| wardy941 |
 wardy941 Two Stroke Sniffer
| Kickstart |
 Kickstart The Oracle
| wardy941 |
| Kickstart |
| Pete. |
 Pete. Super Spammer
 Posted: 01:55 - 07 Aug 2011 Post subject: |
if it's connecting only one side of the top of the piston then the piston must be quite loose in the bore.
With the head off does the crown stand proud of the barrel? There should be about 1mm of clearance between piston and head at TDC ____________________ a.k.a 'Geri'
| wardy941 |
| Pete. |
 Pete. Super Spammer
 Posted: 13:59 - 07 Aug 2011 Post subject: |
Well yes it could make the difference between the piston hitting the head or not. ____________________ a.k.a 'Geri'
| wardy941 |
| wardy941 |
| Pete. |
 Pete. Super Spammer
 Posted: 14:20 - 07 Aug 2011 Post subject: |
You'll get more power from the big bore but you have to make sure the jetting is right because it will produce a lot more heat too. If the piston's been hitting enough to damage it then you should check the big-end and main bearings for up and radial (up and down) play.
Why not put up some decent photos of the damaged piston? ____________________ a.k.a 'Geri'
| wardy941 |
| wardy941 |
| Kickstart |
| wardy941 |
| Kickstart |
| wardy941 |
 Posted: 21:50 - 07 Aug 2011 Post subject: |
| Kickstart |
| wardy941 |
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
