thieving wankers and ignitions
Rufus
PostPosted: 12:40 - 04 Aug 2011    Post subject: thieving wankers and ignitions Reply with quote
i need to swap the ignition on my zx7r cause some little wankers cut up my old one. the new one i bought is attached to a top yoke so would it be easier to try and swap over the top yokes or to take out the old ignition and put the new one in given i have no idea how to get these bastarding shear head screws out and its starting to drive me up the wall Mad
please help.
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
Gazdaman
I did a trackday!!!
PostPosted: 12:48 - 04 Aug 2011    Post subject: Reply with quote
If the top yoke's in similar nick, I'd swap them, otherwise you'll have to drill out the security bolts and replace them with standard ones, clearly making it less secure for the next time.
Gaz
PostPosted: 12:53 - 04 Aug 2011    Post subject: Reply with quote
Gaz
You could always replace them with security bolts. They're not expensive. Although by the time someone has gone to the effort of removing the top yoke, I think the bike's gone anyway.
I agree though, replacing the whole top yoke would be easier. You're going to have to take it off anyway.
Aff
PostPosted: 14:11 - 04 Aug 2011    Post subject: Reply with quote
Defiantly easier to replace the yoke, i had to swap my barrel to a new yoke the other day and drilling those stupid bolts out is a PITA. Your gonna need a Torx security screwdriver (one with the little hole in the middle) to attach it to the old loom though.
Electric Bike Project
Rufus
PostPosted: 14:55 - 04 Aug 2011    Post subject: Reply with quote
thanks guys, that's my next question, how do i get the top yoke off? i understand you have to take weight off the forks and other things ant it's not just a case of unscrewing all the bolts Laughing
damn i suck at bike stuff.
0ddball
PostPosted: 15:28 - 04 Aug 2011    Post subject: Reply with quote
Undo the top yoke pinch bolts, take off the stem nut and you can either loosen the clipon pinch bolts and slide them off the forks at the same time as the yoke or if have access you can remove the bolts that fasten the clipons to the underside of the yoke (M6 allen iirc) and just remove the yoke.
ZXR750L
Fortuna
PostPosted: 17:40 - 04 Aug 2011    Post subject: Reply with quote
Don't forget, steering to the right. You'll be scratching your head wondering why it isn't moving otherwise.
Rufus
PostPosted: 12:09 - 08 Aug 2011    Post subject: Reply with quote
how do i remove the stem nut though? keep in mind i am a TOTAl motorbike maintennance spastic.
MarkJ
PostPosted: 13:22 - 08 Aug 2011    Post subject: Reply with quote
With a socket that fits and a ratchet. Nut will be around 22-28mm.
Rufus
PostPosted: 14:16 - 08 Aug 2011    Post subject: Reply with quote
so i just have to apply some masculinity to it? Laughing
afraid to do it hard in case i break something haha.
cheers everyone Smile
Fortuna
PostPosted: 15:22 - 08 Aug 2011    Post subject: Reply with quote
34mm!!
mad4it028
PostPosted: 15:25 - 08 Aug 2011    Post subject: Reply with quote
if i remember rightly the main stem bolt is an alen key a very big one at that about 17mm or there abouts , i used car sump bolt tools avalable from machine mart about £15 the set
Rufus
PostPosted: 15:27 - 08 Aug 2011    Post subject: Reply with quote
Fortuna wrote:
34mm!!
you sure it's 34mm? will order the socket now if so. i have a spanner that gets around it but i cant get it to budge!
0ddball
PostPosted: 15:37 - 08 Aug 2011    Post subject: Reply with quote
It's a few mm bigger than my biggest socket which is 32mm so 34mm sounds right. I usually just use a massive pipe wrench.
ZXR750L
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.88 - MySQL Queries: 13 - Page Size: 81.95 Kb
