urgent - bike died - ts50- now not stating and riding
wardy941
PostPosted: 16:51 - 03 Aug 2011    Post subject: urgent - bike died - ts50- now not stating and riding Reply with quote
I have my ts 50 running but only with the choke on so i cleaned the carb
i changed the transmission oil - i used mtx gear oil
i cleaned the carb in boiling water and used the air line to blow the jets and carb and dry them then left in sun for an hour to ensure no water was left
the bike still didnt want to run right without the choke - but it rid for a bout 2 hours in total ( not all in 1 run)
it then suddenly died on me not reving at all - sometimes it will start and the throttle wide open it just idles and will die after a minuite or two - if i remove the slider it will sometimes start and rev high to about 7-8000 rpm
anyone have any idea what could be wrong
nisp
PostPosted: 18:49 - 03 Aug 2011    Post subject: Reply with quote
when i had my ts i was using it, as you do. and it started running ruff at about 5-7 and would be ok for a while and go back to running weird. well the thing was the 2 st oil adjuster had moved, for the worse Sad so i put it on 20 : 1 and not a problem since. as long as the lines are cleared and its properly jetted for aftermarket filter it might be the oil adjuster
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
wardy941
PostPosted: 16:40 - 04 Aug 2011    Post subject: Reply with quote
i sorted it today the pilot jet had fallen out as i didnt tighten it enougb Laughing
But it will still only run with the choke it dies when leave to idle without and seems to have lost power latly
The last post was made 14 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 36.39 Kb
