not ridden for 5 years, and it still came out
they also have a hornet but no fairing and 30 miles of my commute each way is motorway.
PostPosted: 16:53 - 04 Aug 2011    Post subject: Reply with quote
Ours is probably running a bit lean and probably should be set up for the pipe. However last tank was 188 miles I think and it hadn't gone onto reserve yet. Bit of self control to keep the cruising speed nearer 70 than 80 which makes a bit of difference. Doing 90 rather than 80 makes a quite noticeable difference (enough that a 188 mile round trip is pushing it for a tank of fuel).
With the Micron pipe there isn't that much go until about 8k (100mph in top) and a bit flat for a few thousand before that. Quite buzzy at 4k to 5k.
PostPosted: 16:58 - 04 Aug 2011    Post subject: Reply with quote
Mrjoolz wrote:
just called dealer.
Dealer in Maidstone by any chance...?
jjdugen
PostPosted: 17:11 - 04 Aug 2011    Post subject: Reply with quote
Dealers are going to add their fees, EBAY every time.
Mrjoolz
PostPosted: 18:07 - 04 Aug 2011    Post subject: Reply with quote
paddy, no I didnt find any in Maidstone for that sort of money. I'm down on the south coast at the moment, seeing the in laws, and there was one down here., which I went to see.
£1,600 for a N Reg ZZR600 with 12K on it, seems a good price for a dealer. The bike looks really clean and all the numbers in the mileage on the clock are in line, so unsure if its been tampered with.
Mrjoolz
PostPosted: 18:14 - 04 Aug 2011    Post subject: Reply with quote
is it easy to check if there is water in the sump, when checking the bike over ? how would you tell without opening it up?
PostPosted: 19:20 - 04 Aug 2011    Post subject: Reply with quote
Open the oil filler cap. You'll see if its emulsified.
£1600 for an N reg ZZR...
Im not going to say anything bad, as its your choice, but i'd definitely look for something other than that for £1600.
Nemo bought his XJ600 for £780, 15k miles on a K plate, immaculate, brand new tyres/chain/sprockets/MOT and tax.
Im not kidding, pristine condition. Shocked
Macie_UK
PostPosted: 21:31 - 04 Aug 2011    Post subject: Reply with quote
As per the above advice, plus give it plenty of hammer in the throttle in second gear. The ZZRs have a common-ish issue with a gear selector fork and or drum, which normally starts in second gear when you are hard on the throttle - it either feels like the chain has skipped a few teeth, or it finds a false neutral. If it's wear on the drum it can last many thousands of miles but they have been known to get progressively worse then lock the box up. Proper repair by a garage will cost you £600 plus.
Also switching from the standard exhaust to a 4 into 1 will leave you with a massive flat spot around 3000rpm, easy enough to ignore it though as most of the fun starts at 7000 Thumbs Up
Apart from the well known faults, they are brilliant bikes - I put 52,000 miles on my last one and would not hesitate to have one again.
I must say that for the money you quoted, that bike should be utterly spotless - I'd be looking at a post 2000 one for that.
Macie
Current: Triumph TT600
Most Missed : TZR250 (for laughing like a loon) | MZ Baghira 660 | ZZR600E1 (for everything else)
temeluchus
PostPosted: 06:38 - 05 Aug 2011    Post subject: Reply with quote
Wear and problems with second gear on these bikes (as well as the zzr1100 and gpz1100s) can be caused by the "positive neutral finder"
These are some sprung ballbearings that are supposed to make selecting neutral easier but if oil changes are neglected or the bike has stood the channels they move in can collect shit jamming the bbs. This causes issues and wear with second gear and/or jam the bike in neutral.
Mrjoolz
PostPosted: 11:00 - 05 Aug 2011    Post subject: Reply with quote
Off to The dealer to test the bike in 45 mins. I will update u all with how I get on. Will try opening it up in 2nd gear to see if it pops out of gear.
Will look at bike properly and take some pics when away from shop if I'm out on my own
Mrjoolz
PostPosted: 18:35 - 05 Aug 2011    Post subject: Reply with quote
Well been and seen bike. Took it out and really quite impressed. For some reason I thought about cb500 performance but it quite surprised me.
If I need to replace shock as I understand they can go, what should I put in and and from what bike? How big a job is it?
PostPosted: 18:38 - 05 Aug 2011    Post subject: Reply with quote
Not that bad to do a shock swap on the ZZR. Personally stick a half decent replacement on (Hagon maybe) rather than trying to bodge on a replacement on which the spring rate and damping may or may not be suitable.
It should be a hell of a lot faster than a CB500. The ZZR600 was the first genuine 150mph 600.
Mrjoolz
PostPosted: 19:51 - 05 Aug 2011    Post subject: Reply with quote
Hi Keith, it is a he'll of a lot faster, but I thought as it was more of a tourer, that it would be as sluggish as a cb500, and didn't expect it to scream off once hit 7k. Smile
Pick it up Monday.
Looking forward to it. Need to get a two piece waterproof set for keeping on bike.
The last post was made 14 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 130.31 Kb
