Scuffs on heel plates.
flat eric
PostPosted: 22:05 - 05 Aug 2011    Post subject: Scuffs on heel plates. Reply with quote
Ive just bought a GSX-R600 K7, and noticed that the heel plates are a little scuffed from the previous owner.
Does anyone know what the best way to get rid of these scuffs. Or do i need to get them treated or will the scuffs polish out with some autosol or other.
Helpful advice needed.
There is always someone worse off than you !
The Tot
PostPosted: 22:11 - 05 Aug 2011    Post subject: Reply with quote
You need to go through the grades of wet and dry - 80->1200. You can leave it at 1200 for that brushed aluminium look. If you want a mirror finish, treat it with autosol. Scuffs are a bit of a bugger because the heelplates are usually lacqured. My alpinestars SMX Plus with the ally heel plates are the main culprit for my scuffs.
Never argue with autism
flat eric
PostPosted: 22:20 - 05 Aug 2011    Post subject: Reply with quote
Cheers The Tot, I'll give the autosol a try first and see what result i get. I think that as you say, the laceur coat has probably been damaged by the boots of the previous owner. have you tried the Autosol method yourself or have you heard that it works ?
hornetmike
PostPosted: 22:43 - 05 Aug 2011    Post subject: Reply with quote
powder coat
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
The Tot
PostPosted: 22:47 - 05 Aug 2011    Post subject: Reply with quote
Ive tried the autosol method but if the lacquer's been taken off, then it'll look unsightly, hence why it's a good idea to polish all the way down to bare alloy then work up the grades and finishing off with autosol. That's the only way to remove the scratches.
I wish HG were still doing autosol for £2.99! It was cheaper than toothpaste!
flat eric
PostPosted: 20:58 - 07 Aug 2011    Post subject: Reply with quote
Just tried Autosol on it, and it didn't touch the scratches. Will get a selection of wet and dry sheets as you (The Tot) suggests. Thanks for your good advice. I did try some wet and dry grade 400, but it was not course enough to remove those annoying scratches.
MaybeGuy
PostPosted: 20:59 - 07 Aug 2011    Post subject: Reply with quote
this thread is like saying ''why do my tyres wear out?''
PostPosted: 21:43 - 07 Aug 2011    Post subject: Reply with quote
Worn heelplates are a sign of a bike that's been squeezed. Thumbs Up
DrDonnyBrago
PostPosted: 11:40 - 08 Aug 2011    Post subject: Reply with quote
T cut do a version of Autosol that costs £2.99 in ASDA atm. I got a few tubes, tried it on a Pewter mug yesterday and it worked well. Haven't tried it on anything else though.
JAMSXR
PostPosted: 11:56 - 08 Aug 2011    Post subject: Reply with quote
This. Stop being such a fanny! Wink
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 65.41 Kb
