r6 don't go please help .is going into a robin reliant
fs1eman
PostPosted: 09:42 - 06 Aug 2011    Post subject: r6 don't go please help .is going into a robin reliant Reply with quote
i have just got r6 .clocks missing ,will not fire or start .anyone please Shocked
PostPosted: 09:49 - 06 Aug 2011    Post subject: Reply with quote
What year?
Does the fuel pump prime?
Does it crank over?
fs1eman
PostPosted: 09:59 - 06 Aug 2011    Post subject: r6 dont go Reply with quote
the pump dont prime year is 2000
fs1eman
PostPosted: 10:02 - 06 Aug 2011    Post subject: r6 dont go Reply with quote
it will crank over if i bridge the starter solenoid but no spark
PostPosted: 10:08 - 06 Aug 2011    Post subject: Reply with quote
It's not going to start if it's not getting fuel or spark. You need to solve both of those issues first.
Is it a trackbike?
fs1eman
PostPosted: 10:11 - 06 Aug 2011    Post subject: Reply with quote
no just brought it salvage , does it need clocks to make it run ?
PostPosted: 10:13 - 06 Aug 2011    Post subject: Reply with quote
Seen plenty of early R6s with race tachos so shouldn't do.
Might need to you to be a bit creative with the loom though.
fs1eman
PostPosted: 10:17 - 06 Aug 2011    Post subject: Reply with quote
will do the loom ,as soon as it go,s .just want to check is all OK with the engine ,and more help on diagnosing the problem '
mad4it028
PostPosted: 10:57 - 06 Aug 2011    Post subject: Reply with quote
have you got the key? as it sounds to me like the ignitions not switching on
check side stand switch 1st
has the clutch lever snapped?
if it has try joining the wires at the lever to each other same with the side stand
fs1eman
PostPosted: 11:19 - 06 Aug 2011    Post subject: Reply with quote
thanks for the info ,have tride all of this but no luck yet ,any more info thanks tony
PostPosted: 11:24 - 06 Aug 2011    Post subject: Reply with quote
Don't believe that year R6 uses a chip in the key, or has an immobiliser as standard so it makes life a bit eaier.
I assume you do have keys with it?
fs1eman
PostPosted: 11:27 - 06 Aug 2011    Post subject: Reply with quote
have a new key . i don't think that have immobiliser on this model .run out of ideas at the moment ?
PostPosted: 11:34 - 06 Aug 2011    Post subject: Reply with quote
Does it have an aftermarket immobilser anywhere on it?
mad4it028
PostPosted: 14:22 - 06 Aug 2011    Post subject: Reply with quote
ive bought salvage bikes that have had the ignition left on after crash burning out the coils or cdi these were mostly stolen recovered tho that were hot wired , but i always go on the assumtion that they wernt pushing the bikes when they crashed so they must run, does it have a tilt switch?
The last post was made 15 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 78.11 Kb
